Question about Proform Crosswalk 500 Treadmill
None of my keys in my proform 500i woek excep the 3mp and the 9 mp no even the start works
    Top Expert:
  • Proform Master
  • 12,223 Answers
If the console takes batteries, replace them. If this does not work or your console does not require batteries, check the reed switch or optic sensor. Reed Switch: Unplug the treadmill and remove the motor hood cover. The reed switch is mounted on the frame next to the front roller pulley. There is a magnet glued into the front roller pulley. When adjusting the reed switch, make sure it is pointing directly at the magnet. Move the tip of the reed switch within 1/8" of the magnet. Also, check to see that the wire is not damaged, and is connected to the console.
Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk
aFTER YOU TEST THE SENSOR DETERMINE IF THERE ARE FAULTY AND REPLACE.
Posted on Nov 15, 2011
Pro form 320x treadmill stops working when you get on it
How can I get my Proform 320X treadmill from stopping a ...
www.shopyourway.com > Manage My Life > Questions
How can I get my Proform 320X treadmill from stopping a few seconds after starting? ... -why-does-my-proform-treadmill-belt-only-move-a-few-seconds-stops
ProForm Treadmill 320x User's Guide ' ManualsOnline.com
fitness.manualsonline.com > ... > ProForm Treadmill
ProForm 320x Treadmill User Manual. Page 1. Page 2. Page 3. Page 4. Page 5. Page 6. Page 7. Page 8. Page 9. Page 10. Page 11. Page 12. Page 13.
Nov 03, 2015 | Exercise & Fitness
Proform 500i problems. 3mph, 9mph and program select buttons are the only ones that work
1) ADJUST REED SWITCH AND OPTIC DISK , AFTER YOU DID IF THE PROBLEM PERSIST. CHANGE IT.
2) AFTER YOU DID, THE PROBLEM IS CONSOLE BOARD.11_15_2011_9_27_32_am.gifTIGHT EVERY CONNECTION BETWEEN CONSOLE BOARD AND CONTROLLER BOARD, LOOSE CONNECTION, BAD CONTACT,CLEAN CONTACT SPECIAL SPRAY CONTACT CLEANER, 11_15_2011_9_27_51_am.gif
May 27, 2011 | Proform Crosswalk 500 Treadmill
Every time I put the key in my Proform 590T, the incline rises for a second, and lowers for a second while displaying 2 hash marks. Then, the home screen comes. All speeds work fine for walking/running,...
how long have you had this treadmill? usually when the hash marks appear it means that the console control board is not recognizing the incline motor. even though it does run a little bit that is just the basic test that the treadmill starts but resets after it does not sense the incline motor. These motors rarely go bad so it is more than likely your motor controller that is causing the issue. I have seen this case many times as i am a fitness repair technician. The motor controller fixes the issue 9 times out of 10
Aug 05, 2010 | Proform 590T Treadmill
I have a proform 500i treadmill, when my key is in place the control board lights up but none of the buttons work. no functrions whatsoever.
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Feb 06, 2010 | Proform Crosswalk 500 Treadmill
Belt is slipping on a proform 740cs treadmill. how do you tighten
You can get the manual on linke below. When there type in the number code then hit submit. on the next screen click on manual link to down load. then on page 21 tells you how to adjust belt.
http://www.hammerwall.com/Download_Manual/18209/
Jan 06, 2010 | Proform 7.0 Crosstrainer Treadmill
Proform 500i not working.
Try putting the treadmil in a cooler location. the heat is effecting the mother board.
Mar 23, 2009 | Proform Crosswalk 500 Treadmill
Proform Crosswalk 500 Treadmill Logo
131 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
