Question about Campbell Hausfeld FP2095 2 Gallon Twinstack Air Compressor
It runs but the pressure is not going upto 100psa
  • Campbell Hau... Master
  • 1,932 Answers
First it could also be a bad checkvalve on the tank
Posted on Nov 22, 2016
    Habit-Forming:
  • 83 Answers
It could be a worn teflon piston if it's an oilless compressor, the loud noisy ones use no oil instead they use a special teflon piston/ring set witch has low friction other than the typical old cast iron piston compressor with an oil reservoir.
2 things, you may have a leak or stuck valve, or a hole in the tank, look and listen for leaks
Your piston is worn out, the teflon is worn or scored and air bypasses the side of the piston, you need a piston rebuild kit, they are around $ 30-40, easy to install in most cases. It may contain a piston and replaceable cylinder wall.
Good Luck
Posted on Mar 20, 2011
What's causing air inflation problem?
then contact the company for a replacement
Jun 30, 2015 | Braun Bp-5900 Exactfit Plus Bp Monitor
Injectors have been done. Once the engine is upto running temperature it stops. It also does not blow smoke while under power when cold. Any ideas. Thanks
It is impossible to answer your question without knowing the YEAR, MAKE, and MODEL of your vehicle.
That being said, check for proper fuel pressure at the fuel rail. If pressure is low, replace the fuel filter, check the operation of the fuel pressure regulator, and verify that the fuel strainer in the tank is not clogged. If pressure is to high, replace the fuel pressure regulator.
The symptom you are describing also sounds a little like contaminated fuel. If all else fails, replace all fuel with new. Also, readout all stored codes in the computer to verify proper operation of sensors.
May 11, 2015 | Cars & Trucks
My mitsubishi carisma GDI 1998 model does not rev upto the 3.0 mark before it starts misfiring, but it starts and does slow running perfectly well with no indicator on dash board. please help
start it at night,open the hood,have someone rev it till 3.0 and look for sparks,then replace whatever is sparking,plugs and wires,coil pack,,,etc.,,,
Apr 10, 2015 | Mitsubishi Cars & Trucks
High water pressure causing overflow
The pipe from the pressure switch is either blocked, damaged or has become disconnected from the pressure switch ....so is not sensing the water level in the drum. From your filter you will see either a thin black or clear tube going upto the pressure switch - check this out. If damaged change; actually it is a simple fix. Spares can be located from this very site - fixya. Good water flow is gud, but after your wash see that the valve on the wall faucet is turned off.
If helped pl click so.
Mar 31, 2013 | Cars & Trucks
I have a 1993 chevy van 5.7 I'm getting gas all the way upto the Carb but it will not run unless I pour gas into the intake. Changed everything except injectors and relay.
well first thing is it does not have a carburator, it has a throttlebody. and the fuel pressure needs to be atleast 45psi continous, and a couple pounds less while cranking. first thing to check would be fuel, then spark. if both are present, then do the pressure check. could have helped with more info.
Dec 31, 2010 | Chevrolet Cargo Cars & Trucks
I have a Hitachi compressor EC12. Motor runs okay & air pressure gets upto 125 psi, however, its not giving out any air on my output hose. what is wrong with this? I would appreciated if you could...
When the pressure reducer fails, it may leak around the adjuster or it may close as yours has. A temporary fix would be to remove the safety unloader or a tank pressure gauge and install a tee fitting replacing safey or gauge and install a quick fitting for air. You will only have tank pressure available however this is a temp fix untill you replace the pressure reducer. You do not have to replace with factory parts, there are generic parts available at Lowes or similar stores. For factory parts go to www.toolpartsdirect.com. Good luck with your repair and post again if you have other question.
Aug 05, 2010 | Hitachi EC12 Portable Electric 2hp Air...
How do i put videos on my gogear
GO GEAR VIBESMV128 x 128, 24 fps
And there is free sofware to convert it
http://www.soft29.com/freeware/smv_converter.htm
GO GEAR MUSE
MPEG4 SP/ASP Upto D1 resolution, 30 fps, bitrates up to 4Mbps in .avi and .mp4 containers
MPEG4 AVC/H.264 BP Upto VGA resolution, 30 fps, bitrates up to 1.5Mbps in .mp4 containers
RMVB VGA resolution, 30 fps, bitrate upto 1 Mbps in .rmvb container
WMV9 VGA resolution , 30 fps, bitrate upto 1 Mbps in .wmv container
GO GEAR OPUS
MPEG4 SP Upto 640kbps in avi format, 320x240 , 30fps (Other formats supported by using provided converter software)
WMV9 Upto 512kbps, 320x240 , 30fps (Other formats supported by using provided converter software)
GO GEAR ARIA
SMV220 x 176, 24 fps
Nov 10, 2009 | Audio Players & Recorders
Long crank time but always starts
It may have good fuel pressure while running or cranking over, but sounds like it is not holding the pressure in the system.
Could be a weak fuel pump, and or fuel pressure regulator.
Mar 11, 2009 | 2002 Jeep Grand Cherokee
High oil pressure on guage
I blew a head gasket and the car acted that way. . . sorry
Aug 15, 2008 | 2000 Jeep Cherokee
Frigidaire Model - FWT445GES1washer
The pipe fro the pressure switch is either blocked, damaged or has become disconnected from the pressure swtich ....
therefore it is not sensing the water level in the drum....
from your filter you will c eithet a thin black or clear tube going upto the pressure switch check it out hope this helps any questions dont hesiste to ask
Jan 21, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Campbell Hausfeld FP2095 2 Gallon Twinstack Air Compressor Logo
272 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
