Question about Lynx LBQ27FRE (NG)
There is only enough gas to lite one side and the burner flames stay very low even when turned on high
  • jdadamss Mar 19, 2011
    THIS IS NOT A PROPANE GRILL ITS NATURAL GAS AND ALL THE VALVES ARE OPEN . ITWORK FINE LAST TIME I USED IT
    THIS IS A NATURAL GAS GRILL .LAST TIME I USED IT IT WORKED FINE . NOW THE GAS PRESSURE IS SO LOW IT BARELY LITES ONE SIDE AND THE FLAMES WILL NOT INCREASE WHEN KNOB IS TURNED TO HIGH
  • 1,606 Answers
Aside from the usual suspects (low fuel tank pressure, mis-adjusted, clogged or malfunctioning regulator), there are gas flow limiting devices that are activated by excess heat, improper lighting, or a detected leak in the regulator or downstream.
  1. Inspect the gas plumbing between the tank and burner. Replace any hoses or other parts that show visible flaws. Remove any char build-up inside the burners and gas pipes feeding them.
  2. If you have a clean, empty spray bottle handy, fill it with a mixture of soap and water. Open the tank valve, then spray the connections. If you see soap bubbles popping up from some point, you have a leak there. Tighten the loose connection or replace the fitting as necessary.
  3. If flow is being limited because of a lighting procedure problem, shut off all burner controls and close the gas valve. Wait 30 seconds. Open the gas valve slowly. Wait 5 seconds, then open the burner valve and light it.
  4. The large black coupling is thermally sensitive. If it is heated above 240 ° F, it is supposed to shut off gas flow - permanently. If this shutoff has been tripped (even partially), the coupler must be replaced.
Note: there are two different regulators. If you must replace the regulator, make sure you get the one for the fuel you use (natural gas or propane).
References: Owner's manual
Parts diagram
Posted on Mar 19, 2011
    Brigadier General:
  • 4,736 Answers
If this is a Propane gas Grill with a tank ... Turn the tank vale OFF. Disconnect the grill hose from the tank and wait 5 minutes before reconnecting it. After reconnecting the hose to the tank, turn the tank valve on VERY, VERY, SLOWLY (Slow motion, slow). Once the vale is completely open, light the burner farthest from the tank first and turn the burner to the highest setting. If the flame height appears normal repeat this procedure with the remaining burners. If the flame heights do not appear normal, turn the tank valve OFF and disconnect the hose. Remove the tank from the grill and lift it with one hand. Does it feel full or partially full? If not, and it's not a new tank, it may only have enough gas to barely light the burners. If the tank is full or partially full and the first procedure listed above didn't solve the problem, you need to replace the grill hose and regulator assembly. You can purchase one from just about any hardware or home improvement store that sells gas grills. Just take you old one with you for comparison. Remember, always turn the tank valve on VERY, VERY Slowly.
Happy Grilling!!
  • 1 more comment
  • Rich Landrum Mar 20, 2011
    Check the inline gas shutoff valve to make sure it's completely ON. If it's been a while Several months) since you've used the grill, the venturi valves may be clogged with insect nests. You will need to remove the burners from the grill to inspect the valve (They are the open end of the burner) and while you're at it, check the burner orifices to be sure they are not clogged. Once the burners are out, your will be able to see the orifices. To clean them, unscrew them with the appropriately sized open end wrench and blow air through them.
    This would be really unusual, but do you have a regulator on your Natural Gas Grill? I said unusual, because most Natural Gas Grills Don't. But if you do, it may be locked closed. In which case it will need to be replaced.
Purchased a grillpro 3 (three burners plus side burner) from orchard. They installed but side burner will ignite. Igniter is working and I hear gas when I turn the burner knob. Fire the igniter and it will...
You're getting gas to the burners, just not enough to ignite the burners.
To solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank.
I hope this helped you & thanks for choosing FixYa.
Jul 28, 2011 | GrillPro Grill Pro 80016 Hose and...
