Question about Bosch Exxcel WFO 2264 Front Load Washer
The machine is not draining - Bosch Exxcel WFO 2264 Front Load Washer
  • 6,993 Answers
There are several reasons why a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
Find some possible cause and how to solve the problem:
A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
Good luck.
Posted on Mar 19, 2011
Holding water
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 02, 2013 | Washing Machines
Washer won't spin
Good Day,
Avanti washer repair
Good Day,
Nov 01, 2013 | Washing Machines
Machine lacked about 23 minutes in cycle, it stopped with lights flashing. It will not drain, therefore cannot spin. It just beeps whenbi try to start it again.
Good Day,
Nov 01, 2013 | Whirlpool Cabrio Washing Machines
Machine stopped in mid cycle with the drain/unlocking light on. No error codes. Machine goes directly to the drain/unlocking position after start. Will not fill, spin, operate. Any ideas?
Good Day,
Nov 01, 2013 | Whirlpool WFC7500VW Washer
Won't drain and showing F 01
Good Day,
Oct 31, 2013 | Maytag EPIC MFW9700S Front Load Washer
Unable to locate the drain so that we can drain the machine. Can you advise where the drain olug is situated
Washing machines usually do not have drain plugs. Take the drain pipe and lie it on floor and let it drain into a flat container, this is the only way I know of draining a machine.
Mar 06, 2011 | Washing Machines
Water wont drain during spin
Check the drain hose, drain pump and the drain sump for any object that might be blocking the passage of water.
Drain Problem Troubleshooting Guide for Frigidaire Front Load Washers
  1. Safety first. Unplug the machine.
  2. Remove the drain hose from the drainage.
  3. Cushion the top rear edge of the machine with a thick cloth then lean it back against the wall.
  4. Remove the two screws holding the front access panel to the base of the machine.
  5. Pull the front access panel down and out.
  6. Lay a towel under the drain sump to prevent flooding the base of the machine.
  7. Remove the drain sump from the tub by loosening the clamp holding it..
  8. Remove the drain hose from the pump by loosening the clamp holding it.
  9. Remove the two screws holding the pump housing to the base of the machine.
  10. Disconnect the wiring harness from the pump motor terminals then pull the pump out of the machine.
  11. Remove the drain sump from the pump by loosening the clamp holding it.
  12. Check the drain sump and the drain hose for any clogging and clean it.
  13. Replace the drain pump if the drain hose and drain sump are not clogged. Install the new pump on reverse of the removal steps above.
Feel free to ask for further assistance if necessary.
Jan 23, 2010 | Frigidaire ATF6000ES Front Load Washer
Machine keeps draining on the rinse cycle.
your drain hose is either stuck to far down in the drain pipe or your drain hose is sealed to the point it has no way air can enter the drain pipe which creates a siphining issue. your drain hose has to have a air gap so the siphing can not occur. the end of your drain hose should be no lower than 34 inches from the floor draped into the drain pipe with a way air can enter at that piont.
Feb 01, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Fisher Paykel Wash Machine GWL11US
hot drain pump? suggests that the pump is not being lubricated properly...
May 27, 2008 | Washing Machines
Bosch Exxcel WFO 2264 Front Load Washer Logo
81 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
