Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
What's the best way to clear Clogged up intake tube?
  • 784 Answers
The best way to clear the hose is to use a wire coat hanger to fish out the debris ( bend the wire straight and then bend a small hook in one end ).
also make sure you remove the floor plate and fish out that hose area.
c...
Posted on Mar 19, 2011
Model 6500sr cuts off at highest control setting even with new bag, what could be causing this problem?
First, turn dial on top of vacuum counter-clockwise so the smallest dot lines up with the arrow. See if it stays on. If not, detach hose and turn vacuum on. Place palm of hand over intake. If it turns off, it's possible that the tubes connecting to the CVA are clogged and simply need cleaned. This is most often caused by using "made to fit" Electrolux bags. Dust is sucked through the bags and into the motor compartment of the machine. All interior parts get covered in dust and need to be cleaned. If this is the cause, the vacuum is best cleaned and repaired at an authorized Aerus Electrolux store. If the vacuum shuts off, or won't turn on before placing hand over the intake, it's probable the control valve assembly is bad and needs replaced.
Another cause is an overheated motor due to clogged screen at back of bag well, full or clogged bag, dirty afterfilter, bad wiring/connections, clogged hose, clogged power head, or bad motor. It depends largely on the type and model of cleaner. Clogged wands are also a possibility, but unlikely.
Check and clean screen at back of bag well.
Replace bag. Make sure it's a genuine Electrolux bag made by Home Solutions.
Check and replace afterfilter if necessary. These should be replaced after every six bags.
Broken and worn wiring connections are often found in the hose ends due to abuse and normal wear and tear. You can check the continuity of the hose using a continuity tester or multi-tester. If a multi-tester, turn dial to one of the Ohm settings. Place one probe into one of the terminals on the end of the hose. This will be referred to as T1. Touch the other probe to each of the terminals/connections on the other end of the hose. These will be T3 and T4. One of them should read zero, the other should read infinity. Repeat this with the other terminal, which will be T2.
Drop a marble in one end of hose and let it roll through. If it doesn't roll through, the hose is clogged and needs to be cleared. Plug hose into the exhaust port of the vacuum, place other end in the in port. Turn vacuum on. This provides a blowing and sucking action which should clear the hose.
Detach hose from power nozzle (PN). Drop a marble into the wand end of PN. If it rolls through, it's clear. If not, there's probably a clog behind the brush where the intake opening is. You may be able to reach this through wand end with needle nose pliers, or either end with a knitting/crochet needle or a bent coat hanger.
If none of these "fixes" provide the answer to the problem, it should be taken to the nearest Aerus Electrolux store for diagnosis. Repairs or checks involving disassembly of the vacuum should always be done by an authorized Aerus Electrolux service technician.
The store nearest you can be found by following the instructions at the below listed link:
http://www.aerushome.com/storelocator/
Mar 17, 2011 | Electrolux Epic 6500 Vacuum
Does not turn on epic 6000
Feb 27, 2011 | Electrolux C101 Bagged Canister Vacuum
I install a new bag and the bag light comes on and the unit turns off.
Feb 19, 2011 | Electrolux Lux 7000 Bagged Canister Vacuum
The vacuum cleaner is not "picking up or vacuuming dirt, etc." I removed and checked the tube, etc. and it's clear (no blockage). I did notice that residue, etc. is blowing out at the base where...
Things to check.The fan scroll is what the handle tube goes into.Remove the tube and inspect the scroll for a clogg.Also inspect it for a crack,you may want to remove the bottom plate to do so.Look in the roller brush area for the intake hole into the fan it could be clogged there.If the bag inflates you do not have a clogg if it dosent you have a blockage somewhere.if you havent checked remove the bag it can also clogg up right where it attaches to the tube.It sounds from your description that you have a blockage. www.sewvac.com
Jan 28, 2011 | Oreck Vacuums
Changed bag and filter, filter light keeps coming on, not working
Jan 12, 2011 | Electrolux UltraLux 2000 Bagged Canister...
I have an electrolux 2100 it wont turn on
Jan 05, 2011 | Electrolux Vacuums
Keeps opening as if the bag is full. HOw do I fix this.
Dec 28, 2010 | Electrolux Lux 5500 Canister Vacuum
Suction when I vaccum the floor but not in the hose
remove the filter from the dirt cup and try again,if you have suction the the filter is clogged.the other is the intake hose that goes into the top of the base where the clear tube is.disconnect the hose from the base tube and take a coat hanger and bend the end into a hook.open the litte flapper door and stick the hanger down in the tube and see if you can pull out a clog of dirt.last but not least,disconnect the top hose completelyfrom the vacuum and see if you can blow through it.if you can't then the flex top hose is clogged.open the little flapper door on the top of the base and turn on the vacuum,if the intake hose isn't clogged then you should have suction.that will tell you that the broblem is in the flex hose or the filter
Jun 07, 2009 | Dirt Devil Featherlite Bagless Vacuum...
I have a Dirt Devil Vision and when I put a clean canister back in place the suction at the bottom of the filter clogs up and very rarely go into the canister. Also where the air blows out of the motor, I...
yes your intake hose is clogged thats the clear hose you can see it on the bottom from the back.disconnect the upper hose from your intake hose and try to push a coat hanger through with the end of the coat hangers end bent till its rounded so you don't puncture the intake hose
Jan 05, 2009 | Dirt Devil M086700 Vision Bagless Upright...
No suction
check the belt or the inside tube between the bag and the brush
Aug 11, 2008 | Dirt Devil M086700 Vision Bagless Upright...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
57 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
