Question about Chamberlain Power Drive 1/2 HP Chain Drive Garage Access System - Garage Doors &
I have a sears 1/2 hp garage door opener, model 139.53525 SRT. I followed directions to erase all remotes from memory and then followed directions for the SRT to learn from the keyless entry outside wall mount remote. The light blinked correctly. When I tried to use the remote, the green "smart" light blinked several times, but the opener would not work. What are possible problems?
    Master:
  • 344 Answers
Make sure you are doing it properly. Press and hold the button on the opener 6 sec to erase it. Then hold the desired button 'on the remote' down, while holding the button on the remote down press and release the button on the opener. The opener should be synced up with the remote then.
Posted on Mar 19, 2011
How do I program my Sears Craftmans 1/2 HP garage door opener
Stacy, get a ladder and climb up to the opener. The directions are there, but typically you press a button for x seconds, and then press a button on the remote. This handshakes the two units. continue for other remotes.
Jul 06, 2015 | Sears Craftsman LiftMaster Chamberlain...
What if 1 remote is missing and i need to reset the remotes?
If you hold the smart/learn button in for 6 seconds it will erase the memory and none of the remotes will work. Now program the opener with your remaining remotes.
Jan 10, 2011 | Sears Craftsman LiftMaster Chamberlain...
Our garage door is not opening with the wall unit or remotes. When I push the wall unit I hear a click from the ceiling unit. The door operates fine manually. The green light on the ceiling unit (the SRT...
The green light on the motor unit is an LED and random flickering is normal. Your problem is most likely caused by an electrical storm or power surge. You will need to remove the logic board from the motor unit and check for burnt or missing traces on the printed circuit board especially around the small transformer. Your holding that button in will most likely have erased the memory of the unit and all your remotes will need to be programmed once you find your problem. I really suggest you call an technician at this point.
Oct 13, 2010 | Sears Craftsman LiftMaster Chamberlain...
How do I change the code for the door opener and remote. I have a craftsman 1/2 HP garage door opener. I have door door openers and one remote with three buttons.
You cannot change the code of your remote or opener. It is set at the factory. If you have lost or have had a remote stolen and need to eliminate its possible use you can erase the memory of your opener by pressing and holding the smart/learn button for 6 seconds. That button is on the back of the motor unit near where all those white wires go. Now you need to program your remote by holding the large button down while you press and immediately release the smart/learn button.
Mar 13, 2010 | Sears Craftsman LiftMaster Chamberlain...
Where to buy remote control and reset My garage door opener also
To erase the memory of the opener so that your old remote will no longer work you need to locate the smart/learn button on the rear of the motor unit. Press and hold this button for 6 seconds. No remotes will now work.
To program the new remote when you get it, hold the button down on the remote and then press and immediately release the smart/learn button.
Call any local door opener repair company from the yellow pages and you should be able to buy a remote from them.
Feb 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have model 139.53671 SRT gagrage door opener
If that is the right remote for the opener you need to locate the smart/learn button which is on the rear of your opener near where all those white wires go. Hold the button down on the remote and then press and immediately release the smart/learn button. It should now be programmed.
Jan 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Can't reset remote keypad
Press and immediately release the SRT button and then walk over to your keypad and key in any 4 digit code you like and press enter.
Aug 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman GDO 1/2 HP - Remotes not working after storm
sounds like it blew the reciever crystal buy another and return the motor thats fried 4 refund
Jul 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman GDO - Remotes not working
I think this is an easier way to program. Press and hold the button on the remote and then press and immediately release the smart/learn button on the rear of the motor unit. Do this for each remote you have.
Jul 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Power Drive 1/2 HP Chain Drive Garage Access System - Garage Doors & Logo
328 people viewed this question
Top Chamberlain Building Materials Experts
Terry Smith
Level 1 Expert
Joseph Hoffmann
Are you a Chamberlain Building Material Expert? Answer questions, earn points and help others
