Question about Electrical Supplies
Need wiring diagram for a key switch for a Honda NTE6700V generator
5 Suggested Answers
  • 42 Answers
SOURCE: wiring diagram for Generac engine on standby generator
here is a wiring diagram for that engine:
Posted on Mar 13, 2009
  • 70 Answers
SOURCE: where would i find a wiring diagram for a honda
If you are trying to hook it up to use it check with any good Honda generator dealer and should help you for free.
If you are looking to repair it there are many sources for manuals on the web.
Thanks,Eric
Posted on Sep 23, 2009
kevin_getz
  • 1031 Answers
SOURCE: I need wiring diagram for honda exw 280d generator welder
You will need to contact Honda directly for wiring issues.
Posted on Apr 30, 2012
watsonhellas
  • 774 Answers
SOURCE: need a wiring diagram for 6 way starter switch
You needn't worry about a six way Kill Button... I used one myself to replace the OEM one. Buy yourself a cheap electrical multimeter for around $12 and test the switch for continuity (the meter set to Ohms or Resistance) with the switch in different positions using the different poles without installing it. You will then know which position is RUN (I) when the meter responds.... turn the switch in the other direction and it should have an OPEN (O); i.e., the meter doesn't move, which indicates the engine Kill Switch by grounding the spark from the magneto or reluctor coil. A multimeter is a cheap tool to have in your arsenal around the home and shop.
Posted on Jun 09, 2015
I need the wiring diagram on a Honda generator model eu2000i for the front cover on the inside any the wire diagram
Type maker, model, user manual in computer search engine. It will bring up sites to get user manual. In the manual, there is a wiring diagram
Dec 13, 2015 | Honda Electrical Supplies
Honda 20hp wiring diagram
are you trying to install a key switch assembly i can help you just indicate color of wires your dealing with,honda tech 30 years
Aug 25, 2014 | Honda Engine 20hp Horizontal Tapered Shaft...
Honda v twine 20hphonda diagrams wining
tell me what are you trying to do key switch maybe??i know this motor inside and out 30 years experienced.
Aug 25, 2014 | Honda Horizontal Engine 20 HP 12V ES 20...
1989 Honda CBR 400 RR wiring diagram
Hi, Anonymous for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
1989 Honda CBR 400 RR wiring diagram Google Search
Honda Motorcycle Wiring Diagrams
http://service.tanga-moteurs.ro/?download=Honda_CBR_400_Repair_Manual.pdf
https://www.partsfish.com/page/oem-parts-for-honda
https://www.tygaeurope.com/media/wysiwyg/parts-book-cbr400rr-nc-29-1cbc01ab.pdf
http://mybikemanuals.com/honda
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 26, 2012 | 1989 Honda CBR 400 RR
2003 Honda CBR 600 RR bypass ignition switch
Hi, Taners2003 for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Ignition switch bypass
2003 2004 Honda CBR600RR Service Manual Moto Data Project
http://www.partsfish.com/page/oem-parts-for-honda
Honda CB Owners Manuals
Mar 19, 2012 | 2003 Honda CBR 600 RR
Need to know which wire is the low oil shut off for a Honda 2000eu generator
the low oil switch wire is the ' yellow ' wire.
the diagram that I have here shows that it is a normally open curcuit ( if that helps any in what you are doing ).
c...
Jan 23, 2011 | Honda Electrical Supplies
Where do you remove the Ground Neutral bond on a EU6500is generator? I need to do this to hook it up to a transfer switch as per Service Bulletin #20.
Page 39 of the current owners manual for the both EU6500 and the EM5000 generators indicate that there is not a neutral ground bond on these units.
Per the wiring diagram, the ground pin on the outlets is connected to the frame ground of the generators (on both generators). To have grounded electrical service, a bond wire would connect the generator frame to the ground terminal on the transfer switch. The ground system from the breaker / distribution box (usually to a ground rod) then serves as the electrical ground for the generator, as well as the balance of the rest of the system, satisfying NEC requirements.
See Page 39 in both manuals:
EU6500 EM5000
"The system ground is not connected to the AC neutral
wire. If the generator is tested with a receptacle tester, it will not show the same ground circuit condition as for a home receptacle."
Sep 22, 2010 | Honda Transfer Kit for EM 5000iSAB and EU...
How can I shut my Honda eu1000i off from inside the cabin?
You should not have to cut any wires to install a remote kill switch. Most honda engines have an oil alert what will cut ignition if oil level is low. The switch actually shorts the itnition to ground just like the on / kill switch. Just unplug oil alert wire from harness and add a homemade connector with second lead and connect another wire to ground/frame of generator engine. When you short these two wires together it should kill engine. Solder these two wires to a female connector (Radio Shack) and just leave inside generator when you want remote switch. Attach switch to leads of desired length of male connector to mate with female connector at generator. Good Luck.
Jul 10, 2010 | Honda Electrical Supplies
Electrical Supplies Logo
210 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
