Question about Singer 7422
Singer advance 722 will not zig-zag or any other stititch but the straight stitch. How do I correct this?
  • 69 Answers
SOURCE: Singer model 2638 will only straight stich all of a sudden
Try changing your needle. That is the most common cause for this. If you hit a pin or broke a needle, it could have been thrown out of time. Try changing the needle, that will in all likelihood correct the problem.
Posted on Feb 12, 2009
  • 980 Answers
SOURCE: Skipping stitches while zig-zagging
If you have put a new needle in then the chances are the machine has gone out of time, you can either take it in to the repair shop or you can contact me and I will attach timing instructions drivewithken@blueyonder.co.uk
Posted on May 14, 2009
  • 3 Answers
SOURCE: need to know how to the zig zag stitch on the 132
By turning the bottom dial on the righthand side of the machine, you can change type of stitch. For zig zag, you need to set it to B (seen on the front of the machine). You can adjust the width of the zig zag using the same dial.
Posted on Jun 21, 2009
  • 8 Answers
SOURCE: Singer Athena 2000 won't zig zag
Try pushing the reset button underneath the machine. Mine does that too. I had it repaired a few months ago...apparently it needs a circuit board that is no longer available.
Posted on Aug 01, 2009
  • 2976 Answers
SOURCE: ZIG-ZAG NOT WORKING
Make sure your presser foot is tight down. If the needle is going from side to side, it's doing it's job. If the stitches are coming out straight, the material is probably slipping back and forth to center area. The presser will eliminate this.
Posted on Aug 28, 2009
My new Singer 4411 will not do zig zag or other stitches, just plain sewing
josephamoi Nov 17, 2017
When sewing ziz zag stitches the zig zag dial on your top right hand must be set any thing thing above 0. The setting is 0 to 6. Only on straight stitch this dial be set at zero.
Nov 15, 2017 | Singer Sewing Machines
On a singer machine from the 70's, how do you change it from sewing zig zag to straight line?
Most likely you change the stitch-width selector to straight, otherwise it will stitch in varying degrees of zig-zag.
Jul 07, 2017 | Singer Sewing Machines
HOW DO YOU CHANGE THE STITCHING FROM STRAIGHT TO ZIGZAG
Check that your sewing machine is even capable of zig-zag. Some machines are straight-stitch only.
Consult your owner's manual.
If your machine can do zig-zag, somewhere there is a dial or setting called "stitch width" that will determine how wide the zig-zag will be.
May 21, 2016 | Sewing Machines
TRADITION 2250 SINGER SEWING MACHINE HOW TO ZIG ZAG
From the pattern selector (the bigger dial), select the zig-zag stitch. Then, using the stitch length dial (the smaller dial), adjust the stitch length. The closer your stitch length is to "0", the more dense will your zig-zag stitch be.
Sep 04, 2014 | Singer 2250 Tradition
Someone gave me a singer 403. I put in the zig zag attchment but it still sews only straight. What am I not doing??
Of course, you have to push the zig zag adjusment lever from the 1 position to one of the zig zag positions, 2-5. Also, the zig zag disc must be inserted. Take of the top of the machine (two screws to loosen the attachment and lift off the top), and you can see a steel connecting piece called the pitman and it should move back and forth when zig zag is engaged. If it isn't, maybe something is gummed up as has been suggested.
Jul 20, 2012 | Singer Sewing Machines
Trouble sewing lycra fabric using a zig zag stitch
You have the machine set for blind hem stitching. Change the stitch selector to stretch stitch, which is a single, in line stitching zig zag stitch.
Cheers,
Embroidery Services
San Diego, CA
Sep 13, 2017 | Sewing Machines
What foot should I use for basic stitch or zig-zag stitch?
a all purpose foot or a zig zag foot will do both straight stitch & zig zag
Dec 16, 2010 | Singer Sewing Machines
Hello. I have a Singer Model 1411. I was going along, switched over to the zigzag stitch, and when I came back to the regular stitch, the machine thinks it's making a buttonhole instead.of a straight...
Well, I think you confused your machine. Go back to the zig zag and sew on a scrap piece of material. Stop sewing and carefully go back to regular stitching. Make sure your stitch length is correct and you have everything tightened up and the feed dog is raised. If this doesn't help, try doing a button hole stitch for a bit, stop sewing, go to zig zag, stitch a bit and go to the regular stitch and see if that works. If not, you may have to take it in to be reset. Good luck.
Nov 28, 2017 | Singer Sewing Machines
Only does zig zag stitches, no straight stitches,
make sure the pattern selector is set for straight stitch first. If it is set correct then the machine may be "stuck" is zig zag mode. May need to be de greased and then re lubricated.
Jul 26, 2009 | Necchi Sewing Machines
Singer 7422 Logo
89 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
