Question about Weslo Exercise & Fitness
I have a Cadence G 5.9 I get an FF on the screen, and it will not respond to anything we have tried????
  • 4 more comments
  • melene_heini Mar 19, 2011
    did that, and it still won't do anything. The "FF" reading is still on the screen when you put the key in. The outlet is good, the power surge protector is good. Even plugged it directly into the wall outlet....nothing, just the FF reading. ?????
    Done that.....several times. What is that "FF" reading?
    Still not working. There is no" Power "key, just start and stop keys, but tried those. When you turn the reset button off the FF will go off.....but as soon as you "reset" and put the key in, the FF comes on, and it will do nothing.
    Are we done? Did you get my last post,saying that the last solution of the Power keys, didn't work?
  • melene_heini Mar 20, 2011
    This is a Cadence G 5.9. The link didn't help any. I have only had this for 2 1/2 months.I thank you for at least telling me what the FF could be. I don't think it would be worth the shipping and repairing , do you?
  • melene_heini Mar 23, 2011
    FYI: the "FF" on the monitor meant that the software needed to be downloaded. Weslo is sending a program for it.
    President:
  • 2,047 Answers
FF on screen means a systems failure of the unit. To sort this out first try unplugging the unit for a couple of hours and try restarting it. If this does not sort out the problem then the failure has affected one of the main components and a replacement of parts is in order therefore you have to refer to an expert to determine what needs to be replaced.
Hope this solution has been helpful?
Posted on Mar 20, 2011
  • 12,061 Answers
Http://www.livestrong.com/article/299994-how-do-i-troubleshoot-a-weslo-sr12-treadmill/
Above is the troubleshooting link for your unit.
I think that the FF, relates to a power problem specifically the Motor.
    Genius:
  • 1,196 Answers
Check the circuit breaker on the frame near the power cord. If the reset/off circuit breaker has tripped, wait 5 minutes and then reset the breaker by pressing the switch in. That should fix the problem, if not, let me know the result
Posted on Mar 19, 2011
  • Ishola Olayemi Mar 19, 2011
    Ok, try removing and reinserting the safety
    key.See what happens.
    Try this, Press POWER to turn off the treadmill,
    At the same time, press and hold the +, -, and POWER keys.
    Continue holding all keys until their is nothing on the screen display.
    Release the keys. insert the key properly and see what happens.
My tablet 7.85 touch screen not responding.cant switch on or off or reboot.Only 5 days old.
It is not the normal behaviour of a new tablet. Don't mess with it. Your tablet is on warranty. Look up where you should take it for a checkup and repair service
Feb 06, 2015 | Tablets & eReaders
Sigma BC 1609 Cadence Bicycle Speedometer reads my movement much slower than I am actually going. E.g. moving about 15, reads as 5 mph.
I had the same problem. It is caused because the mount is facing the wrong direction and your computer is swapping speed and cadence. 5 mph would mean 63 RPM of the wheel which probably what your pedal is actually doing. The wheel is actually turning at about 3 times that rate so if you check your cadence it is probably maxing out at 180 even though that wouldn't be possible.
To fix this, just twist your mount 180 degrees on your handlebars or stem and try again. That way the computer is correctly lined up with the mount.
Mar 10, 2012 | Sigma Sport BC 1609 Cadence Wired Computer
The treadmill powers up but the belt does not respond.
I HAVE WESLO CADENCE M 5 MODEL NO. WETL12706.0 IT POWERS UP BUT DOES NOT MOVE ANY HELP PLEASE
Dec 16, 2010 | Bowflex Treadmill Series 7
I have a weslo cadence 200 cs treadmill. I changed the batteries but the display keeps blinking 0
You probably need a new treadmill display screen but one thing you can try is to get a 6 volt power suppply and use the power supply instead of the batteries.
May 20, 2010 | Exercise & Fitness
I have a cateye strada cadence computer. The wheel sensor is working fine but the cadence sensor isnt detecting anything. The manual says that the magnet must be within 3mm of the sensor but, with the...
I have the same exact issue - all works but not the cadence sensor. I am going to try using some rubber shims or something...wish I had an old innertube to use.
Jan 26, 2010 | Cadence Cat Eye Strada Computer
Philips HDD6330 - Dead?
WARNING: this process will erase all songs off the GoGear.
Disconnect the GoGear from computer.
Turn the GoGear off.
Hold in the volume + button.
Reconnect the GoGear while holding in the volume + button.
Continue holding the volume + button.
After 5-50 seconds, Windows will pop-up a "Found New Hardware Wizard." - complete the wizard (BTW, you can take your hand ff the volume + button now).
Good To Go (Gear)!
-Tha Mp3 Doctor
Mar 29, 2008 | Philips GoGear HDD6330 MP3 Player
Sandisk Sansa e260
u have to wait till the screen will be black. I had the same problem with my sansa. it can lasts 1 or 2 days. after screen is black and then do following: 2. change lock switch to orange position 3. Press and hold rec button (at left side) 4. while pressing the rec button, turn the player on 5. it will appear the boot menu. connect the USB cable and try to continue the firmware 6. if it doesn't work, do a firmware downgrade. download this file: http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe 7. execute the application while in boot mode good luck darek
Apr 03, 2007 | SanDisk Sansa e260 MP3 Player
Cadence FX500
The FX500 is 4 x 75 watts clean and 1 x 500 watts RMS @2 ohm mono. What subs are you running and what are the ohms per voice coil. Single or dual voice coil. By what you said (not getting hot) sounds to me like the load istoo much. Let me know.
I was/am a Cdence daler and I sold many of those amps without a problem Never had a bad one!
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Dec 05, 2006 | Cadence Z9000 Car Audio Amplifier
Exercise & Fitness Logo
205 people viewed this question
Top Weslo Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Jim London
Jim London
Are you a Weslo Exercise and Fitnes Expert? Answer questions, earn points and help others
