Question about Desa International GWRN18 Infra-Red Wall Mounted Panel Heater
The flame is orange and I noticed it was running high and when we leave it on one burner it wants to shut off. I have dusted and cleaned it and it didn't improve it. Now when we go to light it usually you only have to hold the knob down a couple seconds. Now it is almost impossible to light...
    Brigadier General:
  • 4,736 Answers
Sounds like thermocouple is part of the problem as it relates to lighting the heater. Overtime, they do become pitted or corroded and should be replaced. As far as the orange flame when running on high is concerned, it sounds like the air intake valve on the burner is partially clogged with dust or lint. I realize you said, "I have dusted and cleaned it and it didn't improve it" But, if you didn't take the front of the heater cabinet off and cleaned all if the interior (including the burners, the plaques, the pilot and the interior walls of the cabinet), your cleaning wasn't sufficient. A Shop Vac with a hose, brush attachment and crevice tool works real well to help you accomplish this. Also, a can of compressed air with a straw nozzle (like you clean your computer with) will aid you in cleaning the pilot orifice and the Oxygen Depletion Sensor (ODS). To further assist you, I have included a link to your Owners Manual (in case you have misplaced yours) that you can download and print for future reference.Be sure the heater is cool and the gas has been turned off to the heater, before attempting to clean the heater.
http://www.desatech.com/manuals/Vent-Free%20Heaters/107885-01.pdf
Hope this helps you to solve the problem.
Posted on Mar 19, 2011
Orange flames on two Blue-Flame heaters, dual fuel, currently running propane.
Could be that the burner needs cleaning dirt in the burner tubes
Nov 02, 2012 | Blue Flame Heating & Cooling
Is this yellow flame on my grill ok?
Clean out burner holes on all the burners they look blocked , then adjust air mix to burners could need more air to burn
Jul 23, 2012 | KitchenAid KBGS364PSS Grill
Our Uniflame Grill has a round outer burner and a round inner burner. The outer burner has a large orange/yellow fllame. The inner burner has a small blue flame. Is it normal for the inner burner to...
Bob, your wife is partially correct. However, both burners should have blue flames with orange tips. Cleaning the burners and the their venturi valves, should solve the problem. When I say cleaning them, I mean removing and cleaning them.
Hope this helped you and Happy Grilling!!
Jun 27, 2011 | Uniflame FG2204C Grill
Rheem RTG-64DVN model, brand new unit installed during the weekend. fired up but shout down automatically within about 5 seconds. showed error code 12.
contact your gas company if the error code is "12," indicating that the gas supply was interrupted.
have a good day !! In LP models, the 12 error code may also appear if the LP gas supply has gotten low. To clear the code, replace or refill the LP gas supply.
go here for a list of codes for rheem tankless water heaters-- www.ehow.com/list_7833182_error-rheem-gas-water-heater.html
May 09, 2011 | Rheem Tankless Hot Water Heater...
Set thermostat to auto switch unit to heat. Unit lights runs for a minute then shuts off. Fault light blinks4 times, msg. Open high limit.
Check air filter for blockage, clean off flame rod found in the flame pattern of the last burner that ignites, check high limit switch with multimeter to see if good (found above the burner box). Make sure room air blower turns on within 90 seconds of first flame.
Nov 28, 2010 | Goodman CLQ36AR49 Air Conditioner
I have a propane heater that sits on the tank and has the ceramic plates for dissipating the heat. Instead of a nice blue flame, it has a lot of orange flame. Why?
I would shut off valve to heater and remove it from propane bottle. Carefully clean with soft bristle brush and blow out with medium pressure air. Reinstall and light heater and see if flame quality has improved. Often dirt,dust,and lint can build up in burner and cause fuel to not get good enough air to fully combust. Hope this helps you.Thanks
Nov 12, 2010 | Mr. Heater F191824
The flame does not go all the way across and the high limet shuts it off
The flame does not go all the way across the burner
and then shuts off. Sounds like a regular furnace, on the left hand side of the burner is a flame sensor.
Get some sand paper/cloth and clean the metal part
of the flame sensor
Jan 07, 2010 | Heating & Cooling
Kenmore twin burner.. orange flames
A <i>temporary</i> orange flame from your gas stove can also occur at peak usage times. An increase in local demand can cause a decrease in pressure in the natural gas line. If all of your gas appliances are in combustion simultaneously, this may also cause a drop in pressure, especially in older houses. If the problem persists, it is likely a dirty/clogged burner or the stove needs servicing. In general, an orange flame (on a gas combustion appliance) means incomplete combustion and carbon monoxide production.
Research Design Studio
Jul 06, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Gas burners ignite then shut down
I need your model number to be sure, but I sounds like a flame sensor. If you have a hot surface ignitor(orange glow device) then in the same area there should be a small single wire sensor that sits in the flame Remove and wire brush the end and try that.
If you have a circuit board count the fast and slow flashes after it fails 3 tiimes and this will make a code
Nov 19, 2008 | Ruud Matching Split Air Conditioner
Desa International GWRN18 Infra-Red Wall Mounted Panel Heater Logo
52 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
