Question about Equator 20 in. CD 400 Compact Dishwasher
Looking for a manual for a In Sink Erator Classic 400 Dishwasher
Our super old insinkerator is spewing out water and gross dirt junk! What do I do?
It has to be clogged, try putting some Very hot water down the insinkerator. Remember if you have a dishwasher, it also usually uses the insikerator to drain. The Ice wont hurt the unit... so try both.
Jun 19, 2014 | In-Sink-Erator 1019E InSinkerator Batch...
Wont turn of
serial number StoryBoard Quick 6.0
Sep 04, 2013 | In-Sink-Erator 1019E InSinkerator Batch...
Why is my badger .5 plus in sink erator leaking
One of your connections is either broken or missing a rubber gasket or a hose clamp. You have a lock ring on the top that basically bolts to the drain of the sink which is part of the disposal, IT has a rubber gasket or two on it, some have plumbers putty on the very top, the hose that goes from the dishwasher, if you have one, has a hose clamp on it, the drain line into the trap is a compression fit, needs to be tight, and it is usually bolted or screwed into the disposal itself with a rubber gasket. Check these out and tighten them up. Hope this helps.
May 13, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My gargabe disposol won't turn off.
sounds like the wall switch needs to be replaced.
Apr 05, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Dishwasher water at bottom of well.
That little plate has to be gently removed with a screw driver and a hammer.
Apr 01, 2009 | Dishwashers
Dismantle Emerson insink erator
There is a retainer ring that holds the drain and the Insinkerator together. You loosened the drain with the 4 screws. You need to rotate the retainer ring counterclockwise when looking up from the bottom. Maybe 45 degrees and it will come loose. BE CAREFUL IT WILL WANT TO FALL!!
Phil
Dec 03, 2008 | Emerson InSinkErator W-152 Point-Of-Use...
The rubber tube on the top shelf of my dishwasher is falling apar
we found a replacement at appliance parts store. thank you.
Nov 11, 2008 | Dishwashers
In Sink Erator Classic Supreme with sensor problem
I would assume that in the last year you've either fixed the washer or have gotten a new one. If your curious, this is probably the solution. There's a plastic piece that pushed a button when you open the latch and resets the washer. The piece is probably broken. If you remove the screws on the top of the door, you can reach in and manually push the button. You can also tape some metal into the end of the plastic piece so it will still push the button. A flattened bottle cap will work.
Oct 19, 2008 | Dishwashers
In sink erator dishwasher (older modle)
bottom panel loose on one side. cannot push it back in place.
Sep 08, 2008 | Servis 23 in. M4306 Free-standing...
Equator 20 in. CD 400 Compact Dishwasher Logo
556 people viewed this question
Top Equator Dishwashers Experts
Paul Carew
Jaye t rock
Are you an Equator Dishwasher Expert? Answer questions, earn points and help others
