Question about Dryers
Admiral dryer model # AGD4475TQ1 will not heat, vent is clear.
  • 184 Answers
SOURCE: Dryer doesn't heat.
THE FIRST THING TO CHECK IS YOUR POWER. THE OUTLET HAS TWO ANGLED HOLES THAT SHOULD TOTAL 240VOLTS ACROSS THEM. THE L SHAPED HOLE IS THE GROUND AND THERE SHOULD BE 120VOLTS FROM EACH ANGLED HOLE TO THE L SHAPED HOLE. THE DRYER'S MOTOR ONLY RUNS ON 120 VOLTS ( FROM ONE ANLGLED HOLE TO THE L SHAPED HOLE). THE HEATING ELEMENT CIRCUIT RUNS FROM ONE ANGLED HOLE TO THE OTHER(240VOLTS)
THE DRYER WILL RUN BUT NOT HEAT WITH ONE SIDE OF THE CIRCUIT BREAKER TRIPPED.
IF POWER IS O.K., THE NEXT THING TO DO IS PULL THE BACK PANEL OFF OF THE DRYER. THE HEAT ELEMENT IS IN A BOX ON THE RIGHT SIDE WITH TWO RED WIRES GOING DOWN TO THE BOTTOM OF IT. IF YOU HAVE A METER, CHECK FOR 240VOLTS AT THE TWO WIRES ATTACHED TO THE BOTTOM OF THE HEATER. IF YOU HAVE
240VOLTS THERE, THE HEATER IS BAD. IF NOT, THE ROUND ITEM NEAR THE BOTTOM IS A HIGH LIMIT THERMOSTAT. IF YOU HAVE 240VOLTS AT THE TWO TERMINALS ON THE THERMOSTAT, IT IS BAD. PART #
279769 COMES WITH THE HIGH LIMIT THERMOSTAT AND THE THERMAL FUSE FOUND AT THE TOP OF THE HEATER ASSEMBLY. CHECK THE THERMAL FUSE THE SAME WAY.
IF IT IS BAD, YOU WILL SEE 240VOLTS ACROSS IT.
IF ALL THOSE COMPONENTS ARE GOOD, IT COULD BE THE TIMER, TEMP SELECTOR SWITCH, OR THE MOTOR'S CENTRIFUGAL SWITCH. YOU WOULD HAVE TO READ THE WIRING DIAGRAM INSIDE THE CONTROL PANEL TO CHECK THOSE ITEMS.
Posted on Apr 03, 2008
  • 15 Answers
SOURCE: Dryer air heats up but does not dry the clothes. Just replaced the timer but did not fix the problem. Air vents are cleared.
One of two possiblities:
1. Dryer vent is blocked - check the air coming through the outside vent
2. Blower Fan is clogged - remove the lower front panel and clean out the fan wheel
Posted on Apr 30, 2009
  • 89 Answers
SOURCE: Amana Dryer model # LEA60AW. Dryer runs but no heat.
check the heating element and the high limit fuse
Posted on Jul 10, 2009
jsrock516
  • 5911 Answers
SOURCE: Kenmore electric dryer model 110.60942990 no
If the dryer runs, but does not heat, the following link explains how to troubleshoot an electric dryer with a no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
All dryers are not constructed the same. However, the Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
If the model number you have this listed under is correct, the part numbers are as follows:
Heating Element - 279838
TCO/Hi-Limit Thermostat Kit - 279816
All these parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of these components varies, so shop around for the best price.
All your heating circuits are accessible by removing the lower toe panel dire the rear of the dryer by removing the back panel. Just remove the screws around the perimeter of the back panel and the heating circuits will be located on the right-hand side. Refer to the exploded view diagrams at the websites2.gif I mentioned for reference. The heating circuitry is located under the "Bulkhead Parts" section.
If you have any questions, or require additional assistance, please let me know. I hope you find this helpful.
Posted on Nov 01, 2009
SOURCE: my admiral capacity plus dryer will not heat up
amiral dryer ADG7005AWW dry's but does not shut off
Posted on Jan 11, 2010
Admiral dryer capacity plus model number AYE2200AGW. how do you gain access to the rear of the machine to fit and fix the vent pipe?
you should not have to dismantle anything. If you can't attach a duct, quit now and hire a technician
Aug 01, 2016 | Admiral Dryers
How do I replace igniter in Maytag Admiral AGD4475TQ1 gas dryer?
First, you may have to turn off & disconnect the gas line and line-bracket to the dryer (rear of dryer) (because the manufacturer saved by excluding a shut-off valve & disconnect in the unit). Disconnect the cable connector to the valve. Remove the screw(s) on the bracket holding the gas valve/burner/ignitor/etc.CAREFULLY slide the valve/burner assembly out of the unit. CAREFULLY remove the ignitor and replace (part # 279311). Re-assembly in reverse order.
May 15, 2014 | Dryers
Admiral Dryer Model #AGD4475TQ No Heat
This is very rare on a gas dryer but I have seen it. If you have already replaced all that other stuff I would say it has to be inside the timer. On one I worked on once I could remove that orange wire and the dryer would function ok so I ordered a new timer, they sent me a bad timer. Same problem. I finally got a working timer after going through a bunch of mess. That fixed it. So if all the other components are working it very well could be the timer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 02, 2013 | Admiral Dryers
I have the admiral dryer agd4475tq1 and the gas was off for construction now the heat don't work
you've got air in the system you need to let all air out before gas gets to the ignitor..
Nov 25, 2012 | Dryers
I have a admiral dryer model # AGD4475TQ1 ...we turn the gas off now there's no heat how do we relight the pilot
There is no pilot lite on that model, it has an igniter that glows and ignites the burner. There is a small access hole on the bottom left side of the front panel. Remove the cover, start the unit and see if the igniter glows. Post back the results.
The dryer runs fine but has no heat. The exhaust and lint screen are clear of debris. It is a Maytag MD3000
The Heating Element may be gone, or you might be real lucky and have a loose or dirty connection.
You might want to throw the Breaker Switch or unplug the unit before you do anything (220!!!).
Jun 02, 2011 | Dryers
I have an Admiral dryer that is over heating. Its
bad high temp. theremostat on heater box-mike
Mar 14, 2009 | Dryers
My admiral capacity plus dryer will not heat up
Mar 09, 2009 | Dryers
Dryers Logo
656 people viewed this question
Top Dryers Experts
