Question about Fisher and Paykel IWL12 Top Load Washer
How to clean the filter in F&P Elba washing machine,the one under the machine?
My Elba washing machine, when reaches the rinse cycle, water is very loud, never before, but it never stops adding water. Water is draining fine but water does not stop to cycle to rinse.
The water inlet solenoid valve is being held open. Take off the hose and look in the opening to see if you can find anything. Otherwise replace that solenoid valve.
Sep 02, 2016 | Fisher Paykel Fisher & Paykel Elba 3.7 cu...
Elba washing maching wa65tm stops at rinse
have u got a rinse hold switched on.this is to keep clothes from getting creases it holds until someone tells it to complete cyle
Nov 20, 2015 | Fisher Paykel Fisher & Paykel Elba 3.7 cu...
Whenever the washing machine goes into spin cycle there is a screeching noise. Appears to be a ratchet under the plastic container that has a loose spring. How do you repair thiss?
you can take the back off and have a good look around in side and see what you fine try oiling the parts as well with a good wd 40 or something may help
Oct 12, 2014 | Fisher Paykel Fisher & Paykel Elba 3.7 cu...
Elba washing machine wont drain or spin
The pump filter is blocked ,so it wont empty,remove filter cap and clear out lint, coins etc.
Jan 03, 2014 | Fisher Paykel Fisher & Paykel Elba 3.7 cu...
Zanussi 1250 washing machine FLS 1383 W does not drain
Sump hose probably blocked. Tilt washer backwards so u can get under it. Pipe comes from bottom of tub too filter housing, squeeze it you will be able too feel if anything is stuck inside it, simply remove pipe at one end and remove blockage.refit pipe and test
Jun 20, 2013 | Zanussi Washing Machines
Error code 3
Error code 3
Your motor controller module is faulty.
Has a memory error & needs replacing.
Jan 26, 2013 | Fisher Paykel Fisher & Paykel Elba 3.7 cu...
MW512 Fisher & Paykel Washer Machine...Where is the lint filter located?
Fisher & Paykel machines don't have a lint filter.
Manual cleaning of agitator and s/steel bowl will make your washing cleaner.
Oct 12, 2012 | Fisher and Paykel Washing Machines
How do I adjust the clutch on an ELBA Model WA50T54W1 top loader washing machine ?
Hi.
Unfortunately the service documentation for Elba is not available. Although the machine has been built by F&P and although is similar to a Fisher & Paykel Smartdrive there are some small difference. The clutch system may be similar to the smartdrive. I have uploaded the service manuals for two smart drive models below, see if that can help. Check section about disassembly.
F&P top load smartdrive smI.zip
Regards.
Ginko
Sep 05, 2011 | Washing Machines
Fisher and Paykel IWL12 Top Load Washer Logo
547 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
