Question about Kenmore Refrigerators
Kenmore Refrigerator model 106.66861790 maunufacture date: 08/98 Problem: water is collecting on several of the interior frig shelves and collecting under the crisper containers, eventually turning to ice. Tom
aborcass
  • 2651 Answers
SOURCE: Water collecting in refrigerator and ice collecting in freezer
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you access to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somewhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wire around the heater( black heater right above the drain trough) and stick it in the whole maybe an inch or so. now every time the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 15, 2008
  • 1122 Answers
SOURCE: Dripping water
YOUR DRAIN FROM FREEZER TO DRAIN PAN IS CLOGGED,LOOK INSIDE TOP BACK OF REFRIG. SHOULD BE DRAIN HOPPER,REMOVE AND CLEAR OUT DRAIN,THANKS-MIKE
Posted on May 29, 2008
SOURCE: Roper Refrigerator
The regrigerator has water dripping onto the shelves and on the lower portion of the refrigerator into the bottom drawers also.The correct temperature setting is right.how do i fix this.
Posted on Nov 06, 2008
  • 400 Answers
SOURCE: i have water standing inside the crispers, shelves
I beleive that your thermostat is faulty which is causing an excessive build up of ice.
Posted on Mar 05, 2009
jumptrout51
  • 3361 Answers
SOURCE: water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Posted on Mar 11, 2009
I have a Kenmore Coldspot (mfg date 10/00), model 106.70192001. The ice maker is NOT hooked up (by choice) and for the last several weeks, there has been water draining from freezer into fridge in a cyclic...
Your drain line is frozen and is not allowing the defrost water to drain to the pan below. You will need to remove the rear panel in the freezer and thaw the drain line. Make sure ALL ice is thawed before reassembling. I would recommend installing a drain heater so it will not happen again. They are inexpensive and easy to install. They come with complete instructions.
Kelly
Mar 22, 2011 | Kenmore Refrigerators
Water is collecting on the shelves in the main compartment
Sounds like a typical defrost drain blockage. Not sure what model of profile you have if older or newer stile but when the defrost cannot drain to the pan below the refrigerator the water collects inside th refrigerator creating a mess. I'm going to send you to another web page that will help you see a better idea of just what i'm saying so we can help you resolve the problem and learn how to clear the drain and get the water to stop messing up everything. Be right back putting our daughter to bed and brushing her teeth, Sea Breeze
Mar 01, 2010 | Refrigerators
I get water (alot) on shelves inside the frig. I looked at drip pan underneath and it is dry. Checked vents inside frig and they are not blocked.
Sounds like the water drain for the freezer defrost is clogged. You will need to remove the back panel inside the freezer and check it. Sometimes it's just a piece of paper, or other wrapping that gets into it. Always UNPLUG the refrigerator first.
Jan 01, 2010 | Kenmore 18.9 cu. ft. Top Mount...
Water collecting on the shelves
Sure are a lot of sweaty fridges out there. My wife complains about it too. A mis-fitting door will allow moist air inside. Brute force usually fixes that. I just put my foot against the door bottom and bend the door back to where it belongs. If it has drooped, try just forcing it back up. And don't keep the door open too long when looking for stuff.
Apr 11, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water collects on shelves and below the crisper bins at bottom
Mar 11, 2009 | Refrigerators
Water on btm of glass shelves and water in bottom of frig
sounds like you have a gap in the door seal, which results in condensation forming inside unit. Use a blow dryer to heat the seal around the door and ensure that the fit is tight.
Jan 07, 2009 | Kenmore 72073 Top Freezer Refrigerator
Roper Refrigerator
open the freezer compartment loo for ice build up on floor of frezer especally towards rear behind back panel. sounds like you have a clogged/frozen defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials)
Mar 05, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Spitting refrigerator
HI ... TRY TO FLUSH OUT THE DRAIN LINE FIRST. SOME ARE ONLY VISIBLE BY LOOKING THROUGH THE BOTTOM AT THE REAR OF THE FRIG. THE TUBE IS SUPPOSED TO DRAIN INTO A PAN DOWN THERE. THE HEAT FROM THE CONDENSER EVAPORATES IT. GOOD LUCK
May 02, 2007 | Kenmore 94499 Refrigerator
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
