I have a sanyo digital tv for 2 years. I moved it (unplugged tv) and now can't get any channels. I have tried hitting reset x2 and having it scan for channels but nothing is working. I have moved it in the past and was ok, but not this time.
  • 26 Answers
Make sure you have other end of cable connected to aerial/cable or tv distribution.
Posted on Mar 19, 2011
Where is the reset button
Sanyo Service Menu - Factory-Reset.com
factory-reset.com/wiki/Sanyo_Service_Menu
Jump to Sanyo TV Service Menu Method 2 - Unplug the power cable. Press and hold the {VOL -} button on the TV while plugging the power cable back ...
Sanyo TV reset button location? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 27, 2007 - Does anyone know where to find the reset button on a 32" Sanyo TV? The thing is just totally dead and I am thinking maybe if I push the reset it ... I have a Sanyo TV, I accidentally hit the reset button twice. I ...
Aug 6, 2012
36 inch sanyo tv won't change off video 2?
Apr 17, 2010
I accidentally hit the 'reset' button the remote of my sanyo tv ...
Jan 6, 2010
Sanyo DS32224 TV Problem!!?
May 21, 2009
More results from answers.yahoo.com
Nov 29, 2015 | Sanyo DS31520 31" TV
Why did I lose my analog/digital channels?
Tuner fault. Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 11, 2014 | Sanyo DS31590 31" TV
Hi - I have an older model Sanyo 14" tv (?1994/5) that has probably less than 100 hrs use -- Model #DS13530 - the channel does not hold to a specific set - it wants to continuously scan through all...
This sounds like a capacitor fault, although I would not know which one. Most likely in the power supply. You Could try switching on and leaving on for a little while, ie about two or three hours. This may charge this capacitor up.
Alternately, you should take it to a TV engineer to have it fixed.
Hope this helps.
Apr 14, 2011 | Sanyo Televison & Video
I have an older Sanyo (approximately 8 years old) and my remote control is damaged (only the buttons/controls on the right side are working, volume turns up but not down, most of the left keys do nothing)....
If you are feeding the signal from your digital converter into the TV antenna input, I would input the converters signal to the TVs video input instead. I am assuming your converter has a video output signal and left & right audio so you will need cables for your audio also. If your converter has only rf output for the TV tuner input it is generally on either channel 3 or 4 and there may be a switch to set this. It is possible that when the TV scanned for channels the converter was off and it did not find a signal on 3 or 4. If you can get the TV to re-scan, be sure the converter is turned on and on an active channel. All your channel selection should be via the converter after that and the TV simply stays on 3 or 4. I would suggest looking in to getting the original remote. Try partstore.com and see if they have one for your model.
Nov 18, 2009 | Sanyo DS27930 27" TV
Vizio 37L suddenly stopped getting all digital channels
I had the same problem with my 42" vizio. Was working fine for about a year and a half, then a month after all stations went digital, I couldn't see any digital channels and it wouldn't scan for digital signals
This is a strange go around, but it worked for me. . Tried unplugging, pushing power button for two minutes... did everything the forums suggest, with no resolve. But, here's what DID work for me. Trust me, it sounds strange, but it continues to work (and, yes... it's not a permanent fix... the channels still go out once in a while, but I can always get them back now)
Use your Vizio remote control. Turn your TV on. Press the "input" button until you get to "RGB", which is what you would connect a computer to. Make sure no computer is connected, or it's at least off if it is connected. When you get to RGB, you'll see a message that says "No Signal". After about 5 seconds, the TV will enter a sleep mode and seem as if it has turned off (orange Vizio logo). Once it completes it's little sleep cycle and "clicks" off, wait a few seconds and hit the input button again. It'll go to the next menu item. Keep clicking input until you're back on "TV", and VUALA! The channels are back!
I accidentally figured this out when trying to troubleshoot, but I'm glad I did. Didn't want to dishout $250 to get it fixed. Let us know if it works for you too!
Jun 15, 2009 | Vizio VX37L Television
How to get the dell 4200 ed to pick up digital channels
there are 2 coaxial inputs on the back of your tv. plug the antenna into the digital coax. with your remote, do a fac reset: menu, setup, fac reset, all settings, passcode 3355. after the reset, hit input, select digital tv. perfprm a chan scan: menu, setup, channel scan, antenna. this should solve the problem.
Feb 09, 2009 | Dell W4200 42 in. HD-Ready Plasma...
Digital conver. on 2/17/2009
This TV comes with a dual tuner uhf/vhf in and digital antenna in .hook to digital antenna input and change input on remote to dtv hit menu and let it scan for channels.
Nov 15, 2008 | Sanyo HT32546 TV
Ds3224
push reset on remote twice quickly
Jan 05, 2008 | Sanyo DS32224 TV
My Sanyo Tv (model dp327460 is Busted
You should try and download the users manual if you do not have one...I remeber seeing in it that after hooking every thing up, you have to do the channel search twice before the unit will work properly..This is highlited in the manual with correct hookup diagrahm..
Jun 30, 2007 | Sanyo DP32746 32 in. LCD Television
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
