Question about Air Tools & Compressors
I have a 97 camaro backfiring problem after warm up it has new plugs and wires cap roter waterpump and new gas
  • 2,418 Answers
It depends on which engine and any mod.s you may have done. But most likely a timing issue. It can also be due to a lower than normal engine temp. sensor. If you run a lower than normal coolant thermostat to trick your ECU into more fuel, things like this can happen. Start with checking the Ign. timing. Check for a vacuum leak, Check your engine temp. Hope this Fixya up.
Posted on Mar 19, 2011
My car wont stay running with out me pushing the gas
replace the throttle positioning sensor on the throttle body. It will need to be reset upon replacing it so have a qualified mechcanic do it for you
May 05, 2012 | 1990 Chevrolet Camaro
Hello, I have a 1992 Camaro RS 25th Anniversary ed. 3.1 V6. 118k miles. 700r4 Transmission. & My problem is.. I ran it low on gas, put gas in it.. ran like ****.. missing.. sputtering.. low power.....
CHECK FUEL pressure and take a fuel sample see if has water in it. since started problem rt after getting gas sounds lik you got some bad fuel
Jun 02, 2011 | 1992 Chevrolet Camaro
I have a 97, it starts, but when it wrams up it starts back firing and has a storong gas smell? idk what way to turn
If you are backfiring you should check your firing order... If you have had your Plugs and wires replaced recently then it may have been installed wrong.. also try changing your fuel filter.. or changing the spark plugs
Mar 17, 2011 | 1993 Chevrolet Camaro
My 90 camaro will not start has fuel and spark new compter new cap and roter no codes
It sounds like it could be your starter. Try tapping it with a hammer while having someone simultaneously try to crank the car over.
Feb 20, 2011 | 1990 Chevrolet Camaro
WONT START AND TRIES TO TURN OVER BUT BACK FIRES
AWESOME a real camaro problem.
backfire.
strong odor of gas because the gas isn't getting burned
caused from backfire. backfiring because the spark isnt sparking when its supposed to.
problems could be bad spark plug wires , bad plugs , bad ignition parts.
your gonna need to check wires for bad spots, check ignition coils and stuff like that. if all that stuff is ok, then your problems have to do with inside the engine. jumped time etc.
Jul 31, 2010 | 1993 Chevrolet Camaro
97 dodge dakota
try a crank shaft position sensor
it will not set a hard fault code
May 02, 2009 | Cars & Trucks
1995 Camaro backfire
check your vaccum lines and injectors I had the same problem the injector would put gas in the cylinder but not keep constant spray so it would puddle and ignite creating a back fire also check your coils and make sure you are getting spark to every plug ...
hope that help I have the same car 1995 chevrolet camaro 3.4 liter v6 automatic
Apr 30, 2009 | 1995 Chevrolet Camaro
Backfire into intake
I'ts quite possible that your distributor is installed one tooth off and is too far advanced, causing the plug to fire before the intake valves are closed completely. Turn it one tooth counter-clockwise and try it again.
Mar 25, 2009 | 1998 Jeep Grand Cherokee
Air Tools & Compressors Logo
146 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
