Question about Kitchen Ranges
Wife and I bought a p b stratton bed. Four months later tempur-pedic was sagging. Flip matteress and there was mold, water. Mold was purple brown black yellow. Is this due to no ventilation in center of this design of bed. Heard it happens to all types of matteress.Futons. ETC.Also the three center pieces the tie bed together were warp and cracked. Them being only a 3/8' thick. Also the wood is painted with white laquer. I believe problem is no ventilation. Causing it to sweat.
  • 126 Answers
SOURCE: Black flakes, like mold in water dispenser
check your water reservoir lower part of refrig. section ( take out crispers)
Posted on Dec 14, 2007
SOURCE: tempur-pedic remote control does not
If the solution posted by Susan R. (below) fails to work, locate the black power down box under the bed. Check the battery compartment and remove all batteries. If batteries are installed they will prevent a full reset of the box. Unplug the power cord, wait 45 seconds and plug the power cord back in to reset the electronic components. Replace batteries. Now that the error has been wiped from the box's memory, you can now synchronize your remote with the power down box using Susan's instructions below. - Mike V., Antioch, CA
"Locate the power down box for the bed and press the "learn button" for 1 second and release (Black box under the bed). On the hand control, simultaneously press and hold the position 1 and off buttons. The transmission indicator light will flash slowly and then flash rapidly. Continue to hold for 5 seconds and then release the buttons. It should now work! Enjoy. Susan R., Paducah, KY"
For further assistance, refer to the user manual that came with your TEMPUR® Advanced Ergo System™ or you can download it here.
http://www.tempurpedic.com/media/Ergo_System_Complete_Ref_Guide_FINAL_022008.pdf
For phone assistance please contact a Leggett and Platt representative at 800-888-3078. Leggett and Platt is the manufacturer of the adjustable bed and remote components for Tempurpedic.
Posted on May 18, 2009
  • 32 Answers
SOURCE: How to connect a four wire pigtail
The white wire goes to the middle terminal post on the dryer.
The red and black wires go to the outside terminal posts.Doesn't matter which.
The green ground wire needs to be attached to the outside metal case...anywhere. The easiest way is to put the eyelet on the screw that attaches the terminal cover plate when you put it back on. Sandwich it between the screw head, the plate and the case.
Hope that helps. Let me know if you need more info
Best, G
Posted on Aug 03, 2010
  • 3567 Answers
SOURCE: Changing the regulator/rectifier (rr23) on
Give this company a call. I have heard very good things about them. http://www.oregonmotorcycleparts.com/Links.html
Click on the products tab.
Posted on Sep 04, 2010
SOURCE: Replacing right front dual ribbon
can't remember ware the wires go. Help!!!!
Posted on Jan 06, 2011
How do I lower the back of my chair
To lower the back, lift it until it stops firmly. Now let it fall all the way down. (It might need a little push to go all the way down.) To raise the back, lift it slowly until it clicks once. Each click is a height setting; it will stay at that height. Repeat until the back is high enough. To go back down, start over.
(This definitely applies to Tempur-Pedic TP4100 Office chair.)
Sep 09, 2014 | Tempur-Pedic TP4000 Ergonomic Fabric...
How to adjust the back of the chair?
To lower the back, <b>lift</b> it until it stops firmly. Now let it fall all the way down. (It might need a little push to go all the way down.) To raise the back, lift it slowly until it clicks once. Each click is a height setting; it will stay at that height. Repeat until the back is high enough. To go back down, start over.
Jul 01, 2014 | Tempur-Pedic TP4000 Ergonomic Fabric...
The bed is stuck with head up can I manually lower the bed
We have a Tempur-pedic. Each side is controlled by its own remote. It also has battery backup for each side (head and foot) in case the power goes out. We simply push a little button on the battery controlled box on whichever side needs lowered. It works to lower them, but they cannot be raised in a power outage. If you don't have something like that, or a manual crank or something, I suggest you call the company and ask THEM what to do. If it's stuck with the power still on, then even more reason to call the company.
Apr 23, 2014 | Ergomotion Furniture
What is the difference between Tempur-pedic mattresses and other brands of memory foam mattresses?
Tempur-pedic is a type of memory foam. They are a brand name distributer of memory foam products. They have reached a level of popularity now, which consumers refer to their product as a brand (similar to Kleenex).
Jul 25, 2012 | Furniture
Mold in water dispenser
I also found black colored mold in my kurieg, I was getting a respiratory infection every couple of months and couldn't figure out why. I stopped using the machine immediatley about 4 months ago and haven't had a respiratory infection since. What's scary is what is inside the water resevoir that you can't see.
Jul 15, 2010 | Keurig Elite B40 Coffee Maker
Kitchen Ranges Logo
54 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
