Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Chamberlain LiftMaster Pro 2245 garage door has started making a noise (slight clunking) only when closing. I disconnected the garage door and the noise continues. I've looked at the sprockets and the look fine. I would think that if it were a spocket/gear the noise would be heard in both directions. Any ideas?
    President:
  • 3,197 Answers
I would take a close look at the sprocket/gear assembly. There is a bronze bushing that wears and lets that assembly lean. This can cause the chain to miss the teeth on the sprocket just a bit and will cause some weird noises. If it gets bad enough the chain will come off the sprocket. I have no idea why it would only do it in the down direction when there is much less strain on the whole thing. You might also remove the cover from the motor unit and check the drive gear. It is white nylon and wears out. It will be obvious if it is going bad.
Posted on Mar 21, 2011
With my door closed, i push door button to open and the chain and opener continues inthe closing mode. any help?
Shop for sears craftsman liftmaste... on Google
Garage Door Opener Gear...
$31.45
Sears Parts D... Liftmaster 41C4220A Ge...
$21.75
Preferred Do... Chamberlain/l... Sprocket, Gea...
$17.95
eBay Direct Replacement f...
$20.95
Moving Up G... Liftmaster 41c4220a gea...
$31.67
North Shore... Search Results
    Liftmaster Gear And Sprocket Kit 41c4220a Chamberlain ...
    www.sears.com/search=liftmaster%20gear%20and%20sprocket%20...
    Searsmore info. + -. Chamberlain LiftMaster 41C4220A Gear & Sprocket Assembly Kit. $31.40 ... Chamberlain Sears Craftsman Liftmaster 41A2817 Gear Kit. $27.65 ...
Jan 10, 2016 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 9902 won't close at times
Does the motor run? Does it make a noise. What actually happens?
Apr 09, 2012 | Sears Craftsman LiftMaster Chamberlain...
My remote opens my garage door but will not close it. It starts to make a clicking sound when the remote button is pushed to close the garage door. It is a chamberlain Liftmaster with wireless key pad....
Check your door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flashing. Tweak them a bit. If you cannot get both lights to come on you have a bad sensor.
Dec 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: My craftsman 1/2 hp garage dood does not close whe...
If the main light flashes 10 times when you try to close the door it is a sensor problem. Make sure they are not flickering ever so slightly and that they are not loose on their brackets. Tweak them a little bit.
May 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Lift Master Pro Formula 1 only makes click sound
Is the door stuck in the open position? If so the trolley is probably jammed against the bolt just in front of the motor unit. Loosen the chain enough to free the trolley and then run the opener until the door is closed. While the door is closed locate the 'up limit' on the side of the motor unit and turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Apr 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1/2 horse Model HBW0777 acts like the safety sensor is stuck (door won't continue down - re-opens when you let go of the wall button. I can close it with the wall button but I need to hold it...
If the main light flashes 10 times when the door reverses it is a door sensor problem. Look closely at the green lights to make sure one isn't flickering ever so slightly. Tweak them a bit.
Mar 22, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a Chamberlain Liftmaster Professional Model 2245 garge door. It uses a chain and the problem that I have is that the door doesn't stay closed when I close it. The problem I think is with the...
If it were your sensors the main light would flash 10 times. What I think your problem is the door is traveling too far in the down direction. You can correct this by adjusting the 'down limit' which is on the side of the motor unit. Turn this control a couple turns in the opposite direction of the arrow printed on the cover. Some tweaking will be necessary.
Dec 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opens about 8 inches and then revereses
Formula what? they have over forty different types. though sounds something like either limit switches may be faulty. Is this door new? Are there any odd noises from the motor?
Mar 21, 2009 | liftmaster Chamberlain Garage Door Opener...
Chamberlain Liftmaster Pro. Garage door Problems closing
The sensor eye - or more likely, the other end, the sensor light - probably got knocked out of alignment. The eye should have an LED on it - possibly one that glows green when it's ready to close or red when it's obstructed or out of alignment. Try adjusting the light until the LED on the receiver glows green.
Dec 07, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
267 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
