Question about Whirlpool Washing Machines
Whirlpool top load washing machine leaking very badly. is 3 years old.
    President:
  • 2,468 Answers
It could be a tub leak,a pressure hose out of the tub side,or the water fill solenoids and hose leading to the tub
Posted on Mar 19, 2011
Whirlpool ultimate care extra large, about 10 years old. when the machine is in spin cycle, it throws the circuit breaker. It started with a heavy load, but now it seems to do it all the time. It started...
Water leaking from tub seal into motor possibly? Try doing spin with dry newspaper under the machine and check for leaks. Could also possibly be water heater element loose or breaking down - leaks from drain hose or water pump body into windings? Dry news paper test should highlight where leaks are coming from.
!0 years old is ancient for a machine and you might consider replacement rather than a repair which will only be throwing good money after bad. Do you drive a 10 year old car? if you do, you expect repair bills to mount up! same with washer. I bet it doesn't owe you much!
Jan 03, 2018 | Whirlpool LSW9700P Top Load Washer
Hello. I have a two years old Whirlpool washing
Unless you look underneath it will not be easy to confirm but please check the following.:
1. check if the motor has failed, the housing has come off.
2. checckif the belts have failed and brought it off the pulley.
3. check if the main spindle , pulley has come off from the main shaft.
4.check if theere is any foreign material struck in between the tub and outer cover. Checking with manually must confirm.
5. check aftert he above had been looked into to see if any other issues are visible or audible.
Hope these tips helps.
Aug 24, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Our whirlpool washing machine is 2 years old. It
Lid switch bad. Turn on and push down on lid switch with something
Aug 03, 2009 | Whirlpool WTW6400SW Top Load Washer
Cold water hose or seal leak inside machine leaks into basin
Replace the water inlet valve. That is where the hoses connect.
Here is a link to show you how to access the inside of the washer..
Mar 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water Leak
is the pump gray or white? if it is gray then replace it.look where the pump mounts to the ,otor and see if there is a black line coming from the middle.this is probably where your leak is.
just change the pump.
Oct 12, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Ammana washer less than 5 years old making loud noise and leaking water from bottom of washer
it sounds like the tub seal is going bad and leaking on the bearings,not good,you can remove the top with a putty knife into the front seam one clip on each side(make sure no screws on bottom front,you can now check everthing out to see what you find,let me know -mike
Sep 26, 2008 | Whirlpool Washing Machines
Whirlpool 3 year old washer
sounds like a bad basket drive.i don't know why after only 3 years though
Sep 15, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
Sal De
Gerry Harvey
Gerry Harvey
