Question about Car Audio & Video
How do i replace front door speakers on my vauxhall astra, K, registration model
Do i need to remove the whole pannel or just the front speaker cover - how do i get the speaker out of the speaker mounting
  • FFSS Aug 11, 2008
    I have a 2000 Pontiac Bonneville, and the driver side speaker doesn't work. I tried to change the spaker just by popping out the speaker covers on the pannel but it wasn't possible. I am guessing that i have to take the whole PANNEL out to replace the speakers with new ones...THE QUESTION IS...I DON['T KNOW HOW TO TAKE THE DRIVER SIDE PANEL OUT..TO REACH THE SPEAKERS..
    Problem Solver:
  • 4 Answers
Thats a complex situation.
You have to disconnect and remove all the power window and lock devices.
Leave your window up so it doesn't block the speaker.
Once you remove and disconnect the power devices, they should pop out of the door panel, remove the panel gently and watch for any plastic threaded button type pieces. They fit into grooves in the panel and butterfly into the drilled holes in the door frame itself.
Remove and replace the speaker.
Reverse the removal process for the reinstall of the panel and power options.
Posted on Aug 19, 2008
I have a vauxhal astra 55 plate.Am looking to install four 8 inch Eminence mid speakers in both front left and right side doors and the same as both rear left and right doors.How do I then go on to doing...
these might interfer with the window glass going up and down , i'd go to a car audio specialist for some advice before you make some holes you cant repair
Jun 21, 2014 | Cars & Trucks
Replace front speakers
You would have to open the door panel to replace front speakers. Look for any screws around the door handle. look at the whole door panel for any screws so that you may remove the panel in order to reach the speakers. once the panel is free from any visible screws, use a door panel remover ($5-10) and use it to pry off the panel, use it around the door panel push-in connectors, and don't use extreme force, may break connectors. once the connectors around the whole panel are removed. make sure your window is down before the whole procedure. then pick up the panel from the bottom (push up), then the panel should be off the door, if you want to change the speakers, you don't need to take any of the wiring to the window/door lock. simply remove the cover if any over the stock speakers, usually some screws. once the cover/screws are off. the speaker should come off. You will see two wires off the speakers (the red(positive) the black(negative)), once the stock speaker is removed, simply attatch the new speaker to the wires. make sure the negative and positive from the car DO NOT TOUCH, you WILL short circuit and blow a fuse, maybe worse, and it's not worth the time fixing. hope this helps, good luck.
Jun 12, 2011 | 2004 Volkswagen Beetle
Need instructions to replace the passenger side mirror and the driver side tail light on a 1999 Ford Taurus 4-door sedan. Thank you, Gary S.
Section 01-09: Mirrors, Rear View 1999 Taurus/Sable Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 06/25/1998 Mirror, Power-Outside Rear View Removal
  1. Disconnect battery ground cable (14301).
  1. Remove front door trim panel (23942). Refer to Section 01-05.
  1. Remove radio speaker grille from cover assembly by squeezing or pinching between thumb and index finger.
  1. Remove two screws from cover assembly.
  1. Disconnect outside rearview mirror wiring connector (C515-LH; C615-RH). Remove wiring guides as necessary.
  1. Remove three outside rear view mirror retaining nuts. Remove outside rear view mirror (17682) while guiding wiring and connector through hole in door.
Item Part Number Description 1 17682 Outside Rear View Mirror 2 N621906-S36 Nut (3 Req'd) 3 F8DB-17D699-
AAW Cover Assembly Rear Substrate-LH 3 F8DB-17D698-
AAW Cover Assembly Rear Substrate-RH 4 N808968 Screw 5 F8DB-18B984-
AAW Speaker Grille-Standard (No Badge)-LH 5 F8DB-18985-
AAW Speaker Grille-Standard (No Badge)-RH 5 F8DB-18K901-
BAW Speaker Grille-Mach-LH 5 F8DB-18978-
BAW Speaker Grille-Mach-RH 5 F8DB-238A35-
AAW Speaker Grille-Blank (No Speaker)-LH 5 F8DB-238A34-
AAW Speaker Grille-Blank (No Speaker)-RH A - Tighten to 6-8 Nm (54-70 lb-in) ------------------
Trim Panel, Door Front
Removal
  1. Remove cover behind inside door handle.
  1. Remove screw from bottom of pull cup retaining front door trim panel to front door (20124).
  1. Remove three screws retaining front door trim panel to front door.
  1. NOTE: Do not attempt to remove more than one pushpin at a time.
    Using Rotunda Windshield and Molding Trim Removal Kit 107-R0401 or equivalent, remove the door trim panel by pulling one door trim panel pushpin at a time from the inner door skin.
  1. Disconnect electrical connectors as necessary. Refer to Section 01-14A.
Installation
  1. Follow removal procedure in reverse order.
  1. Replace all pushpins with new pushpins (N808994-S).
Front Door Trim Panel
Jan 14, 2011 | 1999 Ford Taurus
Radio code vauxhall astra 1997
Radio code is specific for each and every car. It is specific like anti theft code.
You can get it by providing your VIN# and registration details in authorized dealership.
Nobody else can provide you. If anybody can provide you that , then there is no meaning of security for your car.
Sep 30, 2010 | Car Audio & Video
Remove passenger door pannel
remove screws (several... front, bottom.. door handle pocket (covered by round plastic button), door handle (behind. remove tweeter speaker assy (upper front corner). Interior panel pops out to gain access to whatever is behind it. That's it. Anything else?
Jun 11, 2009 | 2006 Hyundai Sonata
Changing the front speaker 2001 Eclipse Spyder
There are 7 screws all together to remove the door pannel. First, you have to take off the hanlde for the door. the 2 plastic covers on the handle pop off revealing 2 screws on the top and bottom, remove those. then behind the the door handle on the inside, pull it as if you were to open it and there is a screw that you have to remove. Then there are 2 screws on either side of the door pannel, both are farily close to the top, remove those, and then its just a matter of popping the pannel off. start from the bottom, pop it off then slide it up. becarefull, after the door panel is free, there is a connection for the power doors and windows unhook that then the pannel will be free. after that the speaker will be right there and its common sense on removing that. good luck.
Mar 27, 2009 | 2001 Mitsubishi Eclipse Spyder
Removing twin back rest part of seat?
YOU WILL MOST LIKLEY TO REMOVE THE WHOLE SEAT BACK TO REPLACE A PART OF BACK REST AND UNCLIPP THE LOWER PART, THERE WILL BE A LOT OF TENTION ON FABRICWHICH YOU WILL HAVE TO PUSH DOWN ON TO RELEASE
Sep 09, 2008 | 1999 Ford Escort
Vauxhall Astra estate, steering column defect.
the answer they gave u at the shop is true, there is no kit for that steering
sorry...
Jun 25, 2008 | 2008 Volkswagen Touareg
Car Audio & Video Logo
1,291 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
