Question about Gladiator Freezerator Top Freezer Refrigerator
I have a freezerator and the thermostat that I have in the bottom freezer says the temp is 30 but items are not frozen.
  • 87 Answers
SOURCE: SZD27MW - Freezer Fan not working - temp runs 40 midway in freezer
Voltage is either 240V or 110V either way it is stamped on the fan motor. You have a sensor controlling the fan and heater which could have gone open circuit and on some cabinets they use the neutral through the heater to bring in the fan so you could have a heater gone. You can bypass the sensor but this should not be a long term solution as it is a safety mechanism. Hope this helps.
Posted on Aug 17, 2007
SOURCE: Freezer works great, as it should, but fridge is only keeping items room temp. I have the setting at the coldest setting: #7. What is wrong?
Here's what I did, I defrosted! I found out that the fridge temp is monitored and maintained by the freezer. Because we had a power outage one night, my freezer thawed while we all slept and then when power came back on, freezer re-froze but this cause an ice build up on the vent on the back wall of the freezer. Well, ice must have been in one (or more) vents, causing blocked air flow in my top half of the refrigerator. I turned the dial in the freezer to "off" which also shuts down power to the fridge half. I then unplugged the refrigerator, hauled all my food items into coolers, opened the freezer door and refrigerator doors and left them open for a little over six hours. I took advantage of this empty fridge and freezer and wiped everything down. After this time frame passed, I plugged the fridge back in, turned the freezer dial to my preferred freezer temp, and wah-lah! Within two hours I had a cold fridge and solid ice cubes in the freezer. I then put all my food items back into their appropriate compartments, and went to work. Bear in mind, a total 24-hour period is needed for the fridge to re-set itself, but still, after two hours the fridge was noticeably cold. Who knew, besides our parents' generation: DEFROST!
Posted on Sep 11, 2008
SOURCE: some items in freezer are not frozen: bread, cool whip, etc. Meat and veggies ARE frozen. any idea?
This is normal for these particular items. They don't "seem" to be frozen but they are fine. If everything else is frozen that should be, like, ice cream, ice cubes, frozen vegetables, then you don't have a problem. Do make sure your freezer is not building up ice anywhere and that the door is completely shut when you close it.
Posted on Jul 05, 2009
projdoc
  • 2236 Answers
SOURCE: 2000 Amana BX21Vl fridge: ice maker and freezer not working.
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of. after the freezer freezes again, your ice maker will work again.
Posted on Aug 28, 2009
heatman101
  • 43501 Answers
SOURCE: the bottom freezer portion of my gladiator freezerator forms ice
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on May 27, 2010
Why are frozen bread items and small cups of ice cream thawing in freezer and not other things?
Ice cream requires a min. temp of 28 deg. you're most likely at about 30 or 31.
  1. make sure your air flow vents are free of ice in the freezer.
  2. turn up your temp control
  3. pull out fridge and clean and vac the rear coils and the motor area. make sure to clean the fan blades
this should do it mike
Mar 25, 2016 | Maytag Refrigerators
Freezer will not freeze ice ceam
Before you go any further it is important that you check for freezer temps. Yes, you have frozen items but remember that water freezes at 32 degrees and many items will get hard at that temp. And also remember that the lower the temp the longer frozen items will keep.
But ice cream needs proper freezer temps close to zero degrees. Use a digital thermostat and check for your freezer temp - bet it it is no where near zero. I had the same problem and attributed it to the fact that I was not using a name brand ice cream!!!! I was wrong ! LOL.
Aug 31, 2015 | Refrigerators
Vegetables in crisper are frozen, as well as liquids in bottom 1/2 of fridge door. The fridge & freezer temp controls won't adjust to our settings. Also, we're getting ice, but no water will dispense.
The freezer cools the refrigerator, so you actually get very cold air passing from the freezer to the refrig. The air from the freezer enters the refrig on the top and falls to the bottom where it is drawn back into the freezer. The temperature of the refrig is regulated by a thermostat and a fan that runs when the thermostat calls for cooling. If the refrig thermostat is faulty and causes the fan to run more than it should, there will be a freezing problem in the refrig at the bottom because cold air falls and warm air rises. If the refrig is thermostat is calling for cooling constantly, this will take more cold air from the freezer than is normal. Your freezer temp might be higher than normal and the refrig will be colder then desired. If the fan from the freezer is running constantly I would suspect a bad refrig thermostat.
May 06, 2015 | Refrigerators
Westinghouse silhouette frost free fridge 522
I've been on fridges where this happened. I've found the thermostat to be the issue, or the temp sensor to be the issue. It's hard to check without being there with the proper equipment. It may be worth the money to contact a service tech. lmk if you need more help!
Aug 04, 2013 | Refrigerators
Freezer keeps beepimg
if the temp. in the refrigerator side is 20f, its to low, set the ref. to 40f and freezer to 0f.
Sep 23, 2012 | Liebherr CI1651 30" Built-in...
The freezer is not working properly. Measured temp at almost 40 deg. Have cleaned coils and vacumned fan grill. Some items are frozen, but newly added do not freeze.
Check for any frost on the inside, probably the back, of the freezer compartment. If there is any, either the defrost heater, defrost timer or defrost termination thermostat is bad. Need your model # to continue.
Mar 03, 2010 | Amana ATB1832AR Top Freezer Refrigerator
Bottom freezer not keeping ice cream frozen
Check out freezer temp - should be around zero degrees. Fact that ice maker is still working would indicate that the temps are at least about 10 degrees. If the door seals are tight and the self defrosting mechanism is working properly, the unit may be low on refrigerant. I had similar situation where stuff was frozen but my ice cream was mushy even though unit was running 24 hours a day.
Apr 18, 2017 | Amana BX21V
Freezer does not seem to keep things frozen in my refridgerator .
probable reason for this is that the thermostat controls freezer temp and freezer follows suit.
if temp in your garage is low ie in winter, then the fridge doesn't need to switch on and the freezer temp rises.
i know this sounds barmy but it is true
Nov 26, 2008 | Kenmore 44103 Side by Side Refrigerator
Gladiator Freezerator Top Freezer Refrigerator Logo
48 people viewed this question
Top Gladiator Refrigerators Experts
Brian Coughlan
Charlotte Sharp
Charlotte Sharp
Andy
Are you a Gladiator Refrigerator Expert? Answer questions, earn points and help others
