carb needs a clean , try fireing a bit of injector cleaner into the carb (remove airfilter and spray a little bit at a time !! then try again , if still no good the carb will need to come off and be cleaned ,
hope this helps
kind regards
bert31000
Put a carby kit through it and clean, inspect and blow all ports through, check intake rubbers for any leaks, (pin holes can change air fuel ratio) Especially check for obstructions in your idle/bypass jet, do the kit first so you know its right, then tune your idle mix until steady.
