Question about Invacare Pronto M51 Power Wheelchair
I was riding in the rain and now my Invacare power wheelchair isn't working properly. Is there a way to reset it, dry it out, or get it working properly again?
  • 692 Answers
Sorry the joystick doesn't like rain or coffee or wet conditions and you will have to have it replaced. Next time carry a wally world bag with you and put it over the joystick to keep the moisture out. you can still steer and use the buttons through the bag Hope this helps
Posted on Mar 20, 2011
Can you order footrest parts some where?
Your best option to get this specificinformation is properly fro INVACARE
For more information, call them:
01656 776263
Also, look up this website
Invacare Special Adaptations
Sep 13, 2015 | Electric Mobility Invacare Pronto M41...
Looking for reset button oN TDX SD power wheel chair
Hello, Invacare does not have Reset Buttons on the power for the batteries. They only use fuses. Now if the joystick has a display and it says to press a reset button and it did not used to say that then the programming has be lost or changed by the rain or battery power. You will need to have someone with an Invacare Programmer reprogram the chair or a reset switch can be purchased that will plug into the joystick and allow you to get pass the Press Reset command on the joystick.
Jun 14, 2015 | Drive Health & Beauty
Reset button on pronto m51
There is no reset button on a M51 chair. Invacare puts fuses in the battery harnesses. The manual may say there is a reset but trust me there is not.
May 20, 2014 | Invacare Pronto M51 Power Wheelchair
I have a pronto m51 wheel chair got the joy stick wet it flashes 7 times how can i fixs it
Here's your M51 manual:
http://www.invacare.com/doc_files/1125085J.pdf
Trouble codes start at p25.
Also, Invacare is proud of the M51's wet-weather performance (check the "Rain Test" chapter in the manual. You might have a warranty issue. Check with an Invacare dealer.
May 06, 2014 | Jet 3 Ultra Power Chair
Will only work at a slow speed speed con worked fine the next day dead slow is al it will do
have a dealer tech check it with a programer and he will tell u what the problem is by checking the error log could be just a joy stick needs to be reset or the control box in the rear,make sure your insurance will help with repair
Aug 31, 2013 | Invacare Supply Group Invacare Pronto M51...
On/off button not working properly hard to turn off
glenda the switch has a metallic coating under it that makes contact with the circuit board If this coating gets worn then the switch will be hard to turn on -off. Carefully peel back the faceplate cover until you can see the bottom of the on/off switch glue a small piece of foil to the bottom of the switch and support the cover until it dries then carefully stick it back to the joystick Should work like new Hope this helps
Jan 28, 2011 | Invacare Pronto M51 Power Wheelchair
Manual for Pronto M51 wheelchair
Hi. We can supply, but try your local Invacare dealer. If you have luck, send us an email,
scooterworks@xnet.co.nz
May 18, 2010 | Invacare Supply Group Invacare Pronto M51...
Where is the reset button on a invacare m51
The controller puts out fault codes though the LEDs. Count them and then look in the operators manual for likely causes. In my experience it is the electronic brakes that fail on these units and they are costly.
Oct 04, 2009 | Invacare Pronto M51 Power Wheelchair
Pronto 91 fully charged batt but only gey 3 flashes off red light
Batters won't hold charge and work properly it sat up for that long. replace batterys
Aug 27, 2009 | Invacare Supply Group Invacare Pronto M91...
Invacare Pronto M51 Power Wheelchair Logo
170 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
gnshome
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
