Question about HEWLETT-PACKARD G72260US Notebook
I want to replace the LCD screen myself but I can't find any video that shows me how. All of them show laptops that screws on the front of the bezzle and mine doesn't. How do I get the bezzle off?
  • Monroe Bryant Mar 19, 2011
    Your instructions are wrong. There are NO screw covers on front or side of screen..Thanks but goodbye.
    Scholar:
  • 57 Answers
Here's how to remove a screen for a laptop with a front bezzle instead of just front screws:
1. Power down your laptop. Disconnect the power cable and any peripheral devices from the laptop. Close the LCD screen, flip the laptop over and remove the battery from the bottom casing of the laptop.
  • 2.Flip the laptop over, and then open the LCD screen all the way. Remove the rubber screw covers from the front LCD bezel. The screw covers will be located on the front of the panel, or along the side edges, depending on your laptop's make and model.
  • 3.Remove the retaining Phillips-head screws from the front LCD bezel. Insert a flat-head screwdriver into the gap along the outside edge of the LCD panel. Start to pry off the front bezel. Work your way around the entire LCD panel until the front bezel is separated from the panel.
  • 4. Remove the the bezel from the LCD panel and set it aside.
    Source: http://www.ehow.com/how_6759851_remove-bezel-laptop-screen.html
  • Posted on Mar 19, 2011
    Loose hinges how do I tighten them
    Watch the video it shows which screw hold the hinges to computer itself and to the screens back cover. HP DV7 LCD Screen Replacement
    Mar 09, 2015 | HP Pavilion dv7-1130us laptop
    How to replace a ccfl backlight bulb on presario cq60-419wm
    Whoa!
    Let's talk for a minute..........
    CCFL = Cold Cathode Fluorescent Lamp. (Bulb)
    Similar to Fluorescent lighting used in homes, and businesses; but on a MUCH smaller scale.
    Average thickness is 2mm. That is a little thicker than 1/16th of an Inch.
    Or about the width of this capital -> O <-
    Average length is almost as long, as the LCD screen is in height.
    Just like it's larger 'cousins', it has Mercury in it. A POISON.
    Point?
    They break VERY easily, and have Mercury inside.
    I usually suggest changing the LCD screen itself, to replace a Backlight.
    More expensive?
    YES
    If you are talking about price of LCD screen compared to a CCFL bulb.
    SAFER?
    YES
    There is NO price for a human life.
    Okay, moving on..................
    1) http://www.insidemylaptop.com/replace-lcd-screen-hp-g62-compaq-presario-cq62-laptop/
    2) http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
    3) Service Manual:
    HP Support > Compaq Presario CQ60-419wm Notebook PC >
    Manuals download page, (User Guides)
    http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=3966262&
    Scroll down, click on the blue -
    Compaq Presario CQ60 Notebook PC HP G60 Notebook PC - Maintenance and Service Guide
    [Ignore if you are aware;
    This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
    After you click on the above file name it may take up to 30 seconds, before the first page comes up.
    (The PDF file will not show until fully downloaded )
    Go to the top left corner, and click on the small square icon -
    Toggle Slider.
    Becomes two small square icons.
    Show Thumbnails on the left, Show Document Outline on the right.
    Click on Show Document Outline to see the Bookmarks menu.
    The Zoom In icon ( + ) at the Top, increases the view size when you click on it.
    The Zoom Our icon ( - ) decreases the view size.
    When I refer to a page number, it is for the Adobe Reader page number box at the Top. (To the right of the Down Arrow) ]
    The plastic frame in front of the LCD screen is the Display Bezel.
    I may be wrong, but I believe the Display Bezel can be removed, WITHOUT having to remove the entire Display Assembly from the laptop.
    Makes life a lot easier.
    There is a Philips head screw in the Bottom/Left corner, and a Philips head screw in the Bottom/Right corner, to remove from the Display Bezel.
    They are under Screw Covers. The Screw Covers are made of synthetic rubber, or plastic. They are held in place by a type of rubber cement.
    I take a computer pick, and gently pry up at the base of the Screw Cover.
    If you are careful you should be able to reuse the Screw Covers.
    If they do not stick anymore, apply a TINY dab of rubber cement to them, with a toothpick.
