Question about Philips 42PF9630A 42 in. Plasma Television
No picture ive just bought xbox 360 hd av cable and not getting any picture
  • 52 Answers
With the x box 360 it defaults to 1080p and this model does not support that resolution. connect xbox with composite cables and go into x box menu and lower resolution to 1080i and source tv back to original connection and should have picture
Posted on Aug 14, 2008
I have just bought an xbox 360 conected it to my tv allcables connected picture great but no sound
Hi Douglas
I imagine you have bought the new slim Xbox 360? Did you use a HDMI cable to connect it to your TV or did you use the standard cable? If you used a standard AV cable ensure that you connected the red and white cables into the same AV input as the yellow video cable.
Mar 05, 2011 | Microsoft Xbox 360 Console
My xbox 360 elite does not show picture
This problem is most probably due to the AV / HD lead that you are currently using, Try unplugging the cable and blowing it to get rid of any built up dust. If that fails replace your AV / HD lead you are using.
Any further questions feel free to ask.
Nov 22, 2010 | Microsoft Xbox 360 Console
Can I use my HP2009v computer screen with the X-Box 360 Elite
In order to make this work you need the Xbox 360 VGA HD AV cable.
Following link will give you an image of the cable itself:
Unfortunately you wont be able to get the highest resolution with the cable.
Here you have a list of supported resolutions:
Nov 20, 2009 | Microsoft Xbox 360 Elite Console
Picture will not show
You might want to try the following:
1. make sure that the AV cable is not loose or incorrectly seated in both the Xbox 360 console and the TV
2. make sure that you have the correct AV cable for your TV, to verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, disconnect the AV cable and then reconnect the AV cable to both devices
3. if you are using composite cables, do not try to set any HDTV settings because you may lose the picture
4. make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
- if your Xbox 360 console is an NTSC console, make sure that your TV supports NTSC
- if your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- if your TV has a type of picture compensation enabled, disable it
5. reset your Xbox 360 console
- Remove any discs from the disc tray
- Turn off the console
- Turn on the console
- As the console starts, press and hold the Y button, and then pull the right trigger at the same time
- The Xbox Dashboard resets the display settings to the default settings and then automatically restarts the console.
6. Do not take your Xbox 360 console or its accessories to your retailer for repair or for service unless an Xbox Customer Support representative asks you to do this
Mar 09, 2009 | Microsoft Xbox 360 Console
New XBOX 360 no picture / sound
ok your lucky, you just need to by a new av cable.. or if that dosnt work you need to get the av caple connection fixed (only about $25)
thanks, Domo
Dec 23, 2008 | Microsoft Xbox 360 Console
Just bought xbox 360 to play on my hd ready 32"samsung tv,the console came up with message thatgames need to be played at 60 pal,so i changed it from 50 to 60 and now the picture(mostly the writing)is...
ive the oposit problem i want to play hitman which is 50hz game but im using a hdmi cable and it isnt possible to run it in 50hz , 60hz only i think so if you get the new hdmi cables it should fix your problem (if you have a hdmi port you should be using it anyway for the best picture)
Dec 14, 2008 | Microsoft Xbox 360 Console
Sound but no picture
On some av cables for the Xbox 360 there is a switch on the cable itself where it plugs into the Xbox that must be in the correct position. I hope this helps you.
Nov 15, 2008 | Microsoft Xbox 360 Console
Un recognisable picture
try a different set of av cables and or input on the tv and see what u get
Jun 21, 2008 | Microsoft Xbox 360 Console
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
Xbox 360 Elite compatible with 62' Mitsubishi HDTV?
I have it and it works great! For all TVs, the TV have to be on fixed settings on standard, dot-by-dot mapping, noise reduction off. The camera's exposure the same for both side-by-side shots. Just set it on standard and it should work...
Jun 05, 2007 | Microsoft Xbox 360 Console
Philips 42PF9630A 42 in. Plasma Television Logo
158 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
