Question about Sony Televison & Video
My Mom's Sony model KVL-32L 4000 TV developed an unusual ptoblem two days ago. The lower fifth of the screen has a sharp edged bar across it. A dimmed picture comes through it but it also "reflects" some of the picture from above. I don't thnk this is a cable problem since her other TV's are working fine. I tried everything I could think of to resolve the problem but it won't go away.
  • 10,594 Answers
It is problem of LCD Panel (screen) as it is not any wrong setting/ button issue.
Some times t-con board replacement might solve this kind of picture problem but mostly lcd panel found bad.T-Con board is located on top center at rear side of screen under metal cover/ shield.
LCD Panel (screen) replacement would cost you approx new tv price.
Let me know if you have additional question.
Thanks.
Posted on Mar 19, 2011
White line across screen
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sony 46 KDL46EX523 LCD TV
Sharp TV Model 32L-S400B - Reprogram Channels
Download the user manual to your Sharp TV by this link. It will ahve all details. OK?
May 21, 2012 | Sharp 32L-S400 32" TV
Pink bar across top of tv screen
This could be from 2 things. 1 is the optical block is going bad or 2 you got a peice of dust blown in from the cooling fan and its blocking the color filter internally. If you are capable you can take the tv apart and blow compressed air into the color block and remove the dust. Hope this helps
May 25, 2009 | Sony KDF46E2000 46" Projection HDTV
TV TURNS OFF BY ITSELF
Sounds like the Startup Relay is dropping out, you will need to replace it.
Mar 28, 2009 | Sharp 32L-S400 32" TV
Sony Bravia KVL-V40A10 - pixelated lines top and bottom of screen
Are these lines visible regardless of what device (DVD player, cable box) you are watching?  If so, then yes, it appears the LCD panel is failing.  If you only see the lines watching one device, it could be the cable/wire or the device itself.  Now it can also be the related input jacks too so connect the device to another input to be sure.
Mar 24, 2009 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Blue line problem with Sony Grand WEGA KDF-55WF655 Rear Projection TV.
We had the free repair from SONY for the blue dots and splotches. It works great now but you need to hurry and contact them as the offer expires I believe in December.
Sep 25, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
TV Turns Off
Good day.
Yuor TV has an issue particularly in the power supply section with regards to the loose components. This issue can be best addressed by having your units' circuitry be resoldered before it could damage some parts.
Response is higly appreciated.
chris
Jan 11, 2008 | Sharp 32L-S400 32" TV
Sharp 32l
hi hope u didnt touch enything in there 30,000V is what you get.... after 3 days it will dissolves anyway you can replace it but you'll need your solder experience in hand you need to buy a new unit a good soldering iron and make them small round and neat good luck
Mar 27, 2006 | Sharp 32L-S400 32" TV
Televison & Video Logo
55 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
