Question about Cascade Faucets Plumbing
How do i take apart my cascade lav faucet to replace the ceramic cartrige? there is no screw or anything.
    Sergeant:
    Champion:
  • 239 Answers
You don't say which model it is but most of these type of faucets are lever operated. If you look under the lever you will find the hot/cold (blue/red) guide. If you carefully pop this out using a small flat blade screwdriver you will find a slot for a hex key underneath. Undo the hex key and the lever unit will lift off. next you need to remove the cowl and then you can undo the large nut underneath to access the ceramic cartridge
Posted on Mar 19, 2011
Replace ceramic disk cartridge
First shut off water to the faucet. Most faucets have a screw on each hot and cold handle, remove the screw, then remove the handle. Now you should see a large Nut around the faucet stem, remove the nut, then the stem can be removed. Depending on the faucet you have, the ceramic disk can be replaced. Most faucet companies give a lifetime warranty on the disk, so you can order a new one for free if you have the warranty papers of the faucet, if not, you can usually get new parts on line, or at a plumbing store.
Nov 23, 2013 | Globe Union Glacier Bay 8 In Double Handle...
My k-12265 lavatory faucet hot side is dripping from the spout
You probably have a faulty seal in the valve. You will need to take apart the faucet and determine what seal is bad. Contact the manufacturer or a local hardware store to see if they have a replacement valve cartrige for your faucet or individual parts.
Sep 12, 2013 | Kohler Plumbing
How to fix leaky American Standard single faucet kitchen sink
The A-S single lever kitch faucet is terrible. If it is the one I think it is, then it has three screws that mount the cartridge down into the faucet body.If these are not torqued perfectly evenly, the faucet leaks. I suggest getting a Moen to replace it.
Apr 18, 2017 | American Standard Plumbing
Lav center set faucet handle removal model K10271
The handle may be secured with a set screw in the body of the handle that must be loosened before the handle will lift off the valve - the set screw will require an appropriately-sized hex (or "allen") wrench. If you cannot find a set screw on the handle, then the handle is friction fit - in which case no tools are required, just a bit of force to lift the handle off.
Hope this helps. Post a reply if you need further assistance.
DIYpro
May 17, 2011 | Kohler K-10270-4A-G Forte Centerset...
The faucet drips and I cant figure out how to make it quit.
It can be repaired without taking entire valve out of wall. First shut water off and remove handle. Next you will see a collar that will screw off to remove the cartridge below is a link for a single handle moen faucet. Check it out to get an idea. If you know your model you can research on line ,but they are close enough to give you an idea.
Once appart replace washers or o -ring's. Pay attention to how you take it appart for easy reinstallation.
http://www.moen.com/shared/pdf/t2703pt.pdf This link is aparts breakdown of a single handle faucet.
http://www.moen.com/shared/pdf/t2703pt.pdf This site is installation instructions.
http://www.efaucets.com/detail.asp?Product_Id=T2703 This site you can enter you faucet model to retrive information.
Jun 19, 2010 | Moen & One Handle Tub & Shower Faucet
My daughter pushed down on the plug & now it doesnt pop up!! lever at back doesnt work as the suction is so good!
drain assembly can be taken apart from under the lav. first loosen the stopper lever assembly. then proceed to loosening up the slip-nut on piping nearest to the drain. The drain is held to bottom of sink by a nut tightened to a thick rubber washer. Remove nut and remove drain. Dislodge stopper. Replace drain with fresh plumbers putty, underneath lip of drain where it makes contact with inside of lav. Reassemble drain piping and lever.
Mar 16, 2010 | NRS Cascade Brix single hole lavatory...
The cartrige inside my moen faucet leaks
moens website. they have parts break down and diagrams
Nov 30, 2009 | Moen F7425 Chateau Single-Handle Kitchen...
Cannot get the cartridge out of the moen sh lav faucet..no cartridge tool, what can I use to get the cartridge out???
There is a small U clip that holds the cartridge in. It just slides up or down. Some Moen cartridges are very difficult to remove, they can be corroded inside "almost fused" it is best that you get a moen cartridge puller. Lowe's has them. If you decide to tackle this job make sure the water is off, and when you pull the cartrige remember the direction it came out. If you put it in backwards your cold will be hot, and your hot will be cold!
Jan 24, 2009 | Moen & Villeta Two Handle Lavatory Faucet
Leaking kitchen faucet delta saxony 473-sd.
on top of the on off handle ther is a little cap pull it off un screw it carefully take apart the top once u see the top of the cartrige carefully pull it out and replace it and it should stop the leak
Jan 24, 2009 | Delta 473-SD Saxony Single Handle Kitchen...
Plumbing Logo
169 people viewed this question
Top Cascade Faucets Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Cascade Faucets Plumbing Expert? Answer questions, earn points and help others
