Question about Philips Gemini FM-64 Hand Held PLL Transmitter Microphone 3 Yrs. Warranty Microphone
Need to take mic case apart - Philips Gemini FM-64 Hand Held PLL Transmitter Microphone 3 Yrs. Warranty Microphone
When I key the mic up it turn off and then comes back on
Have you tried to look at mic pins where the mic connects to radio?. it will be at the end of mic connection..look in there and see if the copper pins have spread apart. you will be able to tell by looking at the other pins. if one is spread apart it wont make a good connection and shut things down. be sure when you screw this back on to radio it is tight., if you dont have copper pins just straight pins check to see if the straight pins are not loose. if they are you will need to solder them back tight.other than that it could be your radio..hope this helps.
May 28, 2016 | Radio Communications
My mircophone is broken? dont have money to fix? any cheap ways to still use
WOW this is an expensive camera, I would first HIGHLY recomend spending the money and send it to a good electronics or camera shop and have them fix it.
If this is not an option here are a couple or things you can do. Since this is a higher end camera it
should have a mic jack, if so just hook in a good microphone and it should work fine.
A couple of words of warning before tying the next solution you could permanetly mess up your
cameras sound. While this method theoretically possible, some companies intentionally make this
very hard. Often companies will use hair thin wires or wires that are so short thier is no way to
patch into them. Also, since this description doesn't use standard hardware you should disclose
this repair to anyone who might wish to buy the equipment if you decide to sell it. Also, the mic
that I've suggested may not be as good of quality as the original Sony. You can use
any mic of about the same size so long as it has wires to tie into.
If your not real familiar with electronics get a buddy with some experience repairing electronics to help.
If your really adventurous, you could take the mic assembly apart and put in a new mic. Just get a good compact mic like a KOSS M5 and splice off the end then shave the wires. Then carefully
take the mic assembly on you camera apart look for a small disk made of two magnets an a
fillament with 2 wires disconect the wires from the disk and hook them up to the shaved wires
from the KOSS microphone (one wire from a lead the other to the ground of the KOSS microphone). The KOSS mic will have 3 wires two sources/leads and a ground you might have to play around with it to figure out the wires and get it working properly. If your mic assembly has 2 mics figure out which wires are the lead by hooking them up one at a time (to the wires that originally were hooked to the internal microphones) with the ground on the other wire and trying them. Once you figure out which are the lead wires hook them each up to the old mic wires and take the other side and hook them both up to the ground. once you have it all wired back up and any splices insulated (elecrical tape should be fine) you should be able to re assemble the mic with the new microphones installed.
If the mics for the camea are intergrated into a circuit board the same method will work but
the old mics will need to be desoldered and the leads from the new mic will need to be soldered
where the old mics were. If this is the case get a buddy with some experience with electronics to help you.
Method three use an external recorder. For this method just record the sound with another external
device like a digital voice recorder then use an editing program like Sony Vegas to add the sound to your video. The hard part is syncronization. A clicker may help create sound tags to align the video with the audio with the sound.
May 04, 2011 | Sony Handycam DCR-VX2100 Mini DV Digital...
Audio Technica PRO-35: need wiring diagram for mic end
If you feel the shield goes to the middle, try red on one terminal and white on the other. If not, reverse it.
If it's labeled on the circuit board...pin 1, pin 2, pin 3, then pin 1 is usually ground, pin 2 is hot (red), and pin 3 is cold.
Mar 31, 2010 | Audio Technica Audio-Technica AT2020...
How to replace the mic in a nintendo ds?
first you need to take off the back of the ds. Then you will need to unplug the white wire it snaps on and off.After that you will need to take opart the top to get to the mic.the four screws for the top are on top and the bottom of the speakers under those little squares.To get the top apart slid the back of the top up 1/8 of an inch then you can pull apart.the mic is just under the top screen so push the top screen through so you can get the mic out slowly pull the wire out and put the new one in the same way you took the old one out.when taking the back off the bottom start away from the on off switch you can get a tri wing screwdriver on ebay.
Mar 03, 2010 | Nintendo DS Lite Console
Mic problem
If you press on the mic area and it's effected by the pressing, its most likely a loose solder or cut wire etc. Would need to take the phone apart and inspect the microphone. If you have warranty on the nokia use the warranty and don't take it apart yourself.
Mar 17, 2009 | Nokia N91 Cellular Phone
Gxl 2400 wiring connections
well best to just resolder it if you know the wire it should have a standard diaphragm with standard layout. should be asimple fix.
thanks,
Nate
Aug 12, 2008 | Audio Players & Recorders
Microphone not working
The microphone level can only be adjusted in certain games. Have you tried using the mic in any other games? Most likely, the mic is simply defective; I have heard of more than one case of manufacturing defects with Nintendo DS microphones. How long have you had the system? If it is still under warranty, Nintendo should fix the system for free.
Jan 27, 2008 | Nintendo DS Console
Phone connection issues
Well, I get this from time to time too and am embarrassed to discover each time that it was my Bluetooth device in my car I was standing next to that locked onto my phone and took over of my mic and audio features of the handset.
It is possible that your Bluetooth features is turned on and locking onto some device that you, at the time, are unaware of. That may be the problem on your end or your friends end as well. Try turning off the Bluetooth feature on both phones to see it it solves the issue.
However, if you hear them but they can’t hear you maybe your mic has a bad connection inside the ph case... once open you can clean the contacts with a pencil eraser and bend the mic contacts up a little and reassemble. You can remove the mic from the ph case and take it apart to clean it, but note the location, orientation and mark the side you can see of the black contact base that is snapped into the rubber mic holding boot. The mic looks like a small watch battery when removed from the rubber mounting boot. It is easy to get it all confused and out of wack if you do not mark things and or even take pictures of it before removal. Unless your ph is really old and you have a very dirty mic opening or know of spilling coffee in it or the like, cleaning the contacts may be all you need to do.
That’s what I know…
Robert R.
Sep 21, 2007 | Palm Treo 700w Smartphone
I dropped and it came apart
Solved it.
If you need to take it all the way apart, here's the scoop:
Get the top cover off by popping it up at the hinge side (this is what pops when you drop it)... then at the charging end, slide the top towards the hinge to slip the clips out from under something.
the folding mic tells the board it is open by a small z-shaped piece of plastic. The skinny end of this fits into a tiny hole in the bottom of the case and the fat side slides up and down in a little round space over on the side of the case. There is a rubber button with a dark piece that sits on top of the round space. The dark side of the rubber piece presses against a round circle on the circuit board and tells it whether the mic is open or closed. Once you put it all together, you have to press the board down pretty firmly to tell if it is all working.
Then put the volume buttons back in place and slide the top back on.
Jan 12, 2007 | Motorola Mobility H700 Wireless Headset
37 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
