Question about Fisher DD603B / DD603W / DD603H Dishwasher
My the drain hose on my dishwasher got kinked and I fixed it but I keep getting a F1 error. I dried out the pan underneath. how do I reset the flood switch?
  • 77 Answers
F1 means that your dishwashers have flooded. You can download the video in the link below to see how to get rid of the error and fix your dish drawer for numerous other problems. If your drawer is noisy you may want to replace the rotors at this time as well.
Appliance Repair Video
Order Fisher Paykel Rotor in this link if needed
Posted on Mar 23, 2011
  • 4,323 Answers
Hi
Error F1 on your fisher & paykel means an overfill condition. One of the most common causes for an overfill fault is that the dishwasher cannot pump out the dirty water due to a plugged drain hose. Check the drain hose if it is clogged. Now remove the bottom drawer from the unit to inspect the flood switch. Remove the wire harness cover on the underside of the drawer. With the bottom cover off, unclip the wire harness, fill hose, and drain hose. Then unclip the linkage at the back of the drawer and lift the drawer off the slider arms. Now' you'll be able to look at the flood switch. Note the positions of the wires on the flood switch and remove them. Then unclip the switch housing from the base panel. The switch housing contains one switch for each drawer. The switches are wired normally closed (NC) and each switch has three spade connections, so it's important to note where the wires went. Now clean the contacts and let it dry. Hope this helps... Please post back if you need more information.
Daniel
Posted on Mar 19, 2011
Keeps stopping and showing OE
Hi tpearsgolf,
The "OE" error code you are seeing, means "Outlet Error"
The drain pump is either clogged, or the outlet hose has been kinked.
- Inspect the Drainage hose at the back for kinks. - If any, straighten the hose
- Open the unit, and at the bottom sump check the small drain pump area for any foreign object that may be obstructing it. You can remove the filter, as well as the metalish sieve underneath it, check the sump underneath near the drainage holes, make sure nothing is obstructing the flow out of the machine from there.
If not successful, you will need to replace the Drain Pump.
Kind Regards :-)
If you found this solution helpful, please rate it.
Jun 30, 2011 | LG LDS4821 24 in. Built-in Dishwasher
Machine displaying f1
The F1 error refers to 'internal flood.'
You may wish to reset the power of the unit, this may clear the error code.
One common cause is too much or 'wrong' detergent causing too many suds. In this case, giving the unit time and a reset is all you need to do.
You may wish to check under the unit to look for a tray with a widget floating in it. If you find such a tray, empty it & cycle the power to reset the F1 error.
I hope that helps.
Mar 14, 2011 | Fisher and Paykel DD605SS Stainless Steel...
Getting f1 flashing light and a picture of a wrench. how do i turn it off
Hi
Thanks for using FixYa.
F1 error means that the flood switch has been activated. You'll need to reset it by powering off the breaker or by unplugging the unit from the power socket and mains for more than five minutes. Please check that there is no blockage in the drain hose and it is not raised higher otherwise the water will run back to the dishwasher. Also perform the following procedure---
    • Unplug power and remove bottom dish drawer
    • Use a Sponge and dry all the excess water underneath
    • Remove circuit board cover
    • Dry all around and underneath as much as possible
    • Apply hairdryer for 10-15min
Please rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Oct 07, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 is coming up on the top and bottom drawers of the dishwasher.
Hi
Thanks
Rylee
How do i reset a fisher and paykel dishwasher model dw920. Code F1 appeard found out i had a blocked drain, fixed it but still beeps and flashes F1. Have also disconnected power from mains but still the...
Hi
F1 error means that the flood switch has been activated. You’ll need to reset it by powering off the breaker or by unplugging the unit from the power socket and mains for more than five minutes. Please check that there is no blockage in the drain hose and it is not raised higher otherwise the water will run back to the dishwasher. Also perform the following procedure---
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 07, 2010 | Dishwashers
What does an F1 erroor message mean. I have a
F1 means "flood. there is a flood sensor underneath the drawer, and if there is any water under the drawer the control will show that error. Check the drain hose linkage for cracks. Remove drawer and dry the area underneath.
Jul 14, 2010 | Fisher and Paykel 24 in. DS-603 Built-in...
Won't shut off says F1 with a wrench symbol
Hi
Thanks
Rylee
Jun 21, 2010 | Fisher and Paykel 24 in. DS-603 Built-in...
F1 shows on control panel of both drawers,after a couple of startup.Even when machine is not being used both drawers startup on F1,only way to control is to shut off at main supply
Hi
Thanks
Rylee
Jun 17, 2010 | Fisher and Paykel DD605SS Stainless Steel...
Our F & P dishdrawer keeps coming up with f1 and a picture of a spanner have tried turning the machine of at the switch for 24hr but is still doing it
Water has collected at the base of the dishwasher under the drawer.
This triggers a flood switch and causes the F1 error.
Turn the mains power off and extend the drawer out as much as possible. Take towels to dry the base from inside. Also use hair dryer ot dry out the flood switch mounted at the base.
Turn the power on and see if there is any difference. The cause of water collection could be many. Foam in detergent or kink in drain hose or drawer door gasket leaking etc.
May 11, 2010 | Fisher and Paykel DishDrawer DS605FDSM...
Fisher & Paykel Dishwasher leaked
From what you describe, drain water from the top drawer is getting into the bottom drawer or waste water from the disposer is backing up into the bottom drawer.
1. Each drawer has its own drain hose. Each hose should terminate at the drain point with a 'Y' adapter.
2. Inspect the drain point (under the sink where the drain pipes are) to make sure this 'Y' adapter is present. (you should see two drain hoses from the DW). If not present, then the DW drain lines are not installed properly. (Someone took a shortcut and installed the 'Y' adapter behind the DW)
3. If terminated properly, make sure the drain hoses extend upward as they leave the drain point.
It is important the drain lines are connected properly to ensure proper drainage from the DW. Consult the installation manual for complete details.
Jun 08, 2008 | Fisher DD603B / DD603W / DD603H Dishwasher
Open Questions:
Fisher DD603B / DD603W / DD603H Dishwasher Logo
512 people viewed this question
Top Fisher Dishwashers Experts
Tony Houde
Tony Houde
George Merkley
George Merkley
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Fisher Dishwasher Expert? Answer questions, earn points and help others
