Question about Maytag Dishwasher
We moved to a new house with or GE EDW6000. The dishwasher wont drain all the way. about 3-4 gallons left in bottom. The new house has an air gap under the sink that is lower than drain hose Could this be causing the problem.
I had the same problem with mine .turned out to be the pump drain not the pump itself .there was glass stuck in the little propellors.once i removed the glass it worked fine
Posted on Mar 19, 2011
Water remains in bottom, water pump out?
It sounds like one of two possibilities here.
The most likely is a blockage somewhere between the drain pump and the drain in the house (under the sink).
Places to look for this would be an air gap or the fitting where the drain hose connects to the house plumbing. Take the drain hose from the dishwasher off of the house pipe under the sink, run that hose into a bucket and see how it drains then. If it is poor then follow back toward the dishwasher until you find the next junction or fitting. If you are sure all these are clear and still not draining, you will most likely need a new drain solenoid.
Apr 25, 2010 | GE Dishwashers
Water at the bottom of the dishwasher
There is a check valve but it is not strong enough to overcome a large amount of water or waste water and is not a 100% seal. You will need to have your house drain cleaned so the water in the sink and disposer drain out properly.
To keep waste water from entering the dishwasher if you have drain problems in the future you can install an air gap. You can purchase an air gap at most any hardware or Big Box outlet, they come with instructions for installing and are a good idea if you have problems like this.
Apr 25, 2010 | GE 24 in. Profile PDW7800 Built-in...
The water wont drain out the bottom ...i cleaned all the screens inside
HI. check the following areas for faults.
1. Air gap / Drain hoses If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the Motor If defective.
6. Timer Replace if defective (note: uncommon problem).
Sep 29, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Potscrubber 900 Dishwasher won't drain
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
Replace the motor if defective.
6. Timer
Aug 27, 2009 | Dishwashers
Ge quietpower 3 wont turn on
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer or Control Board
Aug 05, 2009 | General Electric Adora GHDA670N Built-in...
Dishwasher won't drain?
HI. check the following areas for fualts.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Jul 15, 2009 | General Electric Adora GHDA670N Built-in...
Ge nuatilus wont drain
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer or control board
Jun 03, 2009 | GE Nautilus 24" Built-in Dishwasher
Water in dishwasher will not drain.
Check the following to address this issue--
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Jun 02, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Dishwasher 2200 series - water comes out airgap
take the air gap apart and clean it out. also clean hose from air gap to garbage disposal.. if the garbage disposal is new take it down and remove the plug where the drain hose from the air gap connects to it..
Feb 13, 2009 | GE 24 in. GSD2230Z Built-in Dishwasher
Maytag Dishwasher Logo
73 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
