Question about Fujitsu Siemens X19-1 19 in. Flat Panel LCD Monitor
Hello, I`ve got a monitor Scaleoview X19-1. Sometimes the monitor will not wake up when I switch him ON. The power LED blinks blue but nothing more. The PC is ok because we exchange it with an ACER laptop and a Fujitsu Siemens Laptop but the error is again the same. In a few cases the monitor wakes up correctly and I can work with it till I switch it OFF. Can you help me, please? Regards Lothar Ulrich Germany
5 Suggested Answers
SOURCE: Fujitsu-Siemens Monitor problem
MY LCD SIEMENS 15
I CONNET IT FROME POWER SPPLY (12 .V) IT WORKE BUT AFTER FEW MIANETS MONITOR ECIME WHIGHT WITH GROWPE LINES RED AND GOOWPE LINES BLUE COMEING AND GO QUKLY
Posted on Feb 25, 2008
SOURCE: fujitsu/siemens scenicview e-19-1 model 900p
Please excuse me posting this as a 'solution', which I rather think demands one knows what was wrong in the first place! Anyhow, I have fixed my problem with this monitor. As previously mentioned cutting JP13 didn't restore the blank display. BTW: JP13 is on the component side of the first power supply printed circuit board (PCB), its under the steel plate in the back of the monitor case, remove both plate and board mounting screws to get at it. But responding to someones previous suggestion, I went about replacing all electrolytic capacitors (caps) on this board, did this rather than just replace C10/C11 as its a bit of a fiddle to open/reclose the monitor case and I'd already done it twice by this stage and wanted to limit possible damage to cables/connectors etc by repeated dismantling of case. ANYHOW! result is that monitor is fixed (so far!), had it on soak for a week and am using it right now, so hopefully it will stay that way. Its fairly easy job to do if you have some PCB soldering experience, you'll need a small iron and a 'solder remover/******' (when removing old caps). Recommend you look at www.badcaps.net/forum for info on the capacitor values you'll need. I used recommended good quality capacitors - Nichicon and Panasonic. If anyone is interested I'll post the list of values I used but its pretty easy to extract the old caps and get the values from them. Hope this is of help, regards Phil
Posted on Nov 01, 2008
SOURCE: i have a fujitsu siemens
i have the same problem :(
Posted on Sep 05, 2010
budmrtn
  • 11361 Answers
SOURCE: Fujitsu Siemens Premium Line P15-1 15" LCD Monitor
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Dec 13, 2010
Blue Desk Light keeps blinking
not recommended but yes it might just be a loose connection or dry joint, just be carefull there are live capacitors inside which might shock you
Jul 15, 2014 | Fujitsu Siemens Monitor Sh ScaleoView , 19...
Led blue light blinking but screen is dead
Maybe your tv is asleep or snoozing. wake it up.
Mar 18, 2014 | Hitachi 32" LE32T05A Full HD LED- LCD...
Hello guys. I need help with my hp dv4 1225dx pavilion. It all started with not powering with battery power. But the battery is in perfect condition. When I plug in the power cord. It comes on and I...
It sounds like a hardware issue, if you're getting the LED's blinking when pressing power, there IS power to your mainboard (which is a good thing). Some manufacturers have placed LED blink codes within the system to let you know what's going on, but I have a feeling it's either A) your battery or B) your hardware, such as a bad RAM stick.
Try removing the battery and with the power plug connected switch the laptop on. If it works, you've got a bad battery.
Try removing a single RAM stick or replacing both.
You could search HP Pavilion LED blink codes to further address the issue.
Jul 18, 2012 | Computers & Internet
I have a dell dimension 4600 computer. I usually put the computer in sleep mode when I am not using it. Usually I press the ESC button and the computer wakes up. All of a sudden, the monitor won't...
Plug the monitor into another computer to determine if the monitor is damaged or working properly. You can also plug another monitor into your computer to determine the same thing.
May 21, 2011 | Dell Dimension 4600 PC Desktop
How do I turn it on
Hello.
To power on the Gateway VX750, press the power button on the front. The power button has 3 sides with a "G" in the middle.
The LED indicates the power status of the monitor.
  • Not lit - The monitor is turned off or does not have power connected.
  • Blinks one time and then goes off - The LED blinks one time when the monitor's power cord is plugged into an AC outlet to indicate that power is detected.
  • Lit solid blue - The monitor is turned on and active.
  • Blinking blue - The monitor is in power saving mode. Before entering power saving mode, a message briefly appears.
Hope this helps.
Aug 12, 2010 | Gateway VX750 (Black, Platinum) 17" CRT...
No powerr
If the led comes on for an instant and then faints quickly, leaving the TV with no led, no blink code, and no power at all, then the fault is usually concerning the PSU board, or the power connection. If you already replaced the cable, the next step is looking for bad solder joints on power cord connector, and then testing and eventually replacing PSU board.
Jul 07, 2009 | Televison & Video
Monitor does not wake up.
Check the inverter and backlight bulbs.
Mar 27, 2009 | NEC MultiSync LCD1550VM 15" LCD Monitor
Samsung 226BW Monitor
What about the blue circle LED on the power button ? still blinking or not ?
For the record I've had some problems with this screen too, sometime I had to unplug and replug my Video Card (and the DVI Cable) and everything was back to normal
Hope it helped you
Nov 07, 2008 | Samsung 226BW Monitor
No picture; power LED blinking amber/green 2-2-2-2...
You can TRY to look for cold solder at the board esp popwer section.
Apr 24, 2008 | NEC AccuSync 120 (White) 21" CRT Monitor
Dell P1110
Hi, The part where you see some color bars and blinking green led is what we call MONITOR SELF TEST. A diagnostic pattern consisting of four colors (red, green, blue and white) appears, and the LED flashes slowly. this happens when signal cable from the monitor is disconnected from the tower and leaving the power chord for the monitor plugged in. If the monitor works properly on a different computer. then its a problem with the computer's video card sending out signal. im 85% sure that its a problem with your video card.
Oct 02, 2007 | Dell UltraScan P1110 21" CRT Monitor
Computers & Internet Logo
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
