The tv screen has turned green all green with a few fine white lines going through the green.thanks
  • 604 Answers
You have lost your red and blue color guns, usually all three guns are driven from one card, but somtime there are individual cards (circuit board cards) depending on the age and value of your tv you may want to have a repair man give you an estimate. These days many tv's are not cost effective to have fixed and its best just to replace them.
Posted on Mar 20, 2011
VIZIO 42 CLASS RAZOR LED SMART TV M420KD picture has lots of green ghosting and thin white vertical line through left side of screen also
Hi Charlene,
please try with video input from any device,and i think you are using local antenna and it has gain problem or your tuner section of the tv is not working correctly.
if distroted pictures comes with video input signal it is video amp and processing unit problem.
you have to go for repair shop for fix that.
regards,
nuwan
Jan 24, 2014 | Vizio Televison & Video
I gotta a green screen
It is possible that you have a shorted green CRT, you can remove the front speaker cover, and you will fine a focus block, and if you turn down the green screen voltage, very slowly, the green should turn down. if not then the gun (CRT) will have to be replace, If it does turn down, then go into the menu and turn the color are the way down and that should give you a black and white picture. If it is not black and white. adjust the red, blue, and green screen voltages until you receive a good black and white picture. Turn slowly they are touchy, and if turn to high, you will get retrace lines and the TV will shut down.
Nov 14, 2010 | Toshiba 61A60 TV
Green screen, white lines. Audio fine.
You most likely have a bad picture tube. Green gun is shorted. Usually a set this size is not economically feasible to put a new tube in. You may also have a green drive problem on the CRT board. Have a shop check it out for you before junking it. Thanks for using fixya.
Dec 05, 2009 | Philips Televison & Video
GREEN VERTICAL LINES
vertical line ic no pda 3653
Aug 16, 2008 | RCA F36650 36" TV
Vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Apr 19, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Hitachi 57SWX20B 3D Effect due to green light convergence problem
I'm trying to fix the issue on my 43FDX20B. So far, I'm able to move the lines up and down, but can't get the left/right motion to fix it. The attached link has the dynamic mode instructions, so you can correct this issue yourself.
http://home.comcast.net/~leebailey00/Hitachi_DCAM_Manual.pdf
The only thing I didn't have was the screen overlay jig the manual talks about. I decided to create one myself and use the screen as a beginning template. I went to our local hardware store and picked up some home window weather covering. The roll cost about $15, is a clear strong plastic and the template was very easy to create. I used a straight edge after I put dots on the plastic and measured the lines for being square and equal after I took it off my tv. Good thing is that if you don't like what you make the first time, you have a 25' roll to use to try again (ha).
Mar 01, 2008 | Hitachi 57SWX20B 57" Rear Projection...
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Screen goes green with white vertical lines
I think either your red and blue filaments are not fully intact causing the green to take over or you have other electronics like subwoofers too close to your tv.
Try degaussing your tv, it might have a degaus button at the back or check the menu.
If you've tried those things without luck, respond with more details.
Hope that helped.
Jan 01, 2008 | Zenith C32V37 32" TV
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
 Grubhead
Grubhead
