Question about Broderbund American Greetings Creatacard Platinum 8 for PC
I'm buying a new computer with windows 7 operating system. My old computer has Windows XP . I have American Greetings Creata Card Gold 3 program which I absolutely love, and also American Greetings Creata Card Platinum 8 program which I also use. Will I be able to download these two programs on my new computer. I would hate to lose them. Please reply. Thanks
    Sniper:
  • 95 Answers
Windows 7 professional and Windows 7 Ultimate have a "Windows XP mode". It may work without it but if it doesn't just use Windows XP mode. Which you can download here.
Posted on Mar 19, 2011
    New Friend:
  • 18 Answers
Actually you will need two programs:
1: Windows XP Mode
2: Windows Virtual PC
More information is located here
You will need to make sure under the Windows Virtual PC you select the correct version.
The Windows6.1-KB958559-x64-RefreshPkg.msu is for Windows 7 users using 64bit edition.
The Windows6.1-KB958559-x86-RefreshPkg.msu is for Windows 7 users using 32bit edition.
The XP Mode will work under either 32bit/64bit editions.
Good Luck!
Posted on Apr 18, 2013
  • FBlawat Apr 14, 2014
    Here is another option to try if you do not want to try the Windows XP mode under Windows 7.
    Micrografx Creatacard Gold 3 was created back in the Windows 98 days and most likely the installer is a 16-bit installer. Windows XP worked OK with 16-bit installers, but Vista, Windows 7 and Windows 8, 8.1 will not work. There is a work-around I found ( I actually found this fix for installing Photoshop 7 under Windows 7) and it works! I was able to install Photoshop 7.0.1 under Windows 7 Pro x64 edition and it works great! Perform a search for Install-Photoshop-6-or-7-on-Windows-7 or go to this websitehttp://www.wikihow.com/Install-Photoshop... Under this website, Look at Method 3 of 3 . Stuff you will need: 1. A working Windows XP -SP3 system where you can install the Free Scalable Smart Package. You may be asking why? You will need to install the Micrografx Creatacard Gold 3 on this system with the "Discovery Program" running so it can create a new 32-bit installer 2. A CD-RW or a Memory Stick where you can copy the new .MSI file created and run it from Windows 7 x86 or x64 bit system. 3. Download the Free Scalable SmartPackager program. This used to be called WinInstall LE but they have since changed the name. You can find the program herehttp://www.scalable.com/smart-packager-c... This is Free, but you still need to register to get the software. The latest version as of last week is v2.0.2. 4. Printed out instructions from the website so you can follow along. Once you perform this, you may end up trying this for other "older" software as well. Basic Overview: 1. Under your Windows XP - SP3 system, install the Packaging software called Scalable SmartPackager v2.0.2 2. Once you have installed the SmartPackage program, it is a good idea to Reboot your system so all files get updated properly. 3. Start the icon called Smart Packager. 4. Under Smart Package, make sure you are under the Welcome screen and click on the Discover a new Package under Common Tasks. 5. When the Blue Discovery screen pops up, click on the Next button 6. Under the New Package Information screen, type out Creatacard Gold3 or something that you like 7. Under the Output Folder, Click the Browse button and select a folder or location where you want the new Creatacard Gold3.msi to be saved. Make sure you click on the Show advanced Options box below and Then Click Next 8. On this screen, you will now need to Click on the Start Discovery. This is what the SmartInstaller program will use to see where all the files are being installed to, etc when you run the Creatacard Gold 3 installer. 9. Insert the Micrografx Creatacard Gold 3 CD in the drive and install the program like you normally would. Please remember to install any of the Extra Free fonts as well during this time since this will be the only time you will have to create a new 32-bit installer (unless you run this process again) 10. After the Creatacard Gold 3 program has installed, verify it is working by Running the program and testing out various things within the program. (This is while the Discovery is still running in the background) 11. Once you have verified the Creatacard Gold 3 program is running properly (under the Windows XP system) then go back to the Discovery window and click on the Red Stop Discovery button and then click on the Next Button. 12. Make sure the Add new package to Smart Packager is checked and then click on the Finish button. This will now save the new "updated installer" MSI file over to the folder location you specified under option 7 above. 13. Copy this new *.MSI file you just created and either burn it to a CD-RW or copy to a Flash drive and take this file over to your Windows 7 system. Please note, these instructions are an overview and may not contain the entire correct order. The last time I performed this was back in January 2014 when I first discovered the article about using Scalable Smart Packager to re-create an installer file into a true 32-bit installer. For me so far, the installer has worked with Photoshop 7 and several Photshop plugins like KPT5, KPT7, etc. I make no guarantees that this will work in your situation but it could not Hurt. Plus, should you have problems removing this program I would recommend you try this Free program called Revo Uninstaller v1.95. This is Free for Home/Personal use only. Hopefully you can use the above instructions I provided and get this great program to work under Windows 7. Please let us know if this process worked for you or not.