    The Display Bezel has TABS going around the exterior perimeter of it's inside edges.
    These snap into matching LATCHES on the Display Cover.
    There also may be some sticky tape, at the bottom/inside edge of the Display Bezel. Means CAREFULLY pry the bottom edge of the Display Bezel when removing.
    The best method, of removal of the Display Bezel that I have found, is to flex it.
    It is made of space-age plastic, and is pretty tough stuff.
    (Of course there are those, who could destroy a steel ball bearing with a rubber mallet, in a sandbox)
    I cut a piece of thick construction paper, to just fit the inside edges of the Display Bezel.
    Display Assembly laid as far back as possible, the thick piece of construction paper will stay in place.
    It is used to prevent scratching of the LCD screen, from your fingernails.
    Come to the Inside edge (LCD screen side), of the right/middle side of the Display Bezel. Sliding a fingertip of one hand under the bezel to lift up slightly.
    Can't get in? Move over a little. You are at a Tab/Latch.
    With one fingertip under the bezel, slide another fingertip under from your other hand. By now a Tab/Latch should have released.
    SNAP!
    Sounds like you're breaking something.
    Keeping the bezel slightly up, move along with the fingertips of one hand, and move towards the Top.
    Go along the Top popping Tabs/Latches loose.
    Then come down the Left side.
    As you reach the bottom ease up on one side a little, and wait for the tape to start releasing. Then ease along the bottom until all the tape releases, and the Display Bezel pops off.
    Once the Display Bezel is removed, then disconnect the small cable that comes from the Video Cable (Display Cable - HP), TO the screen Inverter board. (Left side of screen Inverter)
    (screen Inverter is mounted behind the Display Bezel, and at the bottom of the Screen Frame.
    The Screen Frame is the thin metal frame which surrounds the LCD screen assembly)
    [The LCD screen is an assembly of layers. The layers are held in the factory set position by the Screen Frame]
    Disconnect the small cable that goes TO the screen Inverter, on the Right side of the screen Inverter.
    Remove the screen Inverter, and lay aside.
    Remove the Philips head screw at EACH top corner. Holds the Screen Frame TO the Display Cover.
    Tilt the top of the LCD screen towards you, remove the clear adhesive tape over the Video Cable connector on the back of the LCD screen.
    (DO NOT remove the tape all the way. Just carefully peel it back far enough, so that you can get to the Video cable connector, at the back of the LCD screen. This way you should be able to reuse the tape)
    Disconnect the Video Cable (Display Cable) from the back of the LCD screen.
    Remove JUST the screws which hold the Hinge Brackets TO the Screen Frame.
    The Screen Frame can be taken apart. Of course you will need to do this, BUT ONLY after removing the LCD screen assembly.
    THREE screws on each side for the Hinge Brackets.
    (Display Panel Brackets)
    One towards the Top, two down towards the Bottom.
    Pages 64 through 80 in Service Manual.
    Page 66/ Bottom; shows the Screw Covers, and Screws to remove from Display Bezel.
    Page 68/ Bottom; shows disconnecting the screen Inverter.
    Page 69 shows screws to remove in order to remove LCD screen.
    (Display Panel)
    Page 69/ Bottom shows screws to remove for removing Hinge Brackets.
    Pages 128 through 133 - Recycling/Display: shows taking the Screen Frame apart, and accessing Backlight.
    For additional questions please post in a Comment.
    Regards,
    joecoolvette
    (WEAR gloves -> BE SAFE)
    Feb 25, 2013 | Computers & Internet
    Pink lines running across screen
    Sounds like your lcd screen is bad and needs to be replaced. Try connecting an external monitor to the laptop. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the laptop. If the Borrowed monitor displays ok without the lines, then your video card inside the computer is good but your lcd screen is bad. If the Borrowed monitor displays the same lines as your lcd screen then your video card inside the computer is bad.
    It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the video shows on the external monitor that proves your video card is ok, ,but your lcd screen is bad. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
    Jun 07, 2012 | Computers & Internet
    How to remove the screen from the y510
    The thin plastic 'frame' in the front of the LCD screen, is the Display Bezel.
    Goes by many names. Display Bezel is used by HP.