My gas grill when turned on will not stay lit sometimes 'When lityou can here air or something blowing and the flames are real low it doesn't even cook its so low I have it on high when we first got it, it...
Susan - Assuming that you have a Propane grill with a grill tank, that has plenty of gas in the tank. Do the following:
  • Turn the Propane tank valve OFF.
  • Disconnect the hose from the tank.
  • Wait 5 minutes and reconnect the hose to the tank valve.
  • Turn the Tank Valve ON, VERY, VERY SLOWLY (slow motion, slow).
  • Once the valve is fully open, light the burner farthest from tank, first.
  • Turn the burner flame to High. Has the flame height returned to normal? If so, light the remaining burner(s) the same way.
  • Have all the burner flames returned to normal? If so, you solved the problem.
  • Always remember, when turning the tank valve ON, do it VERY, VERY Slowly.
If the above did not solve your problem, you will need to replace the grill's hose/regulator assembly. You can find them at any home center or hardware store that sell grills and accessories. Be sure to take you old one with you for comparison purposes.
Hope this helped you solve your problem. Please be kind enough, not to forget to rate my response to you. Thanks and Happy Grilling!!
Apr 14, 2011 | Uniflame Grilling
Burner will not stay lit. Push in knob-- flame starts, but will not stay lit as soon as you take pressure off of the knob, no matter how long you hold the knob in. Also, on other burners, I cannot reduce...
I never even saw one of these babys. Wow what a stove. The simmer issue might be fixed by removing the knob and seeing if their is a minimum flame adjustment in the stem of the gas valve. The non lighting issue could be some sort of flame sensing device not recognizing the fire is lite, you could try holding in on the knob a little longer to allow the flame sensing device to pick up OR get a brush and clean around the ignitor. She sure is a beauty. The constant ticking is usually a stuck spark switch.
To find the one that you suspect is stuck you must remove a wire from each switch till you find that one
This video shows how to adjust flame:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 15, 2011 | La Cornue Grand Palais 180 Dual Fuel...
The oval burner has only very low flame, even when set on high
Every one of these ranges that I have seen with the oval style burner on them have a smaller flame then the normal round burners. And there is very little difference between the low and high settings. It sounds like what you are experiencing is normal. What the GE repairman was adjusting is called the "simmer stop". There is a small flat head screw inside the burner stem. By turning this screw you can adjust the size of the burner on the low position of the burner knob. This should be adjusted to where the burner still stays on when the knob is at the lowest setting. I do not think that you need the burner repaired. From my experience they are all like that.
Mar 10, 2010 | GE Cafe CGS980S Kitchen Range
Desa model tb103 wont stay lit.
at first i thought this was a bad flame rod but the fact that it burns on low and not on high tells me that it is not getting enough gas since it burns less gas on low. there will be a tap on the burner side of the regulator, take off the cap and turn the screw clockwise to increase the gas pressure. do this in small amounts until it corrects the problem. If you have or can get a manometer, the gas pressure should be set to @7 inches of water column
Dec 09, 2009 | Reddy Heater RLP100 Portable Forced Air...
Gas Grill - flame always stays on high even though I've turned in on low
hey buddy that use to happen to me so what i started to do was once the fire was high i use to turn the gas off i hope this helped.
 infamouspk
Oct 07, 2008 | Sport & Outdoor - Others
Jenn-Air Gas stovetop
try to clean the burner and then try it.
Sep 21, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Laars lite 2 pool heater burner not lite
If the pilot flame is not strong enough, it will not tell the gas valve to open, or if the gas valve is not getting the signal to open, it won't. Check all wire connections at the thermostat and gas valve. Check ground wires. Clean the pilot light and flame rod.
Aug 31, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Lynx LBQ27FRE (NG) Logo
208 people viewed this question
Top Lynx Grilling Experts
Gary Kenady
Gary Kenady
Paul Bade
Paul Carew
Are you a Lynx Grilling Expert? Answer questions, earn points and help others
