SOURCE: Whirlpool Washer Model LSL9244EQO
shut off water remove rear hoses pull screen from inside opening and clean ..BE SURE TO REINSTALL SCREENS..if still slow or stopped altogether replace fill valve..remove rear screws in console lift and roll console back unplug lid switch pop the clips on each corner up and off cabinet will lift off valve is top right side
SOURCE: my whirlpool washer model LSL9244EQO will not turn on
first lets check power at wall is it good?
then i would check the lid switch they are a common problem and if bad will not allow unit to start... if you are not hearing anything at all and you have power then it is going to be most likely either the lid switch or the timer itself.the lidswitch can be jumped out and tested or if you have a meter it should be a closed circuit when shut and open when lid up/...good luck to you
