Question about Kitchen Ranges
Hello I've broken the glass top on my stove model GRCR3965ZSS-1. I'm trying to find a replacement top for it and can't seem to find one. Could you point me in the right direction? Thanks for your time. D
SOURCE: Replacement of glass top
Just a note when you're doing this... when you open up the top, put a towel across each side so that when you drop a clip, it doesn't go down the side between the oven and the outside wall. If it does, hope that it goes all the way to the bottom where you can get at it by removing the bottom drawer. If you put the towel all the way across the oven box before you start taking things apart, you also won't have to worry about where little tiny screws go when you drop them... and, you will drop them! ;-)
Also, the old tops had a reinforcement bar that the ground was attached to. The new ones don't. There's a tiny hole on the flange of one of the right hand burner holes... that's where the ground is supposed to go on the new top. You WILL need a smaller self tapping screw than the original one.
And, forget having a helper... get something to prop the lid open with that won't fall if you raise the lid a little while you're working on it. Helper will just get in the way and can't hold it still enough while you''re trying to man handle those tiny little clips and screws that hold the burners in place.
--Jeff Moden
Posted on Oct 25, 2008
appldoctom
  • 311 Answers
SOURCE: Broken glass top range
im sorry about that.i have replace many of those running around 400$,that a lot of money.i have see glass top stoves on sale 4 that much.and i think they all are about the same as quilty goes.God bless,tom
Posted on Jan 02, 2009
appldoctom
  • 311 Answers
SOURCE: replacing glass top on stove
its not too bad.kill the power.then under the frount of the top where the top meets the oven door .under there are screws remove those and the top lifts up as on hinges.their is a ground screw wire to loose and unplug the the wire harness that connects the burners to the rest of the stove.then all is disconnected so lift entire top off from hinged area and set upside down on table.transfer all burners to new top thats nexted to old one upside down also.when done reinstall.ive done lots wont be bad.please dont for get to help me with my rateings.God bless ,tom
Posted on Jan 05, 2009
DeBruce
  • 145 Answers
SOURCE: Having trouble cleaning splatters off Ingis Glass Top Stove.
Use DeBruce Polish- a true multi-surface cleaner. There is a transfer of particulates from pan to glass surface aided by the heat. The cleaner will remove this "staining". Also use on stainless steel rubbing with the grain- this is the one product that truely cleans the surface. Follow up with baby oil or a stainless steel "polish that is oil based to "seal"the surface.
debrucepolish.com
Posted on Mar 07, 2009
  • 105 Answers
SOURCE: Maytag Electric Ceramic Glass top stove
You can replace the failed component which is either the burner or the switch that controls the burner. A voltage test would have to be done to determine which compoonent has failed. Generaally it is worthwhile to repair the range.
Posted on Apr 08, 2009
Is it possible to replace the ceramic top to the stove?
Yes depending on the model. I would price a new top and compare it against the price of a new stove.
Whirlpool Cooktop Broken Glass Replacement Model RCC3024
Dec 06, 2015 | Kitchen Ranges
Glass panel missing on grill (top oven) door?
if there seems to be a hole there and not a solid door then yes there should be glass there. try doing a goggle search on the brand . there might be a pic there to show you what is should look like.
Nov 12, 2011 | Ovens
Glass top on range is broken.
pull bottom panel out look on stove middle just below oven door
thumbs up
Aug 17, 2009 | GE Spectra JBP78 Electric Kitchen Range
Who can replace a Admiral stove glass top?
i cracked mine too. the tops cost enough to make you just wanna buy a new stove.
Jul 16, 2009 | Frigidaire FEF366 Electric Kitchen Range
Broke glass on electric genn-air
Please do not use the stove if the element is viable because of broken glass, this could become a danger to yourself.
Look at the cost of a new stove, you should be able to get one for
around 400.00. One of my customers had a glass top with 4 burners,
they had the same thing happen, the cost to replace the top was
1,200.00. So I would assume that you can get a new stove with 4
burners less then it would cost to replace the part on a stove you don't like. Maybe there is a LOWES around you to look at stoves,
they seem to be everywhere,like death and taxes.
As for putting a 4 burner top on a stove that has 2 with grill, I don't think it can be done without the extra cost of adding the parts to run the other 2 burners, so like I said in the long run,it just might be cheaper to but a new stove. It should not be a big deal to remove the exhaust from the grill part of the stove.
I looked at the model# you put down,and it does not have a grill,
from what I see, there are 4 burners and a downdraft vent in between the 4 burners, there are 6 models with this part # and none have a grill,only the downdraft vent.
If the model# is right, the cost would be around 300.00 for the glass, and then the cost of having it replaced. So I would say over
400.00, In which case for the same amount you could have a new one, but you must weigh the difference for yourself and see what you think is the best way to go.
If you have any more questions,please post back and everyone is more than willing to help you. I hope I have helped a little.
Mar 24, 2009 | Jenn-Air JED8430 Electric Cooktop
Broken glass top on my gas stove
Hello Cathy,
Pretty much everything on earth CAN be replaced but it will become your call how much you are prepared to spend to accomplish that. I suggest you contact any Frigidaire dealer or repair site and provide them with your model number and ask for a replacement top price. Not sure that helps but it should get you headed in the right direction.. There are also many online appliance part sites that you can get a better feel for the cost of your glass top ..
Regards,
Rick
Feb 16, 2009 | Frigidaire FES367 Electric Kitchen Range
Broken glass top for my gas stove
You can buy just the glass for your glasstop stove. I too need to replace my glass...I have a whilpool electric glasstop. Its not cheap...may just buy new stove. I priced just the glass for my whilpool at the cheapest I can find for $320.00. Thats a lot. Mind you its not the elements under the glass..its just the glass! So...idk bout you, but a whole new stove might be my best option. If you want to price the glass for your model just keyword search your number and brand of stove and type replacement glass. GOODLUCK! :)
Sears glass top range problem -790.95751990
A room mate burned and severly damage the glass top range. How do I find out about replacing the glass top?
Jan 01, 2009 | Kitchen Ranges
Crack on glass top stove
Hello
Welcome to Fixya
My name is Huum,
You can replace the smooth top !.
But I will tell you not to spend more than half the price of a new stove. How old is the stove and what's the model number!
Waiting your response.
Please remember to leave a rating before you leave
Dec 11, 2008 | Jenn-Air JED8430 Electric Cooktop
Ceramic Glass broken
when ordering you would have to know the color also
Dec 05, 2008 | GE 30 in. JP340 Electric Cooktop
Kitchen Ranges Logo
120 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
