Question about GE Dishwashers
Soap tablet does not dissolve and is in the bottom of the dishwasher at end of cycle.
  • GE Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on Mar 20, 2011
The soap doesn't dissolve
your using to much soap . pour vinegar about a half cup into the bottom of the washer before you start, do this about 3 washes then should be okay,
Sep 09, 2012 | Magic Chef 5-Cycle Dishwasher
The soap dispenser opens & the soap tablet (power ball) drops to the bottom but doesn't dissolve
1. Water temp is wrong should be 140-145
2. spray arms clogged with food
3. water valve is not letter the correct amount of water in
after it fill's check to see water amount in bottom , dose it sound like it is starving for water ? it would sound like it was surging
Dec 01, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Tablet not desolving after quick wash cycle
Find out whether your quick cycle is a wash cycle or a rinse only. If it is a wash it's obviously too short, and the tablet is not dissolving. You do not want undissolved tablets because they will contaminate your rinse water and u end up with soap on the dishes. You can switch to powder if a tablet isn't going to dissolve quick enough on your quick cycle.
Jun 03, 2011 | Bosch Dishwashers
We use the Cascade tablets but they don't dissolve
Either:
1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Apr 13, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Tablet is not dissolving from my dishwasher drawer
If it drops to the bottom when you open the dishwasher door - your soap dispenser is blocked by the rack or an utencil protruding from the rack. Make sure both racks slide in all the way to the back. (hint: check the middle spray arm inlet, make sure it aligns with the tube on back.
Good luck)
Oct 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
The soap packet doesn't dissolve, it remains intact at the bottom of the machine at the end of the cycle.
don,t use those packets stay with powder or liquid dishwasher soap. the packets need a lot of heat to dissolve,.
May 29, 2009 | GE Nautilus 24" Built-in Dishwasher
Tablet falls out & doesn't dissolve especially on fast cycle
Hi and wlecome...
You should not use anything other than powered dishwasher detergent in these products. They are not designed for tablet-style detergents. The reason is because the dispenser does not "open" during the wash cycle like you would see on a conventional dishwaser. The incoming water pours over the detergent and releases the mixture out the bottom of the dispenser. If you need a user guide, you can get one here: http://fisherpaykelparts.net/index.php?blockitemid=29
Jan 22, 2009 | Fisher and Paykel 23 in. DS603H W Built-in...
Tablets not dissolving
Sounds like whatever soap you are using is just too much soap your dishwsher can handle. The soap "packs" are usulally an overload of soap for most dishwashers. Just a few teaspoons of regular name brand soap sometimes will cure lots of dishwsher ills!!!
Apr 12, 2008 | Zanussi 18 in. DA4342 Free-standing...
Tablet wont dissolve during cycle
do you mean when you open it near the end...
the soap dispenser may not be opening due to residue build up.
try cleaning it and if that does not work, you need to service the mechanism.
timers can cause this too.
also, a loose wire can cause this.
good luck
mark
Nov 19, 2007 | Asko D1716 Built-in Dishwasher
Dishwashers Logo
48 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
