Question about Kenneth Cole KC1104 Wrist Watch
Need a crystal and stem for my KC1512 S301-09 quartz
Where do you look for release of. The Stem if there is no small screw
There is a couple of different methods to release the stem,
1. By a screw, note if a screw only 1.5 turns only
2. push button near the stem, push button in and release the stem
3. pull the stem out and a little lever will be seen by the stem, press that and the stem will come out
4. if quartz, will have a hole with a small arrow pointing to it, with a needle insert into the hole to press the lever inside.
Otherwise need more information on the type of watch movement
Nov 29, 2017 | The Watches
If the stem does not lock in, will it still be waterproof?
You need to get out your jeweler's loupe (best at 5x & 10x)... and look for the threads to "*****" (ski-rue) down your winder-stem (not a lock).
(Features a Ski-rue down crown & back case)
YOU can pretty much be assured that if the "stem" collar is malfunctioning (broken) the "water-proof" element is compromised (that's most likely the least of your troubles).
More importantly... if the STEM does not properly "tighten" it can
cause further damage against gears which MUST align with it... further it can come all the way out and be lost... Not an inexpensive part.
Best direction would be to get it serviced by an authorized agent.
TAG Heuer Aquaracer 500M Quartz Mens Watch WAJ1110 BA0870
TAG Heuer Aquaracer WAJ1110 BA0870
Jaxa style Suissetek XL Wrench Case Opener for Large Screwback Watches
Mar 30, 2016 | Tag Heuer Aquaracer Quartz WAJ1110.BA0871...
How do I start a new quartz watch?
pull out stem and push in stem
Mar 28, 2015 | Watches
The winding knob does not lock when I press and turn
That means you need a new stem. Stem problems are fairly common on Quartz Tag Heuer watches. Should not cost you more than $100.
Nov 10, 2013 | Tag Heuer WAF2110.BA0806 Aquaracer...
I have a FOSSIL mens wristwatch model # AM3423. I recently had a watch repair person replace the battery. Battery type and charge confirmed. I received the watch used as a gift from a relative who was...
Quartz watches stop working most often for one of three reasons: (1) dead battery; (2) dirt in the gears blocking the train; and (3) a bad crystal. This is the order in which I typically troubleshoot watches.
If the watch isn't working after you change the battery, first check to see that the stem is fully pushed in. A watch movement can shift just enough inside the case that a stem sometimes looks pushed in, but isn't quite in far enough to re-engage the movement. Pull out and push in the stem a few times to see if that changes anything.
Next, assuming that the battery is indeed fine, look closely at the second hand. Is it moving at all, even a tiny bit? Hold the watch up to your ear. Is there any kind of "chunk" sound about once every second? If you can answer "yes" to either of these questions, a speck of dirt has gotten into the movement and is preventing the gears from moving freely. It doesn't take more than a a big spec of dust to cause this. Sometimes, advancing the time will move the gears enough to cause the dirt to fall out. Some watch repair places also have a special machine that spins the hands rapidly to blow out or compact any dirt in the train. It's usually not economically rational to have the movement professionally cleaned beyond this point.
Finally, if you don't hear anything coming from your watch, the battery is good, and the setting stem is pushed firmly and completely into the watch movement, you may have a bad quartz timing crystal. It does happen, and when it does, the only repair is to replace the entire watch movement. Sometimes, that's affordable; sometimes, it just doesn't make sense.
Sep 20, 2012 | Fossil AM3424 Wrist Watch
My watch keeps stoping but my battery is new
If your watch keeps time for a while, then stops and starts erratically, you most likely have one of several common problems.
1. You might have a bad battery. Sounds silly, but watch batteries have a limited shelf life, and if you installed a battery that's already been in a blister pack for a few years, the battery itself could be the problem.
2. Your "set stem" is not completely pushed in. Quartz watches are designed to stop ticking when the set stem is pulled out. They'll start up again when you push the stem completely in. There's a little finger or spring-loaded prong to keep the stem in or out. Sometimes, that little prong can break off from natural use. When that happens, the stem will work itself out enough to stop the watch from ticking. Natural movement on your hand will push it back in, and the movement will take off again. Check to see that you feel a firm "click" when you push the stem all the way in. Sometimes, when changing a battery, the movement will shift inside the case just enough that the stem doesn't quite catch in the locked, "full-in" position.
3. Your battery has a bad connection. Make sure that the positive and negative terminals of the battery are in good contact with the appropriate surfaces. I have used a tiny piece of aluminum foil at times to increase pressure on the watch battery so that it makes better contact.
4. Your watch movement has dirt in it that is jamming the gears. Modern quartz watches are amazing devices--a tiny amount of force from the pulse motor operates an intricate gear system that moves all the watch hands and day/date wheels. Even a tiny speck of dust in the wrong place on a gear can gum up the works and cause a watch to start and stop. Usually this will happen at set time intervals or at the same time every day, because that's when a particular gear tooth comes into play.
Closely related to this is an actual bent or broken gear tooth. Same symptoms.
A watchmaker can test the gear train by placing your watch in a special testing machine that spins the gears much faster than usual. If the watch hangs up from time to time, it's suggestive of problems in the gear train. Sadly, fixing the problem by cleaning the watch may cost more than replacing the entire watch.
These are the most common causes for this behavior. Hands that rub up against one another, or a defective quartz crystal are two other potential causes, but this should serve as a fairly good checklist for obvious problems.
Mar 09, 2012 | Watches
The hands have come off my fossil FS3087 wrist watch. I would like to know how to take off the glass in order to fix it myself. Thank you
mcdevito75 here, In most cases the glass (crystal) come off or out thru the back of the watch which means you"ll have to remove the quartz mechanism, and that means removeing the stem, thse quartz stems are very prone to breaking while being removed form the quatrz mechanism and the cost of a repair may be more expensive then a whole new watch, shop around get a price from a small watch repair shop on repair verses a new Fossil watch.
Feb 09, 2011 | Fossil FS3087 Wrist Watch
New quartz analogue watch losing 5 minutes a day.
not often so . beleive you me from an avid fine watch collector . it's the batteries. hopt this helps.
Jan 24, 2010 | Timex 27191 Wristwatch
Removing the watch stem
Hi, it depends on the watch . Look carefully ,if there is a release button , somethin you can press on or lift up. Sometimes a needle is enough to do the job. On some quartz movements (the cheap ones) you just can't remove the stem ...
hope this will be helpfull!
K.
Apr 09, 2008 | Watches
Kenneth Cole KC1104 Wrist Watch Logo
94 people viewed this question
Top Kenneth Cole Watches Experts
Ansel Alberto
Ansel Alberto
Robby Otts
Robby Otts
Level 1 Expert
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
