Question about Ultratec CrystalTone Corded Phone
Program speed calling
Please send steps on how to program numbers for speed dialing. Thank you!
Mayo
  • redbo Aug 02, 2008
    sorry...need the steps to program the speed dial numbers for the crystal tone corded phone.
I'm having problems with a Samsung KPDCS-12B LCD phone I've recently been given, I need to add myself to group 501 to take calls for my department (Plumbing) but my phone (Extension 250) is...
Hi you need to do this in 2 parts - firstly to add yourself to group 501 follow the step-by-step instructions which are on the video I have posted. Then follow this to add a mobile number to the directory;
Press the TSFR key
Enter 200
Enter code 1234
=/- key to enable
Speaker key
dial 705
I.e. once in 705
Type in speed number, the cursor will tab over to speed dial slot.
Enter 9 followed by the phone number.
Press 12th button down,
Enter name,
Press 12th button. (You will be back at the speed dial.)
Press tab, then enter the next speed dial slot you wish to program.
NB-
( 705 - Speed dial 12th Button down to toggle between)
( 706 - Speed Name the 2 MMC
Jun 08, 2011 | Samsung DCS 12 Corded Phone
How do i reprogram my speeddial numbers on jazz 4400?
Hello.
From NorStar Support:
To Program Personal Speed Dial Numbers: (Numbers 71 - 94 only.
1. Press the Feature button, then * 4
2. Enter the 2 digit code (71 - 94). that you want to assign to that phone number
3. Enter the telephone number, then press the OK softkey
4. Display will show: "Entry xx stored"
If the above doesn't work, try:
  1. Press [Feature] [*] [4]
  2. Enter a two-digit code from 71 to 94.
  3. Specify the external line by pressing a line button, a line pool button, or the intercom button. If you don't specify the external line, the system automatically chooses a line for the call.
  4. Dial the telephone number you want to program (up to 24 digits).
  5. Press [Hold].
  6. Record the code and number you have just programmed.
Hope this helps.
Feb 02, 2011 | NorStar Jazz Plus 4400 Corded Phone
How do i change a speed dial number on my brother mfc-7340?
Changes to the contents stored in the address book do not become effective in the stored speed dial numbers in Windows®. Description:If you have made a change to the contents stored in the address book, the speed-dial is NOT automatically updated.
If you change the address book entry, please follow the steps below to store the speed dial number again.
  1. Click on the setup button to open the Brother PC-FAX Setup dialog box.
    Notes:
    You can also access the Brother PC-FAX Setup dialog box by clicking start => Programs => Brother => MFC-XXXX or MFC-XXXX LAN (where XXXX is your model name) => PC-FAX Sending => PC-FAX Setup.
  2. Click the Speed Dial tab.
  3. Select the Speed Dial No. which includes the member or group you made a change in the address book, and then click Clear.
  4. Click the Speed Dial No. you want to program.
  5. Click the member or group you want to store on the Speed Dial again and click Add.
  6. The Speed Dial is now registered with the new entry. Click OK.
If you put the patch below, the message that prompts you to confirm the destination number or address will appear when you send a fax using the speed dial. Also the message that indicates changes in the address book do not become effective in the stored speed dial numbers will appear when storing a speed dial.
  1. Make a temporary folder on your HDD [hard disk drive] as the location to save the downloaded self-extracting file, e.g. C:\brodnt
  2. Please click here to download the patch. (7.07MB)
  3. The Brother End-User License Agreement will appear. If you agree to the terms, click I ACCEPT.
  4. Download the file to the temporary folder created in Step 1.
  5. Once downloading is complete, open the folder and double click PCFAXUPD.EXE.
  6. The installation will start. Please follow the on-screen installation directions.
Trust this is helpful. Please vote. :)
Dec 11, 2010 | Brother MFC 7420 All-In-One Laser Printer
I don't understand the one touch dialing on the HP 2140
Hi Suzeo. Many HP fax machines have the function you are requesting. It is called the broadcast fax feature. Look in your owner manual for this feature. If I knew which model you have I would have researched it for you. IF by chance, your machine does not have this feature, it would be money well spent to replace your current machine with one that does. Depending on how many pages the daily fax is, I am estimating that you are spending an hour or more each day on this task. J.
Jul 03, 2010 | HP Office Equipment & Supplies
How to program speed dial numbers?
To Set:
Do not lift handset
Press FNC button
Press the desired “One Touch” Key
Enter number to be stored (remember”0” for external numbers)
Press FNC button to save
To Dial
Lift Handset
8
Press desired One Touch key to dial
Jun 25, 2009 | NEC ETJ 16DD-2 Corded Phone
I have a lexmark x4270. Having problem sending fax. Sending local number, it's OK, but sending a different area code, it uses the local area code then the first 7 number of that number. Because someone...
Hi zoaj,
More then likely you have the fax set up to USE A DIALING PREFIX.
Therefore it is automatically doing this, regardless of what you input.
Follow the proceedure below ( which comes directly from the users manual for your printer type ) to change this. Delete the " USE A DIALING PREFIX " information.
once that is done, it will no longer automatically add the prefix for you. :)
I have BOLDED the relevant information below that pertains to this.
Please take a moment to evaluate my solution. Your appropriate rating of my solution would be greatly appreciated.
Thank you,
Using the Fax Setup Utility Use this utility to adjust the fax send and receive settings. When you save these settings, they apply to every fax you send or receive. You can also use this utility to create and edit your speed dial list.
  • Click Start onestep.gif Programs onestep.gif Lexmark 4200 Series onestep.gif Fax Setup Utility.
  • From Lexmark All-In-One Center All-In-One Main Page, click Fax Setup Utility.
The following table describes the Fax Setup Utility tabs:
On this tab:
You can:
Send
  • Enter your name and fax number.
  • Select a maximum send speed and a print quality for outgoing faxes.
  • Choose whether to scan the entire document before dialing the number.
  • Choose whether to use error correction.
  • Select when to print a fax usage report.
  • Select when to print a fax activity report.
Receive
  • Choose whether you want to print a footer (date, time, and page number) on each page.
  • Automatically reduce an incoming fax to fit to the paper size loaded or print it on two sheets of paper.
  • Select whether you want to forward a fax or print it, and then forward it.
Connection/Dialing
  • Select the number of times you want the machine to redial and the time between those attempts if the fax cannot be sent on the first try.
  • Select the phone line format you want to use (Pulse, Touch-tone, Behind a PBX).
  • Enter a dialing prefix.
  • Choose how (manually, if fax tones are detected, or after a certain amount of rings) you want to answer incoming calls.
  • Select a distinctive ring.
Speed Dial
Add to, create, or edit the speed dial list.
Group Speed Dial
Create a group number and name, and then add phone numbers to the group.
Oct 11, 2008 | Lexmark Office Equipment & Supplies
How do i edit my speed dials?
Redial, speed dial enter the code(60- 99) for system speed dial
(10- 49) for personal speed dial. enter the phone number or the number you want to program then press redial.
Aug 26, 2008 | Toshiba DKT-2010 Corded Phone
Speed Dial and Amplified Echo Feedback
press the number of the speed dial saved and hold down until the phone number appears then press talk
Jan 23, 2008 | Uniden TRU8885 Digital Answering Machine
Ultratec CrystalTone Corded Phone Logo
24 people viewed this question
Top Ultratec Lands Phones Experts
Computer Repairing
Computer Repairing
Are you an Ultratec Lands Phone Expert? Answer questions, earn points and help others