    Display Mask, LCD Bezel, LCD Panel Bezel, and LCD Front Bezel, are a few other examples.
    Lenovo/IBM uses LCD Front Bezel.
    Lenovo doesn't show an HMM for the IdeaPad's, other than for the S9e series, and S10e series, (Notebook), plus the A1-07 series. (Tablet)
    (Hardware Maintenance Manual)
    http://support.lenovo.com/en_US/SupportSearchResults.page?searchText=ideapad+hmm
    (An HMM is a Service Manual)
    I also see there are no guides posted by users.
    Therefore we'll have to 'wing it', using my years of experience with repairing laptops, and you as the tech.
    1) Do you see any screw covers on the LCD Front Bezel?
    May not be the usual synthetic rubber covers. May be plastic, and the same plastic, and color as the LCD Front Bezel.
    Example,
    http://www.insidemylaptop.com/replace-broken-lcd-screen-lenovo-x60s-laptop/
    Scroll down to the photos in Steps 1 and 2.
    Also note the 'seals' on the side of the Display Assembly, shown in Step 2 photo.
    We'll start with this.
    2) Haven't worked on a Y510, and perusing the internet; it seems no one has found a solution, for removing the LCD Front Bezel off of an IdeaPad Y510.
    { ALL power removed before beginning. Remove the AC adapter
    (Charger), and Battery }
    3)
    A) There is no sticky double-sided tape holding it on.
    B) Can't simply 'pop' it off, as with other Display Bezels, that do not use Philips head screws to hold it on.
    [ For all Display Bezels, (Other than this baby, perhaps), there are locking tabs on the outside edges of the Display Bezel.
    These match up to snap locks, on the inside edge of the Display Cover. (Top cover of laptop)
    When the Display Bezel is removed, the locks snap loose ]
    C) I suggest remove the screws which hold the Display Assembly to the laptop, and see if at the bottom of the Display Assembly, there are screw covers, or just screws, to remove.
    If there are, and no other screw covers/screws to remove, the LCD Front Bezel should pop off.
    This is what I mean by pop off,
    http://www.insidemylaptop.com/replace-screen-on-lenovo-g560-laptop/
    Step 2 and 3.
    { The laptop is made by Wistron. (Philippines) One of the three major laptop manufacturers, that makes laptops for ALL laptop brand manufacturers.
    Such as Acer, Compaq, HP, Lenovo, Toshiba, Asus, you name it }
    Post back in a Comment.
    Regards,
    joecoolvette
    May 06, 2012 | Lenovo IdeaPad Y510 Notebook
    No display on laptop
    Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
    Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
    If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
    Apr 29, 2012 | Computers & Internet
    How do you fix a white screen for a dell Inspiron 1100 lap top?
    White LCD screen in a Dell Inspiron 1100 Notebook PC?
    1) Loose connection of the video cable TO the LCD screen, and/or loose connection of the video cable TO the motherboard.
    2) Bad LCD screen
    3) Bad motherboard. (More specifically a bad graphics chipset)
    To start the diagnoses to find out what the problem is, you will require an external monitor.
    This monitor can be a CRT monitor (Looks like a small TV), or a flat LCD screen monitor that has a VGA cable.
    (A CRT monitor is a VGA monitor also)
    Example of a VGA cable, and a VGA port, (Connector on computer),
    http://en.wikipedia.org/wiki/VGA_connector
    The VGA port is on the back of an Inspiron 1100 Notebook PC.
    It is Blue in color.
    A) Laptop OFF, monitor OFF. Connect the VGA cable of the external monitor, to the laptop's VGA connector (Port)
    B) Turn the external monitor on. If a CRT style allow it warm up.
    Turn the laptop on.
    By default, (Factory setting), the external monitor should show the graphics of the laptop.
    IF Not;
    There are 3 options available,
    1) Internal monitor of the laptop - ONLY
    2) Internal monitor of the laptop, AND external monitor
    3) External monitor - ONLY
    If there is NO display on the external monitor, (Display; To include a white screen);
    A) Press the Fn key, and hold it down. Now tap the F8 key. (F8,CRT/LCD)
    Still no display on the external monitor? Press, and hold down on the Fn key, and tap the F8 key again.
    IF, the external monitor shows a white screen, Stop.
