Question about Arris SURFboard SBG900 (49402201900) Modem
Trying to apply network key - Arris SURFboard SBG900 (49402201900) Modem
    Scholar:
  • 155 Answers
You need your PC connected to the Router via cable, then open Internet Explorer.
In the Address bar type 192.160.100.1 and press enter, for login enter admin and for password enter motorola, now you should see a Motorola window with all the settings.
On the left side select Wireless, a different window will appear.
In the Security Mode field, select WPA and click Apply.
Skip the portion about WEP and go below.
Under WPA CONFIGURATION, for WPA Encryption choose TKIP and for WPA Authentication choose Local (WPA-PSK)
Under Local there is WPA Passphrase, here enter your desired password; try not to forget the password in the future or you have to repeat the steps above, also try to use a combination of letter and numbers.
Click on save changes and you have finish, now you can close explorer.
Please let me know if you need additional help.
regards
Posted on Mar 19, 2011
Netgear network security
LOST WIFI SECURITY KEY WORD
If you have lost your WEP/WAP wifi key phrase there is no way to recover it except go into the router administration settings and see if it is in plain text there. If not then you will have to make up a new key phase and apply it to ALL your connected devices.
In future, write the key phrase down on a piece of tape and apply it to the bottom of your router. You can use a hint instead of the actual phrase.
I use the memo function of my cell phone to keep all my passwords and keys.
Apr 06, 2014 | NetGear WG111V2 Wireless Adapter
Tip
To Change the Security key or the Network key in your Belkin Wireless Router?
Hi Friends,
Please follow the default steps for all the belkin wireless routers to change the Security key or the Network Key in the wireless network
Step 1:Connect the Modem to Router (in the Port named Modem) and take another ethernet cable abd connect one end to the Router(in the port named Wired) and other end to any one of your computer
Step 2:Open an internet explorer and type 192.168.2.1 and click on Enter button in the keyboard
Step 3:Now you will be able to see the belkin router setup page
Step 4:On your left hand side click on Security,it will prompt for a login password,leave it blank and click on Submit.
Step 5:Now change the Security type to either WEP or WPA
WEP:
If You select WEP (64-bit), then you will be able to see 5 small boxes ,in each box in key 1,type 2 numbers in each box only in Key 1,after you have typed the number please make a note of it and click on Apply Changes
WPA:
If you select WPA,then you will be able to see the Preshared Key or Password (PSK),in this place type as thing as you wish,after you have typed please make a note of it and click on Apply changes
Step 6:On your left hand side click on Channel and SSID,now you will be able to see the SSID name,Change it any name as you wish and click on Apply Changes
Step 7:Now go to the wireless Computers and try to connect to the new network name,when you try to connect ,it will prompt for a Network key or Security key,type the password which you gave in the belkin router page
The above mentioned steps are the default steps in all the queries if any customer need to change the security or the Name of your network,you can follow the above steps.It very simple and easy to understand
Regards,
Ayyasam
on Mar 17, 2010 | Computers & Internet
My console wont apply an update for xbox live ive gone through network settings and tested the connection but it says connected then doesnt apply the update? Any halp would be appreciated thanks.
Here's how I fixed mine. When I got the message stating that the download was unsuccessful I went into settings, then network, and I tested my network connection. During a network test it automatically logs your profile out, but when the test came back good, before it logged my profile back in, it asked me to update again. I hit "a" to accept the update and it worked this time. I think the key is that it has to attempt the update before logging your profile back in. I think the key is updating with the profile logged out, which under normal circumstances you can't do, only during a network test.
If that fix doesn't work you might try going into your network settings in the dashboard and lowering your firewall restrictions, then updating, then putting your firewall restrictions back to what they were.
Nov 01, 2010 | Microsoft XBOX 360 ARCADE Console
I am trying to access a netbook from school and i need my network key for belkin.3cFE. how do I find it??
