Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Just replaced the filter for my water and now the light won't go out on my dispenser
  • LG Master
  • 4,655 Answers
It was not easy to find but to reset water filter light click=> HERE and on line 4 Click Here for the=> LFX25960_Service_Manual And here for the=> LFX25960 Owners Manual If you have other questions please let me know, Thanks, Sea Breeze
Posted on Mar 19, 2011
Samsung refrigerator filter light won't go off after new filter installed
Press and hold "Alarm" touch pad for 3 seconds and it should reset the filter light to blue.
Feb 02, 2013 | Samsung RF4287HARS French Door...
Frigidaire water dispenser won't work with new filter
The dispenser has a dual water control valves that control ice maker water and dispenser water. To find your parts you will need your refrigerators model number most time found around the fresh food sections door. Below I have a tutorial that may help you determine what may be the problem with dispensing water. Hope this helps, Thanks Sea Breeze
Oct 05, 2012 | Frigidaire Refrigerators
I've got a side by side Whirlpool refridgerator. The Water Filter status light is not indicating. What could be the problem and solution?
There are several pages that explain dispenser programming. This is on page 10 of the owners manual.
Water Filter Status Light (on some models)
The water filter status light will help you know when to change
your water filter. When the water filter status display changes from
"GOOD" to "ORDER," this tells you that it is almost time to
change the water filter cartridge. Replace the water filter cartridge
when the water filter status display changes to "REPLACE." If
water flow to your water dispenser or ice maker decreases
noticeably, change the filter sooner. The filter should be replaced
at least every 6 months depending on your water quality and
usage.
After changing the water filter, reset the status light by pressing
and holding the FILTER button for 3 seconds. The status light will
change from "REPLACE" to "GOOD" when the system is reset.
Changing the Water Filter
1. Press the eject button to release the filter from the base grille.
2. Pull the filter straight out.
3. Turn the cap counterclockwise to remove it from the filter.
IMPORTANT: Do not discard the cap. It is part of your
refrigerator. Keep the cap to use with the replacement filter.
4. Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
NOTE: You can run the dispenser without a filter. Your water
will not be filtered. Simply insert the cap all of the way into the
base grille and rotate the cap until it is firmly in place.
5. Remove the covers from the O-rings. Be sure the O-rings are
still in place after the covers are removed.
6. Push the filter into the base grille. The eject button will pop
back out when the filter is fully engaged.
7. Flush the water system. See "Water and Ice Dispensers."
Water Filter Status Light:
The water filter status light will help you know when to change your water filter.
When the dispenser control panel's water filter status display changes to "ORDER," this tells
you that it is almost time to change the water filter cartridge.
Replace the water filter cartridge when the water filter status display changes to "REPLACE."
The filter should be replaced at least every 6 months depending on your water quality and usage.
NOTE: If water flow to your water dispenser or ice maker decreases noticeably, change the
filter sooner. After changing the water filter, reset the status light.
Details:
Pressing and holding RESET FILTER starts the 3 seconds countdown. Using the dispenser
cancels the countdown AND no dispensing is permitted. The number '3' blinks 3 times and the
'invalid' tone sounds 3 times and user has to release both the pad and the button and press
the button again to start it over
After 3 seconds, the BLUE WATER BARS in the Icon flash and an audible tone sounds 3
times. When the system is reset, the "ORDER" and "REPLACE" icons will disappear from the
display screen. See figure 16.
Note: Users can reset the filter status at any stage.
If you should need the complete and exact model number and manual with parts manual you will need to enter the Model Number here=> sea_breeze_132.jpg Manuals, Guides and Instructions Please rate this solution, Thanks, Sea Breeze
User manual click HERE
Apr 02, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Want to know when and how to replace water filter on a ge side by side refrig
The water filter status light or indicator, present on some models, will help you know when to change your water filter. The light, or indicator, is located either on the temperature control panel in the refrigerator compartment or on the dispenser control panel on the freezer door.
The indicator will be one of two styles.
If the indicator is a light or series of lights, the light will change from green to yellow. This tells you that it is almost time to change the filter. It is recommended that you replace the filter when the status light changes to red or when water flow to your water dispenser or ice maker noticeably decreases.
If the indicator resembles a stack of bars, the bar height will decrease and the status display will change from "Good" to "Order." This tells you that it is almost time to change the filter. Replace the water filter cartridge when the water filter status display changes to "Replace" or when water flow to your water dispenser or ice maker noticeably decreases.
If a filter status light/indicator is not present, the filter should be changed at least once every 6 months. Your filter may need to be replaced more frequently depending on your usage and water quality.
If the water flow to the water dispenser or ice maker noticeably decreases before 6 months have passed, you may need to replace the water filter cartridge more often. Decreased water flow is a sign that the filter is clogged and needs to be replaced.
If the filter is clogged and you are not able to immediately replace it, remove the filter so the water system is in bypass mode. With the filter removed, the water system will continue to operate, bypassing the filter, and the clogged filter will not cause slow water dispensing or low ice production. However, in order to have filtered water, you will need to install a new filter.
The filter status display will help you know when to change your
water filter. When the display reads 10%, order a new filter. It is
recommended that you replace the filter when the display reads 10% OR when water flow to your water dispenser or ice maker decreases.
Step 2
Step 3
Step 4
Turn the cap counterclockwise to remove it from the filter. IMPORTANT: Do not discard the cap. It is part of your refrigerator. Keep the cap to use with the replacement filter.
Step 5
Step 6
Remove the protective covers from the O-rings. Be sure the O-rings are still in place after the covers are removed.
Step 7
Push the filter into the base grille. The eject button will pop back out when the filter is fully engaged.
Step 8
Flush the water system. Use a sturdy cup or glass. Depress and hold the
water dispenser lever for 5 seconds, then release it for 5 seconds. Repeat this process until water begins to flow. Once water begins to flow, continue depressing and releasing the dispenser lever. Hold down for 5 seconds and then release for 5 seconds. Do this on/off process for about 2 minutes. This will flush air from the filter and water dispensing
Hope this helpout in changing the water filter......
Aug 10, 2010 | GE Refrigerators
Amana AR2664bw dispenser lights
Are you talking about the inside lights are the dispenser lights?
Nov 01, 2008 | Amana Refrigerators
Water filter light
to reset. hold dispense light and lock key pads on the dispenser control panel pushed in for 3 seconds until light flashes. This will reset it
Please rate me.
Apr 14, 2008 | Jenn-Air JCD2389G Side by Side...
Ice maker doesn't work. changed filter. light on ice maker door still on.
You need probably to change the dispenser solenoids which swith water on dispenser
Apr 05, 2008 | Jenn-Air JCD2389G Side by Side...
No ice or water from dispenser
Kathryn, make sure you do not have the dispenser locked out. Press and hold the lock button for 3 seconds. If you have a green light above the pad this indicates lock. You are going to have to hold the water lever for a while until all the air in the new filter is purged. Catriver...post back.
Nov 12, 2006 | Amana ARS9265B Side by Side Refrigerator
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
133 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
