Question about Intel Motherboard
Graphics Hi I don't have any other option to change the resolution for my monitor and the display and colors cannot be changed in settings options, what do I do? Please help
  • David
    David May 11, 2010
    I need to know what make and model you graphics card is
  • 781 Answers
You could try right click anywhere on desktop clear of icons go to properties when display pops up go to settings near the bottom is a slider bar to adjust sizes etc. then you can go to advanced and check out what else you need
Posted on Aug 05, 2008
The display is shrinked vertcally in the centre of my LG 915 monitor. plz help me out. Thanks
Hi nasirallahdi ,
If your display is shrinked vertically , please follow the below steps :-
  1. Check the settings button on your monitor , when you press the button you have multiple options coming up which includes reset option.
  2. Go to the reset option and select ok , so that your monitor is reset.
  3. If this does not solve your problem then it could be because of a incorrect resolution being set in your desktop properties , in the settings tab.
  4. To change the resolution settings you need to go to the display settings by finding the option on the desktop via right click and you can try changing the resolution and see if things get ok.
  5. If still the problem persists , then it could be a hardware fault which you need to get repaired via the manufacturer's warranty limit , if it has expired you will be charged for it.
  6. Most probably the problem is with the incorrect settings in the monitor panel , and i believe after you reset your monitor via the monitor panel , things would be alright hopefully.
Hope this helps ...:)
May 10, 2011 | LG Flatron 915FT 19" CRT Monitor
Tip
How to change your Windows 7 display settings In Windows 7 there are serveral...
In Windows 7 there are serveral ways to get to your display settings. I have detailed them below in options so that you can access them as needed.
Option 1
Right click on your desktop and select "Screen Resolution"
Option 2
1. Right click on your desktop and select "Personalize"
2. Next click on "Display"
3. Click on "Adjust resolution"
Option 3
1. Click the Start button and click Control Panel
Once you are in the Screen Resolution you can set the resolution you want.
Note the resolution that is set now is a wide screen resolution. If you have a standard monitor the equivalent resolution would be 1280 x 1024.
After you have made the needed changes click on Apply then OK to save your changes.
Note if you are still have trouble with your monitor displaying right you may need to install the monitor drives. Windows is not going to have the actual drivers for all monitors. So in picture below you will see where is shows "Generic PnP Monitor" this means that the computer is using a generic driver. You can access this screen by clicking on "Advance Setting".
If you need to install the monitor drivers the link below will take you through the steps of installing the monitor drivers.
http://www.fixya.com/support/r4290666-install_monitor_drivers_in_windows_7
Other Helpful Links
How to change your Windows XP display settings
How to check and change you computer IP address in Windows 7
How to enable and disable printer and file sharing in Windows 7
How to take file ownership in Windows 7 and Windows Vista
How to change your drive letter in Windows Vista and Windows 7
on Mar 08, 2010 | Computers & Internet
Display resolution very low and bit rate is 4bit, unable to adjust both levels. also where can i obtain latest system disc for foxconn intel type motherboard.
click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
also
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps don
Mar 12, 2011 | Fujitsu Computers & Internet
Hi! I have a benq G2222hdh lcd monitor and i have a radeon 6800 graphic card with hdmi compatibility. My monitor isnt in on the full monitor but about 2cm is smaller than it should be. I tried everything...
also
hope this helps
don
Mar 03, 2011 | Computers & Internet
How do I change my computer monitor to 1680 x 1050?
First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear as shown in fig. below, click on the settings tab at the top right of the box.
The areas worth noting are: google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor, but the standard options are 800x600, 1024x768 and 1152x864.
Normally the default (in XP) is set to 800x600 which means the display will be 800 pixels wide and 600 pixels high.
Color Quality
This pull down box will contain the current colour options available, again this will depend on your grahics card and monitor, for best results select the highest option available.
Changing the ResolutionTo change your resolution simply slide the bar along to the resolution of your choice and then click the Apply button.
After clicking Apply your screen will resize to the new resolution and you will be presented with a confirm dialogue box, if you are happy with the way your screen looks then simply click Yes, if you would like to try a different resolution click No.
When you have finished simply close the Display properties box.
Jan 13, 2011 | Computers & Internet
I tried to set up dual clones monitors and set the display too high for either monitor now i cant see to reset the video display. Is there a way to reset the card to factory setting with seeing the...
Hello dave, the only way you can change default setting on resolution is go to > Nvidia Control Panel > Display > Change resolution and click apply. If this option does not work you can go to start> control panel> uninstall a program and remove your old nvidia driver from you computer and reinstall latest driver again, restart computer. I hope this helps you.
Nov 26, 2010 | BFG Technologies 3DFuzion 3DFR6200LEE...
My moneter sceen picture has become large and out of focus
i  think there was  a problem with system monitor resolution setting,please follow the given steps and check the monitor setting-
1-Right click and go to property option
2-chose setting option
3-check screen resolution,standard size is 1024 by 786 pixels and color quality is highest 32 bits
  and also check advanced option under setting DPI setting is normal size 96 DPI ,choose all option than apply and ok.
Thats helpful to you.
Thanks,
Dec 13, 2009 | Computers & Internet
Display resolution goes from 1024x600 to 800x600 at start up.
try reinstalling the drivers for the onboard graphics and for the monitor. Might be the monitor is not supporting the default resolution.
Jan 18, 2009 | ASUS Eee PC 900 Notebook
We can't get our screen resolution back to what it was (1024x768) it changed when a game being played ended. It runs on 800x600 at the moment and everything is too big.
The display properties dialogue box will appear as shown in fig 1.1 below, click on the settings tab at the top right of the box.
Screen Resolution
Color Quality
This pull down box will contain the current colour options available, again this will depend on your grahics card and monitor, for best results select the highest option available.Changing the Resolution
After clicking Apply your screen will resize to the new resolution and you will be presented with a confirm dialogue box (see left), if you are happy with the way your screen looks then simply click Yes, if you would like to try a different resolution click No.
Aug 05, 2008 | Computers & Internet
Monitor color display problem
Go to the control panel. Click on display. The display applet is your next stop. The display applet is your central location for all of your display settings, including resolution, refresh rate, driver info., and color depth. The display applet has 5 tabs: Thmes, Desktop, Screen Saver, Appearance, and Settings. The 5th tab is where you make adjustments that relate directly to your monitor and video card. Look at the Settings tab. At the bottom of the dialog box, you'll see 2 options. Screen Resolution and Color Quality. By moving the Screen Resolution slider, you can change the resolution. The most common resolutions are 640x480, 800x600, 1,024x768, and 1,280x1,024.Your system may have more or fewer resolution options.
The color quality is the number of colors displayed on the screen .You can change the screen resolution with a simple slider and adjust the color depth from 4-bit all the way up to 32-bit color.
Running a 32-bit color gives a nice, realistic tone to images, and many games insist on it.
Clicking the Advance button opens another dialog box with 4 or more tabs.
The monitor tab gives you details about the currently installed monitor and enables you to make changes to the driver and the refresh rate.
After you make your changes to your monitor and it still is not working properly, it must be your video card which is not seated.
In layman term, your video card is not plugged in firmly in the slot!!
Jul 11, 2008 | Acer X193W LCD Monitor
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
