Question about Elite Microwave Ovens
I have a kenmore elite 106.57863800 the problem im having is theres a click in the top corner box at the top left of the fridge and it feels like its not getting cold.
F5 code on Kenmore Elite Microwave 721.86013010 is it the same as the Samsung SE codes?
It may be a humidity sensor code or a touchpad code. There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components. If you have other questions, please feel free to contact me directly (see below).
. - William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Nov 20, 2017 | Samsung Microwave Ovens
My kenmore elite 721.66462500 has turntable that attempts to turn but it sparked and popped underneath and seems it won't turn. All else works-IS IT SAFE TO USE?? kenmore elite 721.66462500
When platter doesn't turn, food will not cook evenly. The motor must be replaced. No harm will come to the oven if you continue to use it.
Nov 05, 2017 | Kenmore Microwave Ovens
How Many cubic feet in a elite?
This is a 2.0 cu ft model. link to user manual:
http://kitchen.manualsonline.com/manuals/mfg/kenmore/721_7920.html?p=1
Sep 09, 2014 | Kenmore Elite Microwave, Model...
What is the cause of the smell of burnt plastic coming from my kenmore elite microwave?
Frequently this is caused by a loose connector to a thermal protection device (a TCO) or some other connector that has a plastic sleeve over it. The connector is loose, which is causing heat, which is melting the plastic. You would have to remove the cover to find the bad device and connector. This is a job for a professional microwave repairman.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jul 23, 2014 | Kenmore Elite Microwave, Model...
Kenmore Elite Microwave oven 63792 doesn't heat - all lights, turntable, fan, etc. work just fine.
Most likely it would be a bad magnetron since the light, turntable, and vent fan are running.
Sep 10, 2013 | Kenmore Elite Microwave, Model...
My Kenmore elite mini fridge turns on and the light on the inside comes on and the compressor is running and is pretty hot but the fridge is not getting slightly cool, what would cause this and how could i...
We had small fridge in our RV Travel Trailer.It would run to the tempure control setting,then it would shut off.Check it out,set it up high,then as is cools in about 12-24 hours then set it to 3-4 setting that should keep fridge Kool.Or you may need some fridgerant reinstall.Call your local repair man to quotes to recharge/fridge.Hope this help you out.
Aug 08, 2010 | Microwave Ovens
Need to know how to install
THERE IS EITHER OR BOTH A BRACKET THAT SHOULD BE SECURED TO THE WALL STUDS TO SUPPORT THE MICROWAVE AND THERE ARE THREE LONG SCREWS THAT GO THROUGH THE CABINET ABOVE THE MICROWAVE WITH AN OUTLET IN THE CABINET. THERE IS AN INSTALLATION GUIDELINE IN BOX. IF YOU STILL FEEL UNCOMFORTABLE HAVE YOUR SUPPLIER GET SOMEONE TO INSTALL.
Mar 10, 2010 | Kenmore 63252 Microwave Oven
Owners manual for Kenmore Elite Microwave Model 66462
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
You can just enter your full model number at the Sears parts site.
On the resulting page, look to the right for the blue "View manuals" button. Click there.
d:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpgd:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpgd:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpgcaab351.jpg
That Sears-related site has many free manuals. While the manuals they list there are all free, they will ask you to register.
Many times, the owner's manual will have the installation instructions inside.
If yours is not listed there for free, you would have to order it through the
Sears parts site.
Jan 18, 2009 | Kenmore 66469 / 66462 / 66464 Microwave...
Sears elite keypad not functioning
Sounds like you have a defective control panel.
We repair these for customers nationwide with our guaranteed $39.95 service.
In some cases, it may need parts, but we would contact you first for your approval for any additional charges.
We have full details, plus critical safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa.
At our site, we now have a video available showing how to remove a typical control panel assembly in under 5 minutes.
Feel free to contact me directly.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Aug 01, 2008 | Kenmore 63672 Convection/Microwave Oven
Microwave Ovens Logo
Top Elite Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you an Elite Microwave Oven Expert? Answer questions, earn points and help others
