Question about Mtd Products Yard Machines 158CC Tiller
Yard machine Tiller 21A-410-118 Mt tiller sat all last year and will not start this year. I drained all the gas at the end of 2009. I can get it to start with a little starter fluid but it won't keep running. I also need manual for this as i bought it from a neighbor and he did not have any.
5 Suggested Answers
  • 666 Answers
SOURCE: Need manual or details for Yard Machine 21A-333A129
Go to http://manuals.mtdproducts.com then click public site.
Posted on Mar 28, 2009
SOURCE: I need a manual for my MTD Huskee 5hp rear tine tiller
I went to MTD web site and they had all the manuals for all there products. You will need a model and serial number to get them. Thank you for responding back to me.
I got the manual for the tiller and the engine.
Posted on Apr 13, 2009
KMusselmann
  • 247 Answers
SOURCE: NEED THE BELT SIZE FOR TILLER ,MODEL NUMBER
Well I cannot find the size but I did find the part # and a place to order the part. Hope this helps
Kurt
Part # 754-0434
Can get from the following
http://www.buymtdonline.com/webapp/wcs/stores/servlet/Home_YardMachines_10101_19502_-1
Posted on Apr 17, 2009
SOURCE: BELT PLACMENT ON TROY BUILT TILLER MODEL
I am assuming your belt broke and you cannot find the replacement.
I had to go to an old timer that owns his independent business and he was able to find a much better belt than the one that came on the tiller. The Belt # is 1916657 and it is 25.5 inches long and 1/2 inches wide. It also has a kevelar core that will stand up to the constant gearing up and down.
Lowes was NO HELP AT ALL!!!!
Hope this at leasst get;s you in the right direction
Posted on Apr 25, 2009
Belt broke on my 12 inch mtd yard machine front tine tiller model 21a-250m000 how do i replace it. thank you for your help!
part # 754-04123 v-belt 1-888-656-7278 for parts pull off 4 bolt on bottom red cover to frame replace belt put cover back on
Feb 27, 2011 | Mtd Products Yard Machines 158CC Tiller
Ifound a Tecumseh Yard Machine Front Tine Tiller. It has a 5.50 HP. The tiller seems to choke out every time i crank it up. Can Someone tell mewhere the fuel filter is located???? i have replaced the air...
It sounds as if you still have Carburetor problems.
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked.
(If there is a small screen in the Carb., this can get blocked too. Make sure that it is clean as well.)
Reassemble and start. (If there is a small screen in the Carb., this can get blocked too. Make sure that it is clean as well.)
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Sep 05, 2010 | Yard Machines Tecumseh 148cc Front Tine...
Just helping someone who put gas in her oil fill. What do I need to refill oil? SAE 30 ?
Yes, the Tecumseh engine takes SAE HD30 motor oil. With a complete drain, it should take about 21 ounces to fill.
Aug 26, 2010 | Yard Machines Tecumseh 148cc Front Tine...
Tiller wont get fuel to start
Try disconnecting the line at the carb. Then carefully blow back to the tank. It may have something blocking the outet from the tank. If that doesn't do the trick, the float may be stuck and not allowing the needle to open for fuel to enter the carb bowl. Good luck...Lee
Aug 05, 2009 | Yard Machines Tecumseh 148cc Front Tine...
Have a 2002mtd front tine m.n.#21A-333 A129 just bought its been sitting in garage for 4 years. Cleaned out gas carb ect but starts for only a min then quits. Help...Thanks
It's still in the carb. Needs to be cleaned out really well, all the jet and orifices cleared. Soaking in carb cleaner for several hours and blown out. Also, depending which carb you hsve, it may have a rubber seat that will deteriorate and swell, cutting off gas supply. If it has a rubber tipped needle, that does not apply.
Jun 07, 2009 | Mtd Products Yard Machines 158CC Tiller
We have a mtd yard machine roto tiller model 21A-340-06295208
i need a part list for a tiller model 21a
Mar 28, 2009 | Mtd Garden
Tiller won't start
You may need to perform a rebuild or possibly a good cleaning on the carb. any questions on it feel free to ask
Mar 17, 2009 | Yard Machines Tecumseh 148cc Front Tine...
Mtd Products  Yard Machines  158CC Tiller Logo
181 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
