Question about Nokia Lands Phones
I want to deactivate call barring on outgoing calls for my Nokia N97 Mini but it needs a password. I've tried some codes such as 0000 and 1234 but it won't work. It's a four digit password, does anyone know anything I could try?
  • 107 Answers
This requires more technical support i would advise you to visit your service provider for assistance on this issue because for passwords in most cases they are changed from default and thus making it hard to guess and their is no specific break in code. however you could try these and see if they help:
Change call barring code **03*OldCode*NewCode*NewCode#©
Change call barring code **03*330*OldCode*NewCode*NewCode#©
default barring code is set to (5 zero's 00000) or 12345
Posted on Mar 19, 2011
How to unblock barring password for nokia 5310
Call Barring - Enables you to restrict or bar certain or all types of calls to and from your mobile phone, i.e. outgoing calls, outgoing international calls, incoming calls. Barring is activated with a personal code.
Call barring is a mobile phone feature that allows the user to set certain prohibitions on incoming or outgoing calls. This is an effective means to prevent the phone being used to make expensive international or premium rate calls, particularly when the phone is to be used by people other than the subscriber.
Many companies that provide handsets for business use now employ call barring as a security measure, to control their use and restrict calls to pre-approved numbers. The user's personal code must be used to activate this feature.
How do I get it?
Contact your local Service Provider. You will need a four digit barring code. Initially this will be 0000. You should create a personal barring code for security. Please consult your cellphone's instruction manual.
What does it cost?
This service is free.
Also you can deactivate it from your cell phone..
Different cell phones have different setting functions,
You can try these out. It's the general way to deactivate call barring (NOKIA) .
Follow the below instruction:
Go to Menu,
Enter settings,
Scroll to Security,
You will see call barring on that list,
Click on it,and scroll to last option and you will see cancel call barring.
Your cell phone might not be the same with these functions,but the procedure are aways the same..
Good luck.
Jul 18, 2011 | Nokia Cell Phones
Call barring password for Nokia 2730
Hi,call barring - Enables you to restrict or bar certain or all types of calls to and from your mobile phone, i.e. outgoing calls, outgoing international calls, incoming calls. Barring is activated with a personal code.
How do I get it?
What does it cost?
Go to Menu,
Enter settings,
Scroll to Security,
Good luck.
Samsung b7320 omniapro call barring password
How do I get it?
What does it cost?
Go to Menu,
Enter settings,
Scroll to Security,
Good luck.
Jul 11, 2011 | Samsung Omnia Pro B7320 Smartphone
Please help mo to anblocked my call barring password.. i forgot my password and now it is blocked. :(
How do I get it?
What does it cost?
Go to Menu,
Enter settings,
Scroll to Security,
Good luck.
Jun 17, 2011 | Nokia C3 Cell Phone
I dont know my call barring password,my phone is nokia E63
How do I get it?
What does it cost?
Go to Menu,
Enter settings,
Scroll to Security,
Good luck.
Jun 13, 2011 | Nokia E63 Cell Phone
To remove call barring activation
How do I get it?
What does it cost?
Go to Menu,
Enter settings,
Scroll to Security,
Good luck.
May 28, 2011 | Nokia Handsfree For 6020, 6101, 6102...
My nokia phone can neither call nor receive acall,,its barring codes are blocked
I am sure this solution will help you, Just follow the steps.
1- Go into the settings and find the option of call barring usually its in call settings option. 2- Then you find the option of deactivate barring on all outgoing & incoming calls select yes and if it ask you any code or password then its 0000 by default or your sim pin code if you haven't changed. 3- After deactivating barring of incoming and outgoing calls, your phone can make and receive calls.
May 22, 2011 | Cell Phones
Hwo to block the incoming call from a particular number in Nokia E5 mobile with the options with the mobile
You can bar the calls that can be made
or received with the device (network
Make calls 35
© 2010 Nokia. All rights reserved.
service). To modify the settings, you
need the barring password from your
service provider. Call barring affects all
call types.
Select from the following voice call
barring settings:
Outgoing calls - Prevent making
voice calls with your device.
Incoming calls - Prevent incoming
calls.
International calls - Prevent calling
to foreign countries or regions.
Incoming calls when roaming
- Prevent incoming calls when outside
your home country.
International calls except to home
country - Prevent calls to foreign
countries or regions, but allow calls to
your home country.
To check the status of voice call barrings,
select the barring option and
Options > Check status.
To deactivate all voice call barrings,
select a barring option and Options >
Deactivate all barrings.
To change the password used for
barring voice, fax, and data calls, select
Options > Edit barring password.
Enter the current code, then the new
code twice. The barring password must
be four digits long. For details, contact
your service provider.
hope this helps
John
Jan 31, 2011 | Computers & Internet
How do i deactivate GPRS from Nokia N97? Thanks.
deactivation of your GPRS service
- call the network service provider
- they will deactivate your GPRS service or they will given you the code to deactivate GPRS or given the procedure to deactivate
if u satisfies with the information given by me
vote me!!!
Jan 05, 2010 | Nokia N97 mini Smartphone
Lands Phones Logo
447 people viewed this question
Top Nokia Lands Phones Experts
Faiz Mohammed
Faiz Mohammed
Are you a Nokia Lands Phone Expert? Answer questions, earn points and help others
