Question about Electrolux Kenmore 3.5 cu. ft. I.E.C. High-Efficiency Front Load Washer / Dryer
I have a Kenmore 3.5 Super Capacity front load washing machine that is acting like it has a power problem. It stopped in the middle of a cycle and no lights would come up on the display. I unplugged it and plugged it back in and it worked long enough to drain and refill with water when it quit again. I tried the breaker and the outlet, and power is flowing. From looking at other posts, I'm thinking my board might be bad. Does it sound like that, and how much should I expect to spend to get it fixed?
  • 117 Answers
SOURCE: Stops at spin cycle
Open the lid to the washer and let it down gently. You should hear a click when the lid closes. If you don't hear it, the lid switch might be faulty and this will prevent the washer from going into spin. Not an expensive repair.
http://tclaundryrepair.com/
Posted on Feb 20, 2009
  • 4 Answers
SOURCE: Broken front loader washing machine
take the back off and see if the belt has come off. is it draining water? if not make sure nothing is blocking drain pump
Posted on Apr 23, 2009
jsrock516
  • 5911 Answers
SOURCE: Whirlpool heavy duty super capacity plus machine slow to fill.
This problem is commonly attributed to a water inlet valve that has become clogged with sediment or calcium deposits over time. If you live in an area that has hard water, or if you use well water, this is a common problem. You can remove the valve and attempt to clean it by soaking it in a 50/50 solution of distilled vinegar and water, or you can simply replace it all together. If you're going to go the route of removing the valve, it makes better sense to replace it, rather possibly having to repeat the steps again if cleaning the valve doesn't work. The following link explains how to access and replace one:
http://www.fixya.com/support/r3575881-replacing_water_inlet_valve_on_whirlpool
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
I have found these sites to be reputable and provide great service. Prices differ between them, so shop and compare. If you do not wish to order parts on line, look up the part numbers on the Sears site and check with your nearest appliance parts retailer. These is a common part that may be commonly found in their in-store inventory. The average cost is about $30 - $35.
If you DO wish to attempt to clean the valve to save some money, submerge the valve in a 50/50 solution of distilled vinegar and hot water for about 30 minutes and flush with clean water. DO NOT submerge the electrical connections.
You may also try any number of calcium, lime and scale removers on the market. CLR comes to mind as a good product, but use in a well ventilated area. It has some very strong fumes.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Posted on Mar 18, 2010
Testimonial: "Great advice. I will follow your clear and easy steps. Sounds like one or the other solution will be fine."
marka19
  • 1430 Answers
SOURCE: Whirlpool heavy duty super capacity plus machine. ...
First you should remove the hoses and clean the screens in the ends of the hose, some hoses have screens in both ends. While the hoses are removed look inside the water inlet valve there should be a screen in there also remove and clean the screen out. Some screens will not be removable so you will need to clean in place or remove the water inlet valve. If all is clear you will need to check the solenoids on the water inlet valve for power.If the solenoid has power when put in a fill cycle and no water eneters your washer you will need to replace the water inlet valve. Most water inlet valves must be replaced as a unit, so if one solenoid fails you replace the hole valve assembly. These are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru the testing procedure. It may be a different model but the testing will be the same. If you need help disassembling there are also videos of disassembling most styles. You can also enter your model # for diagrams and illustrations of your specific model. Not all models will be available. All parts come with installation instructions.
Posted on May 20, 2010
BIKER T
  • 909 Answers
SOURCE: Hi, I have an Electrolux
Im taking it that you have a squirrel cage motor.(motor without bruhes) Locate the capacitor and replace it. Most of the time its the capacitor that has malfunctioned and that will stop the spin cycle. If you have a soft start.(an electronic control), then check the brushes. Possibly need someone to help as the motor will need to be removed to gain access to the brushes. Check length. must be at least 25 mm.(otherwise not enough tension). Make sure power is pulled out when doing this repair.
Posted on Sep 05, 2010
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Kenmore super capacity washer3.5 not working lights flashes and stops
This is usually a sign that the drain pump filter needs to be dumped or an object has jambed the pump mechanism.
Jan 30, 2013 | Kenmore 3.5 cu. ft. Front Load Electric...
I have a kenmore washer that does not drain and spin at the end of the wash cycle....Kenmore Super Capacity 3.5...Quiet Tumble Action...Easy Access
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 02, 2010 | Frigidaire ATF6000ES Front Load Washer
Kenmore washer 3.5 super capacity. Machine spins
It sounds like your tub bearing is bad or going bad. It could be the adjustment on your spin cycle. Does your unit allow you to adjust this. Also are you overloading. Can you send me the brand and model of your unit and I help you more.
JimmyC
Oct 05, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Front loading washer won't spin
my amana washer wont spin and does not drain
Sep 11, 2009 | Kenmore Washing Machines
Won't fill w/ water, Kenmore 3.5 Super Capacity Front Loader
The pressure switch is likely to blame. Change it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 28, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Stops at spin cycle
Feb 20, 2009 | Electrolux Kenmore 3.5 cu. ft. I.E.C....
Washing machine suddenly stopped working during cycle
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jan 01, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Kenmore Super Capacity front loading washer that has stopped.
Hello SMCCRAVE,
You are referring to a top loader problem.
A front loader is different the following is from the youtube page that has video explaining the possible issues!
Washing machine not spinning? This video provides information on how to troubleshoot a front-load washer that won't spin and the most likely defective parts associated with this problem. These are sorted from most likely to least likely to be the issue.
Commonly replaced washer parts:
Drive belt
Door lock switch
Motor control board
Stator/rotor
Drive motor
Good Luck!
Rich Lilja
May 21, 2017 | Kenmore 46462 Front Load Washer
Electrolux Kenmore 3.5 cu. ft. I.E.C. High-Efficiency Front Load Washer / Dryer Logo
83 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
