Question about Acer X193W LCD Monitor
DVI connection to DVI port on PowerMac G4
The DVI cable included with the monitor does not fit the port on the G4 hard drive. I have connected the ADC cable and have a good picture on the monitor, so my question is -- is there an advantage to connecting the DVI option as well?
    New Friend:
  • 99 Answers
DVI offers better picture quality since no DAC occurs.
But to most of us Analog VGA will do
Posted on Nov 09, 2008
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
Powermac screen developed fine black grid and won't operate properly
Isolate the problem to see if it's the screen or video card by connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok without a problem then your original screen is bad and your video card is good. If the Borrowed monitor displays the same problems as your original then your video card inside the computer is bad.
May 29, 2012 | Apple Powermac G4 Quicksilver Logic System...
I would like to know what adapter (DVI to VGA Cable Adapter) I need to connect to a Macintosh G4. Thanks
Without knowing what Model Number of MAC G4 you're referring to, I can only give you generic information.
If your MAC G4 has a DVI port it is generally the female style.
The DVI connector on the adapter will need to be a male DVI style.
The VGA end of the adapter will be either male, or female. Most VGA connectors on a monitor cable have a male VGA end.
(The DVI end will have the pins sticking out on the adapter. The VGA end will have the socket holes)
Also stated as the monitor cable end will be a DVI male. The port {Connection} on the computer is a VGA female)
Example of a DVI male to VGA female adapter,
Barring that you need the other style of DVI to VGA adapter, (DVI female on the monitor cable, VGA male on the computer), this is an example,
[ Note* The newer VGA connectors are also known as an HD-15 connector.
More information on the Video Graphics Array connector,
More information on the DVI connector styles, and the Digital Visual Interface technology,
If you should find all of this confusing, simply state in a Comment as to what connector is on the end of the monitor cable, and what connector is at the computer.
State whether the connectors are Male (Pins sticking out), or Female (Socket holes)
Jul 16, 2011 | Computers & Internet
I have CMV 946D Monitor and i am trying to connect it to my laptop via DVI cable and it doesn't work. my laptop is already connect to another monitor using VGA cable. do i need any driver or does DVI...
Sorry, but you can use only one port at a time, not both, It is either DVI or VGA. If you want to drive two monitors, you need to lok for docking station with dual video card.
Apr 28, 2011 | Chi Mei Corporation CMV-946D/A Monitor
I want to connect an LG 32LD550 television monitor to an Intel based 24" I mac computer---what cable is needed?
The LG 32LD550 television has HDMI and VGA.
Your iMac has a mini-DVI output port with support for DVI, VGA, S-video, and composite video connections via adapter.
So all you need is either:
1) mini-DVI to VGA adapter.
2) mini-DVI to HDMI adapter.
HDMI is better quality, and so I'd recommend something like this: (You may want a longer cable though).
Dec 22, 2010 | Apple 24 iMac - Intel Core 2 Duo 2.8GHz,...
I would like to connect an Apple Studio Display 17" to my Macintosh Server G4. Can it be done? What adaptor is needed if any?
Apple Studio Displays connect via DVI cables. The PowerMac G4 (all versions) support both VGA & DVI. You shouldn't need any adaptors. It should just plug into the back.
Dec 22, 2010 | Apple Macintosh Server G4
Transferring software and files from PowerPC G3 to PowerMac G4
to mount somthing in a mac is basicly cutting it on for use.
For example if you instal a flash drive or an hard drive via an out side connection, The mac will mount it so you can use it.
Aug 09, 2009 | Computers & Internet
ATI Rage 128 Pro ADC 16MB AGP Video Card
Hello Burnolid,
Well, yes, if you have an AGP PowerMac G4 then any AGP video card will FIT into that AGP port.... The question is to know if that card is Mac Compatible ?
Where did you get the card ? Did you get it our of another mac ? or from someone who got it out of a Mac, then yes, it should be compatible with any Mac with a AGP port.
Mar 30, 2009 | Apple Power Mac G4 Desktop
Acer X193W LCD Monitor Logo
128 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
