Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore water dispenser not working, side by side frig
The water dispenser stopped working, but ice dispenser works fine. I looked at the solenoids in back and the water lines. Water is going to and from the filter to the solinoid unit but even when both solinoids are unplugged the ice dispenser still works? What might be broken?
  • 2 more comments
  • Anonymous Aug 07, 2008
    I change water filler no water come out the dispenser I chesk water line they are ok
  • jbosch Sep 26, 2008
    Our Kenmore side-by-side water dispenser is not dispensing water, but the ice maker is working.
  • docrobs2 Oct 12, 2008
    Kenmore elite side-by-side. Ice dispenser works fine. Not a sound (ie. no clicks, hums, etc) when pressing the water dispenser lever.
  • thomas_yoxal Nov 25, 2008
    Here a hum when pressing in the water dispenser, but no water comes out.
No water come out of dispenser to glass
Posted on Aug 06, 2008
My kenmore refrigarator door water dispensor stopped working. when i place a glass in the dispensor i hear a click sound but no water comes out. Also the clicking sound causes the hose to the water connection to move/ jump. I assume that when the water dispensor arm is puished in, it opens a solenoid to allow the waterto flow into the glass
Posted on Aug 15, 2008
For my premium assistance plan, I'll tell you how "I fixed it"....
Posted on Aug 03, 2008
Whirlpool gold side by side ice maker not making ice... have replaced the ice maker... still not working, no water to unit... not frozen up... water dispenser is working fine
You have a dual solenoid water valve. Blue for the water and red for the ice-maker. It located in the rear lower part of the frig. The water solenoid needs replacing that will solve your problem. BB
Jan 21, 2010 | Refrigerators
Ice maker tray does not fill with water
replace the duel inlet water valve on the bottom back of frig.,one side has failed-mike
May 22, 2009 | Kenmore Refrigerators
Water not going into icemaker. Water dispenser works fine.
Check the water valve at the back of the fridge if present.
Even if you used blowdryer, ensure that linse are not frozen by performing a complete defrost.
Disconnect water lines from icemaker, and blow with compressor if the above did not work.
May 20, 2009 | Kenmore Refrigerators
Water dispenser not working on my Kenmore fridge
NO,YOUR RIGHT YOU NEED TO REPLACE THE WATER INLET VALVE ON THE LOWER BACK OF FRIG.-MIKE
Mar 01, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My ice maker has stopped making ice. I have Kitchenaid Architect II KSRS25FTBL.Water dispenser is working fine. Ice maker is turned on.
Could be the solenoid valve. It is usually located where the water line connects to the frig. The valve may have trash in it.
Feb 21, 2009 | KitchenAid Superba Architect KSCS25INSS...
The icemaker stop working on my Whirlpool side by side frig
If there are ice cubes setting in the icemake waiting to be dumped then the icemaker is bad. If the icemake is dry then the water valve is bad. You have one water valve with two solenoids. One works water in the door and the other sends water to the icemaker.
Dec 15, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser in the door is dispensing water very very slow.
check and see if the ice is fully formed or look hollow / if hollow then run you a new water line to frig / if cubes are full then replace water valve.
Nov 24, 2008 | Kenmore 53642 / 53644 Side by Side...
Water dispenser will not work when lever is pressed. we had an intermittent problem with it before it stopped working altogather.I was going to look at it but was afraid to pop off the trim on the outside...
This could be a bad water valve in the frig. This frig has a double water valves. One for the ice maker and one for the water dispenser. It should be in the lower back. Where the water line goes in. You can check this valve easily. Find the double water valve on the frig. Turn off water supply to frig first. Swap the plastic water lines going from the water valve into the frig. Turn water supply on. Then see if the water dispenser works. Sometimes you will have to operate the water dispenser for a little while to get the air out of the line. If it works now then the problem is in the water valve solenoid and needs to be replaced.
Nov 08, 2008 | Kenmore 53642 / 53644 Side by Side...
KENMORE ICE MAKER STOPPED WORKING
MAKE SURE THE ICEMAKER IS ON,ON OFF BUTTON OR LEVER IN DOWN POSITION,CHECK TUBE BEHIND ICE MAKER PULL IT OUT LOOK IN IT LOOK IN FREEZER HOLE TO MAKE SURE IT'S NOT FROZE UP,CHECK WATER INLET VALVE ON LOWER BACK OF FRIG.,LOOSEN CONNECTION TO SEE IF GETTING WATER,IF WATER IS COMING OUT IT IS A BAD WATER VALVE ONLY ONE SIDE TO WATER DISPENSER IS WORKING,VALVE IS NOT OPENIBG TO ICEMAKER SIDE,THANKS-MIKE
May 29, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
2,404 people viewed this question
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
Fred Sops
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