    You have a bad graphics chipset. Option is to replace the motherboard.
    IF, the external monitor shows graphics just fine, diagnose further.
    A) Look to see if the Video cable is plugged in tightly to the motherboard, AND connected tightly to the LCD screen.
    Dell Support > Inspiron 1100 Notebook PC > Service Manual,
    http://support.dell.com/support/edocs/systems/ins5100/en/sm/index.htm
    Click on - Display
    Under the heading - Display Assembly, look at the partial 'photo' under the number 8.
    On the left side where it shows two Philips head screws removed, is the Video Cable. Pinkish wire wrapped around a Light Blue wire.
    Look at Number 9.
    The display-feed flex cable is the Video Cable.
    Make sure it is plugged in tightly to the motherboard.
    Now go down to Number 10.
    In the exploded drawing the number 7 points to the Video Cable.
    (display-feed flex cable)
    Shows the Video Cable disconnected from the motherboard, and going up to the back of the LCD screen.
    Scroll down to the heading - Display Panel. This shows the connection of the Video Cable to the LCD screen.
    Also;
    The Video Cable runs through the left Hinge Cover.
    Repeated opening, and closing of the laptop, may have damaged the Video Cable.
    Observe the sheath of the Video Cable. (Outside wrap)
    Does it appear damaged? Pinched? Torn?
    Even if it does not, I suggest performing a continuity test with a multimeter.
    Multimeter's function knob is set to Ohm's. (Omega symbol)
    Positive probe lead (Red) is touched to one end of a wire going through the Video Cable.
    Negative probe lead (Black) is touched to the other end of the wire.
    Do not be concerned at this time with the Ohmage. Concern is to see if ANY reading comes up, not how much.
    Perform a continuity check on all wires in the Video Cable.
    (An economical, yet decent enough multimeter for this test, can be purchased for around $5 to $12. A multitude of store carry them. An auto parts store is but one example)
    Video cable checks out?
    The next suspect is the LCD screen.
    However, read on.
    Primer:
    An LCD screen does not produce enough light by itself. It needs an additional light source.
    A Backlight is the additional light source.
    A Backlight is a CCFL.
    Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
    An Inverter (Screen Inverter) is used to convert the power (Electricity) from the laptop, for the LCD screen, and Inverter.
    90 PERCENT OF THE TIME the fault is the Inverter.
    Example of a screen inverter for a Dell Inspiron 1100 Notebook PC,
    http://www.nylaptopparts.com/index.php?main_page=product_info&cPath=91_95_125&products_id=547
    An expensive (Read - Sensitive) multimeter can be used to check a screen inverter. Not something everyone has laying around, or access to. In this case I would suggest replacing the Inverter.
    (The screen Inverter is also easily accessed, AND much cheaper in comparison, than the LCD screen. Again, 90 percent of the time the fault is the Inverter )
    IF, the Inverter does not cure the problem, then the problem is the LCD screen.
    Review;
    Check the display with an external monitor. Display checks good, run a continuity check on the Video Cable.
    Video Cable checks out OK, go to the Inverter.
    Inverter does not cure the problem, the problem is the LCD screen.
    BEFORE beginning to disassemble;
    Remove ALL power to the laptop. Remove the AC adapter (Charger), and Battery.
    Observe Anti-Static Precautions.
    (I would also advise using an ESD wrist strap, and connect it's alligator clip to a good ground source.
    Average cost of a decent ESD wrist strap, is around $3 to $6.
    I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case.
    {Electro Static Discharge)
    Use a multi-compartment container for the various screws you will remove.
    label each compartment for the area the screw/s come out of.
    If no multi-compartment container is available, substitute with a clean egg carton.
    Label each egg holder.
    SOME screws look VERY similar to other screws.
    Do Not mix them up.
    For additional questions, or to have me explain anything I have stated here, post in a Comment.
    Regards,
    joecoolvette
    Dec 29, 2011 | Dell Computers & Internet
    Good Morning. I wonder if anyone could help me solve my problem I have a Accer Aspire 5535 and its around 2yrs old on windows Vista. The screen stopped lighting up and then on Random days it would...
    This could be one of two things, it is either the inverter (this generates high voltage to run the back light) or it could be the back light itself.