How can I load CreataCard Gold 2 on windows 7
I have American Greetings Creata Card Gold, which my computer states that it is not compatible with my program, is there an updated program?
Aug 08, 2011 | Broderbund American Greetings Creatacard...
I have windows 7 I uses creata cars gold in my old computer but now it won't run in windows what do I need to do
You can either upgrade to the latest Broderbund greeting card software. (See this site for a list of all the Broderbund Design and Print products: http://www.broderbund.com/c-6-design-print.aspx . You may not be able to import old projects into the new software.)
Creata Card Gold 8 was for Windows XP and older OS versions. I suspect the compatibility mode will not work but you can try it. Right click on the installer. Then choose Properties and then the Compatibility tab. Turn on Run program as Compatible with the appropriate OS. Then right click again on the installer and choose Run as Administrator. Then check if the program itself is running in the compatibility mode by right clicking again and choosing Properties. This is more likely to work if you have Windows 7 32-bit.
I do not know if this will work. A method that will work is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software from your CD in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them to print them. A printer can be installed to either the real or virtual machine at a given time. You will be asked to uninstall the printer if you try to install it in the virtual computer with it installed on the main computer.
I hope this helps.
Apr 04, 2011 | Broderbund American Greetings Creatacard...
I have American Greetings CreataCard Platinum 6. Windows 7 will not complete it. Sometimes I can skip quickly and get it to make a card but it is definitely not responding properly. What can i do? I...
You are may need to use compatibility mode for this program. It was originally intended for use on windows 98/Me/2000 and XP. To set compatibility mode to any of those operating systems, right click on the American Greeting shortcut (the icon you click to start the program) and select "properties". Now look for the "Compatibility" tab and click on the check box for "Run this program in compatibility mode for:" and in the drop down box, select "Windows XP (Service pack 2)" Or, "windows XP (Service pack 3). If there is no service pack options for windows xp, that's fine. After you made your selection, press ok. If the program works, you're set. If not, go back and change the compatibility mode operating system to another choice such as "Windows 98" or "Windows 2000". Try each one and see what works for you.
Mar 29, 2011 | Broderbund American Greetings Crafts! and...
My creata card gold 3 does not work in my new window 7 How can I correct this, I am afraid to download a new driver for fear of crashing. TY Ria
Try changing the compatability. Right click on the desktop shortcut for My creata card gold 3 and choose properties from the menu that right-clicking opens. This will open the properties window. There are three tabs near the top labeled "general", "shortcut" and "compatablility". Click on Compatablility. Check the box marked "run this program in compatability mode for:" When you check the box, the drop-down menu below will light up and you can select the system you used previously.
Jan 19, 2011 | Broderbund American Greetings Creatacard...
I have the creatacard gold 3.0 cds and a new pc running windows 7. CC Gold 3.0 is not compatible with windows 7 64 bit . Can you help?
yes can be, just follow these steps:
Not compatible or not working well with windows 7?
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))
Nov 28, 2010 | Broderbund American Greetings Creatacard...
Would the Broderbund American Greetings Spiritual Expressions 7 be compatible to Windows 7? And does this CD have the same spiritual pictures as the American Greetings Spiritual Exressions that I bought...
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
Aug 21, 2010 | Broderbund American Greetings Spiritual...
My Creata Card Gold does not work with windows 7
you will have to go to the creata card web site and download the version for 7 and install your serial number in place of the one you had for windows.As long as you enter your name and adress in the system it will auto update.
Jul 14, 2010 | Broderbund American Greetings Creatacard...
Is there an upgrade for American Greetings Creata Card Platinum 8
You can try to right click the setup.exe file and select properties. Next select the compatibility tab and choose Run this program in compatibilty mode and click the drop down to find the version of XP that you think it will run in and the program will install and run in its own memory space and work in VIsta. Don't worry about any other settings on that dialog box. No need to buy a new copy. Now if the program has been installed and won't run, you can right click the shortcut and perform the same steps.
Jul 16, 2009 | Broderbund American Greetings Creatacard...
Broderbund American Greetings Creatacard Platinum 8 for PC Logo
1,058 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Alun Cox
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