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Oct 26, 2010 | Belkin (F5D7230-4) Router (587009)
Gigaset 567 wireless router. unable to connect from desk top to laptop
try to disable the antivirus software and try to connect again, if this doesnt work try to go to safe mode w/ networking
to go to safemode w/ networking you can try this options:
when using windows XP, Vista and Windows 7. try to restart the computer as soon as the computer turns on immediately strike F8 key continuously, in advance menu option or advance boot option use the arrow key to highlight safemode w/ netwokring and hit enter ( if you see you operating system just hit enter again )
or try this one:
for windows XP,
click start
click run, type in msconfig
in msconfig click the tab for Boot.ini click safeboot at the bottom and choose network, hit enter
click apply and ok
for windows vista and windows 7
click start button or the pearl
type in msconfig in the start search and hit enter
click the Boot tab
click the safeboot and choose networking
click apply and ok
i hope this helps
Pls rate my resolution thanks!!
Mar 04, 2010 | Siemens Computers & Internet
Okay so mine has found my network, but it can't connect and I know my network is wireless, because I used my psp and wii with it.
its due to high level security on your router. change your wireless security settings to WEP 64-bit encryption and in key 1 type any 10 didgit number and clikc apply and then try to connect
Feb 26, 2010 | Microsoft Wireless Network Adapter Xbox...
Wireless doesn't work
Hi Friend,
Kindly check the below given instructions,
To access the WIRELESS (WLAN) settings window, click on the Wireless Setup button in the SETUP directory.
WIRELESS NETWORK SETTINGS
1.Click on the Enable Wireless box to allow the router to operate in the
wireless environment.
2.The SSID identifies members of the Service Set. Accept the default
name or change it to something else. If the default SSID is changed, all
other devices on the wireless network must also use the same SSID.
3.Enable Auto Channel Scan so that the router can select the best
possible channel for your wireless network to operate on.
4.The Wireless Channel can let you select the channel of your access
point. Channel availability is different for different countries due to their
regulation.
5.Select 802.11 Mode to operate in b/g/n mode. Or select specified mode
to use.
6.Channel Width, Maximum rate for 20 MHz is 130 Mbps. Maximum rate
for 40 MHz is 270 Mbps.
7.Transmission Rate, suggest keeping the Best (automatic) selection.
8.Click on the Hide Wireless Network box to allow the router to stop broadcasting its SSID.
WIRELESS SECURITY WIZARD
1.Click on the Security My Wireless Network button to enter the
2.SECURE MY WIRELESS NETWORK window.
1.Input the SSID.
2.Select the Wireless Channel.
3.Select the Encryption type. WPA-PSK is more secure than WEP 64 bit.
4.Click on the Apply Settings button to apply the settings
WIRELESS SECURITY MODE - WEP
1.WEP (Wireless Encryption Protocol) encryption can be enabled for
security and privacy. WEP encrypts the data portion of each frame
transmitted from the wireless adapter using one of the predefined keys.
2.The router offers 64 or 128 bit encryption with four keys available.
Select WEP Key Length from the drop-down menu. (128 bit is stronger
than 64 bit)
3.Specify the encryption key from the Current Network Key drop-down
menu.
4.Enter the key into the WEP Key field 1~4. (Key length is outlined at the
bottom of the window.)
5.Select Authentication type from the drop-down menu. (Shared is
better than Open)
6.Click on the Apply Settings button to apply settings.
Check and revert back
Regards,
Ayyasam
May 30, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Need help setting up a secure network.
Go to 192.168.0.1 in your browser, log into the setup page of the router. Under wireless set the SSID(network name), click apply, then go to security and set the encryption key, Click apply and log out. Then on your computer, if it is wireless, click on the wireless network icon, the when it shows your network, click connect . Then you have to put your encryption key in twice.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 11, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Problem securing belkin wireless g plus router
you must enter the WEP key because if type in the pass-phrase it won't connect(don't know why)
Jul 02, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Setup security
To set up a network key (password to access the network), follow these steps:
Open your browser and go to 192.168.0.1
Depending on your router's model number, the username/password combination will be different. Try admin/(blank), admin/admin, or user/(blank), where (blank) is not putting in a password at all.
If you look through the tabs and option pages, you will see a section for WEP or Network Key. A 64-bit WEP key is enough, you do not need a 128-WEP or a WPA key.
Make sure you apply the settings before closing the page.
May 01, 2008 | Computers & Internet
Arris SURFboard SBG900 (49402201900) Modem Logo
376 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
jimmy Leo
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
