Question about Maytag Atlantis MDE7400AY Electric Dryer
Hi, My Maytag Atlantis MDE7400AYW is making a noise. It is the front of the drum ribbing on the front of the laundry opening. I pull back on it a bit and the rubbing noise stops. I ran it with the front off and it also does not make noise. I put the unit back together and then it rubs? Can you help Thanks, John
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Mar 20, 2011
My Maytag Atlantis MDE7400AYW does not start when I pull the knob and I cleaned the sensor and connection and pulled the panel and checked the connection on the board the damp indicator light comes on but...
There are a few different scenarios which would cause the dryer not to start. First, make sure you door switch is functional. Second, the white thermal fuse, located on the exhaust housing may be open. Worst case scenario would be a defective timer or motor. Either of these may not be cost-effective to replace.
Mar 06, 2014 | Maytag Atlantis MDG7400AW Gas Dryer
Replace blower belt
unplug it,open the door,remove the two phillips screws that hold the door on and remove the other two on the other side,remove the door and pull the front panel off,just tilt the top of panel out,remove the four 5/16 inch screws that hold the front bulkhead on,then remove the top screws and the L bracket on top,remove the front bulkhead,pop off the metal wire holder on the right side and stick the bulkhead on the right side of the machine so you can remove the drum,lift the top panel up a few inches and slide out the drum,you'll see the mark on the drum from the old belt,put the belt on the drum ribs down against the drum,slide the drum back in,grab the belt,put it under the belt pulley,pull the pulley over to the motor and connect the belt on the motor shaft,put the dryer back together the same way you took it apart,you'll notice two short screws,they go into the holes that have a space around the hole,one goes in the bottom and then the other opposite side up top.hope this helps.
http://www.youtube.com/watch?v=1eeJvqhHEYY
May 16, 2013 | Maytag Atlantis MDE6400AY Electric Dryer
One of the three things that tumble the laundry in the dryer is loose--it is making alot of noise--how do I tighten it
I think you are talking about the large ribs that prevent clothes from just sliding in the drum.
They are available as a spare, so are usually screwed in from outside the drum.
To fix your problem, turn off and unplug dryer.
Remove back pannel screws holding the lid on, and slide back the lid.
Rotate the drum by hand internally untill the faulty blade is at the top. You should be able to see the screws that need tightening.
Replace parts when finished.
Sep 29, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Need help replacing dryer belt on Maytag MDE9306AYW
Hi, Remove the screws in the door opening. Two screws hold the door hinge but, the door will stay in place. Once you get the screws removed, the front panel will lift off. Once you get the front off, you will see the drum and what it will take to thread the belt around it. Make sure the rib side of the belt is touching the drum and the ribs need to set into the ribbed pulley on the motor. The idler puley is spring loaded and will need to be moved with one hand while you thread the belt with the other hand.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 27, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE7400AYW timer has been replaced but the dryer won't stop drying on it's own. What is the reason? I have the same problem... the timer on mine doesn't seem to work. Any ideas?
The wire connections to the timer may have not been made correctly when it was replaced bypassing the OFF contact in the control circuit.  There should be a wiring diagram inside the front or back panel that you can check.
Jun 02, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
I pull the knob on dryer Maytag MDE7400AYW and it won't start.
yeathe start switch is bultdirrectly into the timer assembly youll need to replace the timer.
Feb 17, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis dryer mde7400ayw won't run
I believe this last one has it right. the timer may be bad or worse, the board could be bad.
Jan 15, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis
UNPLUG DRYER, 220v is not fun
You get in the back of the dryer, from the front.
maytag dryers have two screws in the curve of the bottom of the front panel. (Note:screws may be torx-secure screws, cut a slot in them and use a flat screwdriver or pick up a torx-secure #20 bit at a tool shop, star shape with a pin in it)
remove the screws and the front panel can be swung up from the bottom and unhooked.
unplug door switch wires
reach under drum, for belt tensioner, pull belt off tensioner. and motor pulley
lift drum up and slide out forward
under drum are 2 rubber tired rollers, check for free motion, replace both if either is seized
the drum has felt bushes on it
examine felts for wear, replace if worn.
ensure all felt and adhesive is scraped from drum before fitting new felts, if there is any left, it bumps/thumps and knocks every rotation (best adhesive is Hi temperature red silicone)
use 2-4 pairs locking pliers(visegrips) to install felt
  • put adhesive on drum edge
  • clip felt in place at one point with visegrip
  • pull felt around drum, clipping in place as you go
  • let sit in clamps till adhsive sets
reassemble drum in reverse order
38d7d07.jpg while you got it apart is a good time to clear any lint from exhaust vents and squirrel cage fan,
felts last cost $30/pair rollers $9/pair
takes 45 minutes now to change felts, I do rollers while the adhesive sets, had a lot of practice, replace the belt, cost is minimal, it has been *****ed pulling the drum against the worn felts or rollers, and will break soon, dont want to open up again
Aug 29, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Removing Timer Knob on Maytag MDE7400AYW dryer
Can anyone help me? I have a Maytag Atlantis that my parents just gave me and my wife. Unfortunately, they accidently removed the model number sticker in the door area. I need to buy a new timer but no one can find which timer to get without the model number. Via the internet, I think I narrowed it down to either the MDE7400AYQ or the MDE7400AYW....but they both look identical to me. Can anyone tell me what the difference between the two is so I can go get the part?
Mar 03, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
121 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
