Question about Canon imageCLASS D760 All-In-One Laser Printer
When a copy its made the original white page gets many gray likes and theres no view of what it was copied just the lines and i replaced the toner catrige with a new one but still the same problem.
    Master:
  • 325 Answers
You need to replace the drum unit.
Posted on Mar 19, 2011
Toshiba DP 8070 has Service recommended for IQC
there is a rubber blade similar to the wipers on your car, that clean the drum. when there is an obstruction under the blade it does not clean that area around the drum leaving that line. i would say a technician needs to be contacted.
Mar 09, 2010 | Panasonic DP-8020E Black and White Copier
COPIES FROM PANASONIC FP7722 ARE JUST BLOTCHY GRAY
yep!
we can say it is common error/malfunction for these series of fp-77xx
it is also called as quarc error
you may fix it by manually adding some toner at the developing unit
or by pressing USER PRESET + 11 + 1 to perform manual add toner maybe up to 5x until you see some improvement.
Feb 15, 2010 | Panasonic FP-7735 Black and White Copier
Gray continuous streaks on lower half of copy using Canon IR 1600
I assume you had the issue before you changed the toner, If so the problem is either the fuser or the Laser.
Do this:
start a print job and after you hear the paper feed into the machine open the top cover to stop the machine. You want to stop the page before it gets to the fuser. May take a couple tries.
remove the toner cart.
the page should be under the cart with the image on it.
If the line is on the page the problem is image development(toner or laser).
If no lines the problem is likely the fusing assm.
May 28, 2009 | HP LaserJet 8100N Printer - Refurbished
Black lines on the right side of every copy
depending on what the lines look like it could be the charge roller or transfer roller.
A defect on the charge roll appears as black areas on the front of the test page, and as light gray areas on the test page.
A defect on the PC drum of the toner cartridge appears as white areas on a dark, full–coverage test print and as black areas on the "text only" test page.
I have also seen a line with a 'ridge' on the paper. This will appear almost like an embossed line. This was caused by the fuser roller being scored by debris.
Jan 12, 2009 | Dell 1710 Laser Printer
Error code F2-42
Are the lines horizontal or vertical? DO you get lines on B/W copies (black and white) also? If you try to copy a blank white page do you get the lines? Does the toner / lines wipe off after the copy comes out? If the toner wipes off after the copy comes out you have a problem in the fusing unit ( the hot area that fixes the image onto the page). If the lines are vertical then you have something inside the device that is dragging across the page as it goes through the device. If the lines are horizontal then you it could be the drum cleaning blade, the transport blade, or charge roller. The noise could be that one of the blades are bouncing. It could be that a gear is worn. Please give more info on the problem to better help.
Dec 31, 2008 | Sharp AR-BC260 Color Copier
Hello mine is really an FT3713
This sounds very scary...
Your Machine is very old..
What did you do last to the Copier to get it in this condition?
All you should have done is empty the Waste Toner bottle, and do SP83.
Oct 26, 2008 | Ricoh FT3713 Copier
HP Laser Jet 2840 Printer
If it's scan and copy only and not when you send a job from the computer your solution is easy to remedy. Try going into the menu located on the printer to info menu. Scroll down to conguration page and click the check button. When the printer prints, if the line is not on the page you simply have ink or white-out on the scan glass for the ADF (auto doc feeder).
To clean the ADF glass, lift the top lid to expose the glass. There are two peices, 1 large full size and one strip peice. If your getting the line when using the auto feeder (without lifting top) pay close attention to the strip of glass. When a document is auto-fed it moves the original past the strip of glass. A dot (pen mark or white-out) will appear as a line on your final copy.
Clean well with windex or similar glass cleaner. PUT THE CLEANER ON THE RAG THEN THE RAG TO THE GLASS. Don't spray the glass as it's easy to get it into cracks where to don't want it to fall on an electronic part or board below the glass edges. While you at it, clean all the glass.
Test by making a copy of a "BLANK" sheet of paper with one small line to give you postion clues. First by putting it on the glass. Clean everywhere on the large glass that shows a mark on the page (except the one you purposely put there). The mark will help you locate where to clean. (example - 1" below and 2" over from your intentional mark) It also helps you identify top of page from bottom.
Once that is done do the same thing using the original in the ADF. Simply measure in from the edge of the page on the copy and find the corresponding spot on the small strip of glass.
IF YOU SHOULD BE GETTING THE LINE IN ALL FUNCTIONS, PRINT, COPY MANUALLY, AND COPY WITH ADF. Check the toner cartridge, most likely black for damage on the cartidge drum. The cartridge drum can be quickly viewed by flipping the shutter open (the part with the HP logo and part number printed on it). If there is a line, replace the cartridge.
Hope that helps you. If so hit it with a FIXYA!
Thanks,
Aug 30, 2008 | HP LaserJet 2840 Printer
White line and very, very dirty copies
the nealy black copies sounds like the drum is going, try adjusting the exposure to light, if it comes out with the whole page the same way but just lighter than change drum. White line sounds like there is something on the coronas.
Jul 22, 2008 | Canon PC-940 Black and White Copier
Gray background, but copied text is visible
With toner being dropped I would take a close look at the cleaning unit next to the drum. Sometimes they become clogged or wear out. Inside the machine, can you see toner that has spilled or piled up? If so that is an indication of a faulty cleaning unit.
MM85
May 23, 2008 | Canon NP 7130 Black and White Copier
Canon imageCLASS D760 All-In-One Laser Printer Logo
32 people viewed this question
old marine
old marine
