Question about Logitech Webcam
My c25 webcam does not show pics on skype how can i troubleshoot
Inbuilt webcam not in drivers
Open the control panel on the start menu and click hardware and sound, choose devices and printers and see if the webcam shows up there. If it does right click and click troubleshoot. Windows will scan the device for errors.
If the device is not visible in the device manager, then you need to install a driver for it.
If you let me know the model of your PC I may be able to point you to the right place to download a new driver or you can try the Advent support website.
Mar 17, 2012 | Advent Computers & Internet
I have the XGR webcam with built in mic - trying to skype - got pic but says mic is on mute - for the life of me i cannot find the mute button - only thing that clicks is the little silves things at the...
in skype, if u have the latest version, call someone, then look from left to right at the bottom of the other persons pic, there is a mic button there, click on it and it will unmute the microphone.
Mar 26, 2011 | Logitech Webcam
Hi i have a Gear Head WC785SFX 1.3 MP Webcam and i cant get any video display showing me that the actual camera part is working. But the speakers and microphone on the webcam both work i just cant get the...
First of all test your cam here
Test My Cam Test Webcam
Just make sure its plugged in
If it works here sign into Skype
Click on Tools
Click on Options
Click on Video
Make sure the gearhead webcam is set as default above the video screen. ( It may not give its name but refer to it as USB camera )
Once your picture is visible that's it.
If you still have no pic here but have at Test my cam you need to find out what additional software you need to run this cam
Nov 16, 2017 | Computers & Internet
Using the original software for 2000, pc con cam will not show pic using Sjype with xp on thinkpad
Check if your software is OK - go to this site and hit 'Allow' in top window.
http://www.testmycam.com/
If your webcam broadcasts in the left hand panel configure your webcam to Skype
If your webcam has a built-in mic
Open Skype > Options > Audio set up - run through check list > Save
Make test call from inbox using Echo/sound test.
Webcam
Options > Video set-up - run through check list - fine tune quality of picture using settings > Save
Make a test call to check settings
Oct 09, 2009 | IBM Webcam
A4 tech 5M notebook webcam on hp pavilion notebook with integrated webcam - very blurry pic on new a4 webcam with skype - and not online just testing
I suggest you download the user manual from the CD and see how to set up the webcam before you go into Skype
Before you do that, check the image on another site to see how it looks
Hit "Allow" in top window and see the webcam transmission in the left hand panel.
Aug 20, 2009 | A4tech Computers & Internet
Have ezcam II webcam and can't get picture to show on skype
Normal 0 See section A. Skype in the info below to setup the Audio & Video.
Also send this to your family and friends so they have their computer setup properly.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
Hope this helps. Bud
Feb 26, 2009 | Ezonics EZVideo Chat Kit Webcam
My integrated webcam is not displaying
can you access the webcam using the utility (hp webcam not SKype)? Sometimes Skype loses sync with devices. double-check your Skype version too.
Dec 24, 2008 | HP Pavilion dv1000 Notebook
Using with skype
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video shoud work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Mar 23, 2008 | Trust SpaceCam 100 Webcam
Pic on yahoo messenger chat
on yahoo you have to select the cam
select messenger > preferences > webcam and select source
Dec 08, 2007 | Logitech QuickCam Pro 4000 Webcam
Logitech Webcam Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