    As you have suggested, it could just be a loose wire or cable.
    Replacing the inverter is relatively straightforward as it is located at the bottom edge of the LCD screen behind the plastic case. The backlight is usually part of the LCD screen and you would usually be better replacing the screen entirely.
    To get at either of these components to check cables/wires etc, you will need to disassemble the screen case of the laptop, this is fairly simple if you are comfortable with disassmbling laptops.
    A brief overview of the screen replacement process is below, instructions 1-4 show how to remove the case to access the inverter and cables:
    1. Power off your laptop. Turn the laptop upside down so that you can see the bottom side of the laptop's case.
    2. Depress the battery release latch and lift the battery and laptop ac adapter out of the laptop. Flip the computer back over and open up the LCD screen to a 90 degree angle.
    3. Pull off each of the rubber buttons located along the edges of the Acer Aspire 5535 Screen. Remove each of the screws underneath the buttons with the Phillips-head screwdriver, remove keyboard.
    4. Insert your fingers underneath the cover of the Acer Aspire 5535 Screen. Work your fingers around the edges of the cover to unlock it from the screen. Pull the cover off the screen and set it aside.
    5. Locate the inverter board at the bottom edge of the Acer laptop screen . Disconnect the cables at the right and left end of the board that connect to the Acer Aspire 5535 Screen. Remove the screw holding the inverter board in place and then lift the board off the LCD screen.
    6. Tilt the screen slightly towards you until you can see the strip of tape holding the video cable. Pull off the tape and then disconnect the video cable from the laptop case.
    7. Remove the Acer Aspire 5535 LCD screen from the case. Set the new screen onto the case and reattach the video cable and tape strip. Position the replacement inverter board at the bottom of the screen and attach the screw.
    8. Reconnect the inverter board's cables. Pop the plastic cover onto the Acer Aspire 5535 LCD screen and reconnect the screws. Set the rubber buttons over the screws. Reconnect the battery.
    9. Turn on the laptop. Wait for the manufacturer's logo to appear on the screen to ensure the display was replaced properly.
    Apr 13, 2011 | Computers & Internet
    How do I replace the video card in a Sony PCG-GRT270 Laptop ?
    You cannot replace the video card on a laptop, they are built-in on the motherboard.
    Dec 09, 2010 | Computers & Internet
    I need to replace the LCD screen on my Toshiba Satellite P305D-S8828. Can you provide step by step guide with photos or a video?
    Replacing LCD is not a big deal. Just follow these steps:-
    1. Unplug your laptop and remove the battery pack.
    2. Locate the rubber screw covers around your laptop screen. There are typically four, but some models may have more.
    3. Remove the screw covers. Take care not to lose any. They pop off.
    4. Place your fingers between the front bezel (the plastic piece around the LCD screen) and the screen. Gently work your way around the screen to remove the front bezel and expose the screen assembly.
    5. Remove the inverter from the screen assembly. It is held on by tape in most models. To disassemble the screen, you will need to either unscrew the screen from its metal holder, or just lift the screen out.
    6. Disconnect the wires. One wire goes to the backlight, while the other goes to the video card.
    7.Use exact serial no. LCD for exact replacement.
    8. Connect the video wire and the backlight wireand affix it using the tape that held the original in place.
    9. Put the screen back in place if you need to, and snap the front bezel back on.
    10. Screw the front bezel screws back in, and place the screw covers back in place.
    Hope they work for you. All the best
    Dec 09, 2010 | Toshiba Satellite P305D-S8828 Notebook PC
    Have Presario M2000 need new scrren
    Thats a little old to be putting $100 in for a new screen. Anyway on the bottom of that laptop u will see holes marked with a K those all need be removed there are two in the battery compartment and the screws under the rubber stops on the lcd screen bezel. There should be a video on utube to show you the rest but the keyboard top power bezel and lcd bezel have to be removed to replace the screen. The screens are pretty basic as for removal once you know where the screws are. Look for a donor latop on ebay to save money.
    Mar 28, 2010 | Compaq Presario M2000 Notebook
    HEWLETT-PACKARD G72260US Notebook Logo
    173 people viewed this question
    Top HEWLETT-PACKARD Computers & Internet Experts
    Marvin
    Marvin
    john smith
    Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
